Old 01-18-2013, 01:03 AM   #1
Rich2wd OP
Oddometer: 115
990 parked up for 6 months won't start
G'day all, I have a 2007 990 Adv low mileage 6000 km's in great condition. The bike was parked up for about 6 months while I completed a traineeship (read empty wallet, bike not registered), yesterday I went to give it a birthday with an oil change and that's when my troubles started....
The battery (factory original) was understandably dead, knackered so much so it won't charge. No worries I'll jump start from the cars battery, no good. With or without the bikes battery hooked up to the bike the car battery will not turn the 990's motor over. The tacho needle jumps at the turn of the key but when you hit the go button nothing.
I have checked all the fuses and I can turn the engine over by hand by the rear wheel with a lot of effort. I should be able to jump start the bike, correct? Where do I go from now?
Cheers Rich
Formerly Rich too_wheelz
2007 KTM 990 Adventure
2009 KTM 300 Christini AWD
Rich2wd is offline   Reply With Quote
Old 01-18-2013, 01:16 AM   #2
Eataz
Eataz's Avatar
Oddometer: 49
Have you flipped the red "killer switch" next to your throttle?
Eataz is offline   Reply With Quote
Old 01-18-2013, 01:26 AM   #3
Rich2wd OP
Oddometer: 115
Yes I did, thanks
Old 01-18-2013, 02:25 AM   #4
RB450
RB450's Avatar
Oddometer: 296
Is there a kickstand kill on these? Make sure it's in neutral.
RB450 is offline   Reply With Quote
Old 01-18-2013, 05:13 AM   #5
T-Mac
orange
T-Mac's Avatar
Oddometer: 50
Does the fuel pump make noise when you switch on the key? Red button off, Neutral on (or clutch lever pulled)?
According to the owner's manual: "Jump starts are not recommended since they can damage the motorcycle's electronic system".
KTM 1190 Adventure
T-Mac is offline   Reply With Quote
Old 01-18-2013, 08:07 AM   #6
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,962
Since you have to get a new battery start with that.
Install on bike and hook up to charger overnight to make sure it is fully topped off.
Then try starting the bike, even though you hooked it up to the car battery you might be using bad jumper cables or just dont have a good enough connections for the amperage draw of the starters need top be supplied.
Save yourself a lot of effort, start with a new battery installed in the bike then trouble shoot.
On these bike batt issues can drive you crazy.
I am going to assume you have already done all the obvious stuff regarding the gas and such if not....
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 01-18-2013, 03:36 PM   #7
NKL
Oddometer: 191
What he said.
NKL is offline   Reply With Quote
Old 01-19-2013, 02:53 AM   #8
Rich2wd OP
Oddometer: 115
Thanks fella's, I'll order a new battery which has to come all the way over from the east coast. It will take a week or so and then I'll go from there.
Cheers Rich
Old 01-19-2013, 05:49 AM   #9
Peanuts
Peanuts's Avatar
Oddometer: 1,674
You could have got a battery from a Honda dealer.....
While you are waiting, check the earth lead is clean and tight, check the connectors on the solenoid are clean and tight.
Peanuts is offline   Reply With Quote
Old 01-21-2013, 07:07 AM   #10
Rich2wd OP
Oddometer: 115
All sorted, thanks for the replies. Picked up a Power Volt Nano Gel battery today, cranks the engine up no problem at all.
Cheers Rich
Times are GMT -7.   It's 04:42 AM.
