Old 01-19-2013, 08:25 AM   #16
Tucos
Tucos's Avatar
Oddometer: 304
I have Wolfman racks made by backroads moto and the expedition soft bags, and pelican storm hard cases. I like the expedition cases for heavy off road use but if you are in and out of the bags a lot, it becomes a pain in the butt. I used the pelicans for a trip to copper canyon and was much happier due to ease of access to documents, etc. I also only packed about half of each case and was able to fit my jacket and pants in them, locked up, when eating or whatever. I had an encounter with a log that ripped one of the pelicans off of the rack. The mounting setup for the hard cases bent, as designed, and saved the rack and cases from any damage. Berg Briggs from backroads moto sent me a couple new easy to change pieces and I was back to like new condition. On the copper canyon trip, my buddy on a GS with Jessie's, had a tumble. The aluminum bent and one side would not close and the other had a hole ground into it. I am not saying that wouldn't happen with the pelicans but I hit that afformentioned log pretty hard and the case was still square. Good luck with your choice there are a ton of good products.
Tucos is offline   Reply With Quote
Old 01-19-2013, 08:39 AM   #17
PNWcrazymike
PNWcrazymike's Avatar
Location: Bend, Oregon (in the sunny half of the state)
Oddometer: 14
Neither
If you're sticking to asphalt and ravel roads, please disregard my opinion.
If you DO plan on riding off road, especially rough roads that are seasonally washed out with ruts and exposed rocks or deeper sand, I don't recommend any kind of "hard bags" because when you have both feet down "paddling" the bike through said rough sections, inevitably on leg will get sucked under a hard bag and although it may not be broken, you'll swear that you just broke your leg. I remember this all too well from my GS days so my current ADV bike is getting "soft bags."
Again, if you're sticking to asphalt (no pun intended) your hard bags will be out of the way and not an issue.
-Mike
PNWcrazymike is offline   Reply With Quote
Old 01-19-2013, 08:56 AM   #18
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 7,847
The Gobis seemed too wide for me, so I used KTM pannier & Gobi tail box racks and made mounts for my aluminum mermites -
I would have bought aluminum panniers if I didn't already own these, and I'll be buying a set of Wolfman Expedition Saddle Bags soon.
LC8World.com - KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo screwed with this post 01-19-2013 at 09:27 AM
Hondo is offline   Reply With Quote
Old 01-19-2013, 09:28 AM   #19
ÖÖ.
ÖÖ.'s Avatar
Oddometer: 139
-Mike
I agree. Different panniers for different kind of riding. As said before soft bags are lighter and usually smaller than hard bags. Good things if you are really riding off road far away from any civilization. With hard bags fully loaded it's easy to get near the stated maximum load capacity.
Riding "high speed" gravel / tarmac inside civilized world you may need to consider more about protecting your items inside the panniers than the ultimate bike lightness and survivability. Also if your crashing with speed usually your bike starts sliding around. Grinding everything that touches the ground. Maybe hard bags are better in these kind of situations. While in off road crashes seem to be hard hits, usually without any sliding. In those kind of situations soft bags may be better for the bike but maybe not for the items inside.
To original topic. First I had alu-panniers. They were easy to pack, had plenty of room and where quite light. I had few light off road style crashes with those, no problems. Only few bends. Problem was they where too wide and had even too much space for riding alone.
I changed for pelican 1550 cases. They are not so easy to pack and they are a bit heavy. They are a lot narrower so its easier to drive in narrow tracks. I have had few crashes with them. Off road ones left only few scratches. Crash on racetrack grinded left case a bit but lid still closes perfectly and it's watertight.
My sw-motech quick lock racks are getting more difficult to install/remove after every summer. Maybe some day I have to get new ones.
Pics and vids
ÖÖ. is online now   Reply With Quote
Old 01-19-2013, 12:01 PM   #20
Dogtown
Dogtown's Avatar
Oddometer: 397
boxes!
Ive had all of them!
Soft bags only carry enough for an overnight.
