Old 01-30-2013, 06:43 AM   #1
Deans BMW OP
Granpa Hoon
Oddometer: 3,575
HD question
My BIL has a '06 EG Classic, lives in East Texas and I have ridden it a lot in all those East Texas back roads. I have to confess that it was the most comfortable bike I have ever ridden.....but I always got the feeling of vagueness starting around 80-85 on those two lane paved back roads. The question is, re the new '13 EG Classic with the new frame, 6 speed tranny and 103 motor and I think, better brakes.
How do they compare??? Has that vagueness either disapeared or pushed to a higher speed?
What are the thoughts on the new HS's with the new frame, 6 spd and the 103?
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW screwed with this post 01-30-2013 at 07:10 AM
Deans BMW is offline   Reply With Quote
Old 01-30-2013, 07:04 AM   #2
Murf2
Oddometer: 848
Yes the handle much better! Sounds like you'd like one to me.
Murf2
Murf2 is offline   Reply With Quote
Old 01-30-2013, 08:37 AM   #3
NonDairyCreamer
incomprehensible
NonDairyCreamer's Avatar
Oddometer: 96
Night and day difference with the new chassis. But the pre '09 models can be improved with a Tru-Track or other brand stabilizer which limits the side to side motion of the power unit when cornering in long sweepers. Easy to install. The motor, primary and trans float on rubber mounts but as a unit are connected to the swingarm and that creates the problem.
And depending on the miles of the unit you rode, replacing the motor mounts (usually the front one) and the swingarm rubber isolaters with better ones, will also help handling. All of these items are easy to install but alignment should be checked when changing any of these, also easy to do.
"Which will you have: wise madness or foolish sanity?" Cervantes' Don Quixote
NonDairyCreamer is offline   Reply With Quote
Old 01-30-2013, 08:45 AM   #4
Cakeeater
Oddometer: 977
Vagueness is gone. I run my '11 road glide ultra often at 100 mph-plus when I'm in the middle of nowhere, which I often am.
It tracks solid, and true.
Even at top speed (110-115ish) it's steady. The chassis could handle much more motor.
Now, at harder corning at higher speeds (80-85) my bike will start to give a litttle gentle weave on bumps. Nothing frightening, just a hand on my shoulder saying "son, that's enough".
For example, a few months ago I went both ways on I-80 east of salt lake city...sort of a high speed set of turns going up (or down) the mountain. Traffic was moving out both times, and I was in the fast lane, but at 85 mph I wasn't wanting to go any faster down the mountain.
Cakeeater
Cakeeater is offline   Reply With Quote
Old 01-30-2013, 09:03 AM   #5
boatpuller
Oddometer: 680
Yes to what the above have said. In addition, the '06 might need the steering head bearings re-tightened, and maybe the front shock oil freshened up. Both can contribute to the feel at speed you reported. But, in general, the new frame is wonderful! Keep in mind the touring frame is not designed to be a Porsche, and will probably never have the trackability of an FJR or an LT over 100 MPH. But for reasonable speeds, it's a wonderfully comfortable motorcycle.
Sounds like you have a BMW, which is a nice motorcycle. So, thank you for your objectivity about HD's.
boatpuller is offline   Reply With Quote
Old 01-30-2013, 09:20 AM   #6
EricD10563
EricD10563's Avatar
Oddometer: 708
I've rode pre 09 Harley tourers before buying my first one and it felt like the front end and back end were not connected on the earlier models. The last one I rode was a loaner a 08 and I purposely took the same road to and from the shop to compare my 09 to the 08 and immediately I could feel the difference. The newer frame just felt tighter, sure footed and offered more feed back to the rider. I also noticed that I was scraping the road on the older model, I assume the lean angle in greater on the newer frame. There still is some "bagger wobble" on the new frame when pushed and I've experinced that on both Harley's that I've owed, usually occurs in high speed sweepers. The new frame is a vast improvement over the old frame IMHO.
In 2009 I rode 18,589 miles on an island that's 72 miles long. That's 50 miles a day everyday for 365 days. I think I'll go home now. 97k miles and still riding http://travelwithe.com/blogengine.net/ my YouTube Channel http://www.youtube.com/channel/UCTJA4CrFRY-_rvDejPct73g
EricD10563 is offline   Reply With Quote
Old 01-30-2013, 09:51 AM   #7
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
Do yourself a favor and ride the FLTRU Road Glide Ultra (with the Shark nose) before you buy. It has ABS & Security standard and provides a MUCH better Air pocket than the Bat Wing on the Ultra.
