Old 01-17-2013, 02:48 PM   #1
flux_capacitor OP
I know a shortcut!
flux_capacitor's Avatar
Oddometer: 9,631
I'm leaking fork oil from under rebound adjuster knob.
Has anyone ever had fork oil leak out from under the plastic rebound adjuster knob on the top of the fork? My right one is doing just that and curious how to go about repairing it. Thanks!
flux_capacitor is offline   Reply With Quote
Old 01-17-2013, 02:57 PM   #2
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,475
o-ring
Take the top cap off, remove adjustor, replace 0-ring.
“Men marry women with the hope they will never change. Women marry men with the hope they will change. Invariably they are both disappointed.”
― Albert Einstein
dlrides is offline   Reply With Quote
Old 01-17-2013, 02:59 PM   #3
Johnf3
Oddometer: 1,055
Two things:
First, did you or someone else just work on or service the forks? Commonly, those who are not familiar with WP forks will fill the middle of the inner cartridge with oil (the area where the long thin rebound tube sits). This is supposed to be dry, and when oil gets in that space it comes out the top as you describe.
Second, the rebound cap is sealed with a common O ring that can fail, although normally it is not that common of an issue. To repair this, the rebound knob has to be removed. This part is easy, at least until the two little steel balls and the spring go shooting across your garage never to be found. Point being, be careful. Once the rebound knob is off, the replacement of the o ring is straightforward. Reassemble the knob into the cap with the spring and the two steel balls and you are good to go.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 01-17-2013, 10:01 PM   #4
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,071
Johnf3 nails it in the First Place. You can replace o-rings on the cap, but it won't fix it until you drain out the extra oil in the damper tube.
"Son, you can't do both"
Old 01-18-2013, 03:51 PM   #5
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,411
it's also possible to have spun the inner cartridge, which reduces the threads available, not allowing the fork cap to seat fully, keeping the damper rod from seating, causing it to leak. dont ask how i know...
laters,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 01-18-2013, 10:19 PM   #6
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,125
Originally Posted by Johnf3 View Post
Two things:
If there is oil around the rebound tube, and the forks haven't been worked on in some time, oil could be getting past the rebound adjustment needle, it seals into the rebound tap with an o-ring. The rebound tap is steel, and sometimes gets very rusty, and eventually oil can make it's way past the o-ring.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 05-02-2013, 06:34 AM   #7
freddelito
Oddometer: 0
Do anyone know the size of that rebound adjustment knob o-ring?
freddelito is offline   Reply With Quote
Times are GMT -7.   It's 03:07 PM.
