Old 01-18-2013, 06:16 PM   #1
go2cnavy OP
go2cnavy's Avatar
Oddometer: 520
DIY Rotopax Pannier Mounts
Rotopax Pack Mount
12" Brace (x2)
U-bolt w/ nuts (x2)
Bolt,washer(s), nut (x2)
Total = Less than $10.00
I was trying to figure out a way to mount my Rotopax cans under my Wolfman soft bags. I have HB pannier racks and didn't want to spend $225 per side for the Kreiga ADV mount (which is awesome and if I had the money they would be on the bike). But after spending buttloads of money on the 990 over the last few months, I decided to go the way of KLR riders...cheap.
Step one - Determing where your hardware will line up on the rack and drill appropriate holes. I used a 12" brace that was pre-drilled and only had to add two holes for the u-bolt.
Step two - Use a template for the Rotopax mount holes. I used my CJ rack, but you can also use the base mount that comes with the Rotopax mount.
Step three - mount all the pieces finger tight and adjust alignment. Then tighten everything up.
Step four - mount cans and soft luggage.
Step five - crash test
╭∩╮(-_-)╭∩╮
990A / 450 EXC R/ 250 EXC/ 450R - for sale
go2cnavy is offline   Reply With Quote
Old 01-18-2013, 06:19 PM   #2
Nnordsman
Nnordsman
Oddometer: 329
Nice work. I have been thinking about how to that.
Nnordsman is offline   Reply With Quote
Old 01-18-2013, 06:29 PM   #3
ThumperStorm
ThumperStorm's Avatar
Oddometer: 1,118
Thumb
Nice and simple, I like it.
"Maybe you ain't in a rut, maybe you're in a ditch, way over your head." Don Marshall
ThumperStorm is offline   Reply With Quote
Old 01-18-2013, 10:31 PM   #4
Snowbound
Oddometer: 877
I had a 3 " wide piece of steel welded to my Givi rack . The Wolfman EXP bags fit on top . I am hoping that the steel will be more durable than an aluminum mount .
BMWMOA
ABC
Pikes Peak BMW Riders
2001 R 1150 GS 1978 R 100RS 1976 XT-500 1964 CL-72
1955 CJ-5 1975 F-250 Highboy
Snowbound is offline   Reply With Quote
Old 01-24-2013, 09:13 AM   #5
robdogg
turnip truck driver
robdogg's Avatar
Oddometer: 1,755
nicely done.. trying to do something similar with my Jesse racks for when I don't want to use the hard cases.. since that strip of metal is only secured at top and bottom how much does it flex? particularly when the rotopax are full.. that would be a concern as it could weaken the strap over time, or cause the mounting bolts/nuts to loosen?
"ride hard, live righteously"
'04 1150 GS "Ich bin ein Berliner"
'12 KTM 690 - Austrian Ferrari
robdogg is offline   Reply With Quote
Old 01-24-2013, 06:15 PM   #6
go2cnavy OP
go2cnavy's Avatar
Oddometer: 520
Does not flex at all. It's 3/8" steel.
╭∩╮(-_-)╭∩╮
Times are GMT -7.   It's 05:53 AM.
