Old 01-18-2013, 10:00 AM   #1
whitham_wannabe OP
whitham_wannabe's Avatar
Oddometer: 1,048
R100 Final drive leaking
My R100 sidecar is outside of work , all loaded up for Snow Camp, and I just noticed a bunch of fluid all over the back wheel.
It appears to be coming out of the plug on the top of the drive unit. Any clues as to what the heck is going on here? It certainly doesn't look good ...
I guess my weekend plans might be changing ....
From a WW1 RAF Flight Manual ...
"If a crash at the home airfield is inevitable, try to hit something soft and, preferably, inexpensive"
Travels With Bruce : More Travels With Bruce
whitham_wannabe is online now   Reply With Quote
Old 01-18-2013, 11:30 AM   #2
gonerydin
Oddometer: 74
You see this a lot in COLD weather. You could switch to lighter viscosity oil or... just ignore it.
gonerydin is offline   Reply With Quote
Old 01-18-2013, 12:15 PM   #3
whitham_wannabe OP
Oddometer: 1,048
Seriously? It is very cold right now, about 26 degrees riding in this morning.
I am all about ignoring problems ...
Old 01-18-2013, 01:30 PM   #4
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
When was the last time a fresh, NEW crush washer was used on the fill bolt? I'd bet a few fills ago...
*edit* just noticed it looks like the breather is puking too, you sure it's not overfilled?
I would not lower the viscosity of the gear oil, 80/90 hypoid.
You'll likely get more answers quickly if you have a mod move this to the Airheads sub-forum.
Current: 93 R100GS, 03 XR650R
Prior: 73 CB350, 77 R100/7, 83 R100RT, 04 XR650L
I love every motorcycle I've owned and even some that I haven't.
ignatz72 screwed with this post 01-18-2013 at 01:39 PM
ignatz72 is offline   Reply With Quote
Old 01-18-2013, 02:24 PM   #5
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 973
Pull the fill plug and check the level..may be down a tiny bit. Cold weather caused the heavy molassis fluid to puke until it warms up a bit.
Stay with 75-95.
Ride to warm up, clean off...ride again to make sure it's not the housing gasket.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 01-18-2013, 08:51 PM   #6
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,079
I've seen this happen numerous times when it's cold. Fill it with synthetic instead and I think that should handle it. A failing transmission output seal can cause this same symptom, but circumstances don't point that direction.
Times are GMT -7.   It's 12:11 PM.