In both Head Winds and Side Winds it is a MUCH better riding bike.
The new Frame allows 1 degree left and 2 degrees right more lean than the 2008 and older bikes.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 01-30-2013, 10:04 AM   #8
Cakeeater
Oddometer: 977
Good looking bike!
Yes, as Dakez says. I tried all the HD touring models and immediately knew the Road Glide Ultra was for me. I put an aftermarket windshield on it (windvest) that lowers buffetting with a FF helmet. Terrific road bike.
Cakeeater
Old 01-30-2013, 10:26 AM   #9
jon_l
jon_l's Avatar
Oddometer: 3,458
I have sat on, but not ridden these yet. On paper the Road Glide and Road King are my favorites. I don't want music, CB, etc. I do want ABS and cruise control.
I was surprised at how small / tight the Road Glide felt sitting on it. The Road King felt roomier, and of course it is lighter, cheaper, and converts to a cruiser easily.
I am 5'11" and 225 lbs, with 30" inseam (short legs).
I'd appreciate feedback on "roominess".
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Old 01-30-2013, 10:40 AM   #10
EricD10563
EricD10563's Avatar
Oddometer: 708
I had the 96ci and now have the 103ci motor on my 2011 EG Limited and it's a nice improvement, I down shift less and it pulls harder in higher RPM's. Like my previous bike I will do a Stage One to the bike and I assume it will wake up the new motor like the old one, I still think the 103ci pulls better than my 96ci that had a stage one. I think Brembo brakes became standard in 2008 and I have no complaints with the brakes at all, the rear foot pedal takes some getting used to but it's not an issue for me, used mainly to skim some speed off or coming to a light. I like the ABS but have no experince with other makers, it would engage to early on my other bike but there was a dealer download that corrected that issue for the most part and I've not felt ABS kick in on my new bike at all yet.
Old 01-30-2013, 10:55 AM   #11
Deans BMW OP
Granpa Hoon
Oddometer: 3,575
Answering boatpullers question, yes I have several BMW's, currently a R1200S, a '10 R1200GS, a '74 R75/6, just sold my K1600GT. Also a new Husky 650 Strada.
I'll be .....hard to even think about it.......70 in March and am considering slowing down, been riding since the late '50's........... To my eyes, the Road King or the Electra Glide Classic are the only HD's I'd want and for the very shallow reason of...They look like I remember they should look. I have been a sport/touring rider for ever and am planning to slow down.......I hope.
Flipping the coin as many times as I have, one of these days it will turn up tails.
Dean O
Copperhill, Tn.
Old 01-30-2013, 11:22 AM   #12
boatpuller
Oddometer: 680
I was surprised at how small / tight the Road Glide felt sitting on it. The Road King felt roomier).
The only things that should contribute to "roominess" would be the seat, the handlebars, and the feeling of claustrophobia or openness due to the farings and windshield. The frame is the same, and the seats are all interchangeable as are most of the handlebars. Some have lower shocks than others, but I would not think that'd be a factor in "roominess".
Old 01-30-2013, 11:37 AM   #13
Cakeeater
Oddometer: 977
I've ridden far less than you...but that's a big reason I ride HD now. I tested a K1600GT. Loved it, but I'd go too fast on it, too often. I already ride my Road Glide faster than my wife likes....or knows about
Cakeeater
Old 01-30-2013, 11:45 AM   #14
Deans BMW OP
Granpa Hoon
Oddometer: 3,575
Can't tell you how much I appreciate these grown up answers, thanks guys, I have no interest in the "Pirate" look or wanabe Bad guy sillyness.
Bike is very comfortable and still has that classic look and feeling, but without the classic issues.
Dean O
Copperhill, Tn.
Old 01-30-2013, 02:04 PM   #15
royal
Don't Follow
royal's Avatar
Oddometer: 653
I thought I'd chime in here. I've had two BMW's (LT1200 and and RT1200), and most recently a 2010 Kawasaki Concours. I wanted to have a bike with the classic looks of a what I think a motorcycle should look like AND be comfortable for longer trips. So, I traded my Kawasaki in on a 2012 Electra Glide Classic.
Absolutely couldn't be happier. It's put the fun back in riding again. Comfortable, fun and looks just right. One of those kinds of bikes that after you park it and are walking away, you turn back just to look at it again. 10,000 miles on her and nary a problem. I consider myself lucky to have finally found the right bike for me.
I'm wasted and I can't find my way home....
royal is offline   Reply With Quote
Times are GMT -7.   It's 04:20 AM.