Gobies are tooooo wide (for me)
Aluminums are a bit too fragile for "get offs"
Happy with pelicans! Home made mounts on KTM/Gobi racks LOVE THEM!!!!
OH 7 990
Marin County To Cabo!
Dogtown is offline   Reply With Quote
Old 01-19-2013, 12:36 PM   #21
Lorretto
City Dweller Crushperado
Lorretto's Avatar
Oddometer: 285
FWIW the 41L KTM branded Tourtech panniers will just barely hold a Medium or Large full face helmet [10.5 inches wide]. The lip at the top of the bag is narrower than the body; just guessing about 0.25 inches on each side but I haven't measured it. The downside is they are much wider than the bars. The 41L bags are about the same total width as the Gobis but with more storage capacity. I doubt the 35L Alu panniers [9 inches wide] will hold a FF helmet if that is important to you.
Lorretto is offline   Reply With Quote
Old 01-19-2013, 01:53 PM   #22
GLRRA47
Oddometer: 29
I like my Jessie boxes.
GLRRA47 is offline   Reply With Quote
Old 01-19-2013, 04:42 PM   #23
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 959
Send a message via Skype™ to ciedema
I have Gobi's, but after seeing the Jesses in the flesh I wish I had them, much better. More space, about the same weight, stronger and aren't any wider than the bar ends. Also are stronger than the Touratech ones.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
No Four Wheel Drives, No Fixers and No Fricken Whingers
Personal Attacks - the last refuge of the intellectually impaired.
ciedema is online now   Reply With Quote
Old 01-19-2013, 11:13 PM   #24
Gimme 2
Team slo ass
Gimme 2's Avatar
Oddometer: 1,674
Had both
Had aluminium ones then sold em and got gobis , get alu, much better. the water carrying gimic is just that, it's a PITA.
Just be sure to get a cable lanyard attached to your lids, cause if you lose one it's big bucks, trust me on that one.
Give it WOT.
Gimme 2 is offline   Reply With Quote
Old 01-20-2013, 08:34 AM   #25
GLRRA47
Oddometer: 29
Good customer service with Jessie panniers. Only thing I needed to follow-up with, was applying silicon sealant to and around all the fastner pass through points to ensure no seepage in the rain.
Old 01-20-2013, 08:50 AM   #26
Av8rPaul
Av8rPaul's Avatar
Oddometer: 238
My Gobi's measured right at 42" wide. Has anybody thrown a tape on the other options mentioned here for comparison purposes?
Paul
2004 KTM 950 Adventure - sold
IBA #33
Av8rPaul is offline   Reply With Quote
Old 01-20-2013, 12:04 PM   #27
Wantajustride
Wantajustride's Avatar
Oddometer: 88
Wish I could post a photo of the Kriega/RotopaX set up,,,, (no photo bucket account, too cheap)
With the bags stuffed full of gear they measure 36" wide using the factory KTM mounts.
2012 KTM 690 R
2012 Yamaha Super Tenere
2012 KTM 990R Adventure
"Walking thru life to an unknown destination and trying to enjoy the adventure getting there"
Wantajustride is offline   Reply With Quote
Old 01-20-2013, 12:48 PM   #28
Av8rPaul
Av8rPaul's Avatar
Oddometer: 238
Photobucket is free, at least for me!
Paul
IBA #33
Old 01-20-2013, 01:41 PM   #29
BarkSlayer
BarkSlayer's Avatar
Oddometer: 331
I wish KTM would offer the plastic bags without the 3 liter water jackets molded into the sidewalls. A small plastic (disposable) bottle of water in the tank bag has worked great for me. The extra storage space in each bag would be much more practical.
2007 BMW R1200GS
2009 KTM 300 XCW
"If guns cause crime, then all of mine are defective." Ted Nugent
BarkSlayer is offline   Reply With Quote
Old 01-20-2013, 02:04 PM   #30
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,152
There is a thread full of photos in the Vendors section.
traveltoad is offline   Reply With Quote
Times are GMT -7.   It's 03:37 PM.
