Old 01-18-2013, 06:40 PM   #1
go2cnavy OP
go2cnavy's Avatar
Oddometer: 518
DIY Pelican Case Mount
Intent: Easy on/off without removing rack and secure.
Items needed:
Pelican case
Clevis pins with locking pins (x2)
Rubber o-rings (x4)
Washers
Step one - use your top rack as a template to drill holes. Check desired depth of Clevis pins and cut to size. This will allow you to come from underneath your rack to install without having to remove the rack from the bike. It also prevents would-be dirtbags from taking your stuff.
Step two - reinstall rack and mount the pelican case. The rubber o-rings will allow the Clevis Bolts to stay in position while mounting. Use the second pair of o-rings, washers, and locking pins on the interior to get the desired snugness.
╭∩╮(-_-)╭∩╮
990A / 450 EXC R/ 250 EXC/ 450R - for sale
go2cnavy is offline   Reply With Quote
Old 01-20-2013, 03:25 PM   #2
Boats313
Boats313's Avatar
Oddometer: 35
Sorry, there is no way it is that easy or inexpensive. A proper motorcycle accessory costs at least 8% of the bikes value and/or takes 37 man hours of labor to do it yourself.
Looks good, I was thinking of something similar for a larger box, using 4 pins. I was worried about the pins sticking too far into the box.
Boats313 is offline   Reply With Quote
Old 01-20-2013, 04:11 PM   #3
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 4,203
Nice install...
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 01-20-2013, 05:32 PM   #4
steve_k
steve_k's Avatar
Oddometer: 1,062
Clean work!
steve_k is offline   Reply With Quote
Old 01-20-2013, 05:49 PM   #5
ilbiker
Oddometer: 143
That looks simple enough. Thanks
I don't suffer from insanity, everyone else around me does...
ilbiker is offline   Reply With Quote
Old 01-20-2013, 06:52 PM   #6
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,562
Nice.
Flashmo is offline   Reply With Quote
Old 01-20-2013, 11:12 PM   #7
GillT
GillT's Avatar
Oddometer: 141
If you dont mind, what model/size case is it that you used?? I'm in the market for one and trying to find happy medium between storage and size of the case.
GillT is offline   Reply With Quote
Old 01-20-2013, 11:37 PM   #8
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,294
You could always use a set of these to eliminate the pins intruding into the box.
http://www.mcmaster.com/#standard-sp...e-pins/=l4lacz
tbarstow is offline   Reply With Quote
Old 01-21-2013, 06:20 AM   #9
jules083
jules083's Avatar
Oddometer: 3,539
I like it. May have to steal that idea on my KLR.
That pelican case looks tiny on the back of your 990. I know it's not, just the rest of the bike makes it look that way.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 01-21-2013, 07:28 AM   #10
go2cnavy OP
go2cnavy's Avatar
Oddometer: 518
It's a 1400. Kinda small, but perfect for electronics, passport, etc. Didn't want too big of a box.
It is small, but I didn't want something large. I have enough storage else where. The Pelican 1400 is large enough to store a Warn x17, air pump, extra gps, and cell phone. It also gives my son a better sense of security with something behind him as we ride, whereas before the big HB top case was enormous.
╭∩╮(-_-)╭∩╮
Old 01-22-2013, 06:05 PM   #11
Mr.Z
Oddometer: 12
Got to ask, how stable is it with just the 2 pins holding it down?. I have the same case and was also thinking of ways to mount it. Might just use 4 pins for that added stibility.
Brilliant Idea BTW!
Mr.Z is offline   Reply With Quote
Old 01-22-2013, 07:32 PM   #12
go2cnavy OP
go2cnavy's Avatar
Oddometer: 518
Brilliant Idea BTW!
At first it wobbled a little because it wasn't tight enough; the location of the pin holes relative to the inside surface of the case didn't allow the washers to provide enough force to really seat the case against the tail rack. To solve this, I simply doubled up the washers - it worked like a champ!
╭∩╮(-_-)╭∩╮
Times are GMT -7.   It's 05:31 AM.
