Old 01-18-2013, 03:32 PM   #1
everycredit OP
everycredit's Avatar
Oddometer: 272
Spider webs on windshield--can I sand them out?
I've seen minor scuffing being polished out of windshields, headlights, etc. Mine seems uglier than that.
I started with 1000 grit sand paper and wet sanded. Eventually went to 3000 grit and then polished. All it ended up doing was making my windshield look cleaner, but still had those spider web marks.
Would being more aggressive with the wet sanding (starting with 100 grit?) do any good? Or should I just replace the windshield? What are your experiences on this?
everycredit is offline   Reply With Quote
Old 01-18-2013, 03:49 PM   #2
Beezer
Oddometer: 5,945
if its "crazing" due to age or chemical attack then no.... it is too deep. your description of "spiderwebs" sounds like crazing to me... very common on older aircraft plastic.
Beezer is offline   Reply With Quote
Old 01-18-2013, 03:56 PM   #3
everycredit OP
Oddometer: 272
It's hard to photograph, but it sounds like "crazing". Alright, I'll put the $3 in sandpaper costs toward a new windshield.
Old 01-18-2013, 04:13 PM   #4
bradluke0
Oddometer: 221
Hi all ! I would try one of those kits for polishing bad headlight lenses . We used the 3M kit on our cars and they came out awesome .
bradluke0 is offline   Reply With Quote
Old 01-18-2013, 04:34 PM   #5
everycredit OP
Oddometer: 272
I tried it. Like I said, it looked cleaner, but it's still opaque.
Old 01-18-2013, 04:37 PM   #6
Yamarocket630
Honey Badger
Yamarocket630's Avatar
Oddometer: 630
Careful applications of heat can fix minor scratches and crazing in polycarbonate plastic.
http://maic.jmu.edu/journal/10.2/r&d...tz/heafitz.htm
Yamarocket630 is offline   Reply With Quote
Old 01-18-2013, 04:43 PM   #7
everycredit OP
Oddometer: 272
Where the hell did you find this?
Old 01-18-2013, 05:15 PM   #8
duck
duck's Avatar
Oddometer: 10,403
Haven't tried it myself but I've heard that the mild abrasive in toothpaste can help revive old windscreens.
duck is offline   Reply With Quote
Old 01-18-2013, 07:58 PM   #9
kantuckid
Oddometer: 3,178
go with #3
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 01-18-2013, 08:32 PM   #10
everycredit OP
Oddometer: 272
Some combination of methods above have now caused my windshield to be unusable.
This is now moot.
Old 01-18-2013, 08:34 PM   #11
Beezer
Oddometer: 5,945
acrylic can be polished back to clear.... polycarbonate on the other hand will never come all the way back.
there is a kit made by Micromesh to repair aircraft windshields that works good, but all it really is is a set of cloth sandpapers from about 800 to 8000 grit.
I have had good results doing what you did. 400 or 600 to remove scratches, then 1000, 1500 and maybe 2000. follow that with rubbing compound. I like Presta. they make 1000, 1500, 3000... etc. 1500 removes scratches left by 1500 sand paper. I use the 1000 then the 3000. finish with Plexus or Pledge
all this stuff can be had from a real autobody paint store
I would try a small spot to see if you can get all the spiderwebs out. if it works then do a bigger area
edit: oooop... looks like I'm too late. ah well I'll leave the post anyway because the stuff listed works
Old 01-18-2013, 09:05 PM   #12
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,521
So long as you do not look through it, one solution to pretty it up is to simply paint it. I did this on my 1100GS and it looked pretty good.
For actual scratches and gouges, sanding can work wonders:
http://www.advrider.com/forums/showthread.php?t=853435
From this:
To this:
In about 20 minutes.
Jim
JimVonBaden screwed with this post 01-19-2013 at 03:12 PM
JimVonBaden is online now   Reply With Quote
Old 01-18-2013, 09:15 PM   #13
everycredit OP
Oddometer: 272
For actualy scratches and gouges, sanding can work wonders:
From this:
To this:
Jim
Eh, oh well. Mine already caught on fire.
Old 01-18-2013, 10:47 PM   #14
Fictitious
Fictitious's Avatar
Oddometer: 203
Originally Posted by everycredit View Post
eh, oh well. Mine already caught on fire.
pics or it didn't happen! :p
Stuff, as well as things
Fictitious is offline   Reply With Quote
Old 01-19-2013, 04:41 PM   #15
everycredit OP
Oddometer: 272
It didn't flame up, but it was burned enough to say "f it"!
Times are GMT -7.   It's 08:34 AM.
