Old 06-03-2013, 03:32 PM   #1
TheCowboy OP
back in the saddle again
TheCowboy's Avatar
Oddometer: 606
Tire will not seat
I've changed a lot of tires. I got a TKC80 that will not " pop" while trying to seat it. I've checked rim and tire for obstructions. Any ideas?
TheCowboy is offline   Reply With Quote
Old 06-03-2013, 03:42 PM   #2
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,613
I've heard of those tires being harder to seat, but couldn't find those posts - instead I found http://gl1800riders.com/forums/showt...-Seal-Non-Wing that has quite a few suggestions (along with sending it back for a replacement)
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 06-03-2013, 03:43 PM   #3
showkey
Oddometer: 1,955
MORE lube, better lube...............can't have too much.
How much air pressure have you applied?
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 06-03-2013, 04:05 PM   #4
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,740
Originally Posted by showkey View Post
more lube, better lube...............can't have too much.
+1
traveltoad is offline   Reply With Quote
Old 06-03-2013, 04:08 PM   #5
JR356
JR356's Avatar
Oddometer: 3,893
As prior poster said,LUBE the rim and tire.
Also you did pull out the valve core before attempting to inflate?,if not then do so,as you will not have enough air flow to seat the bead.
JR356
JR356 is offline   Reply With Quote
Old 06-03-2013, 04:12 PM   #6
some call me...tim
some call me...tim's Avatar
Oddometer: 279
I had a hell of a time trying to get a front tire to seat recently. What finally seemed to do the trick was inflate it to ~50 psi, give it a good bounce or two with lube on the bead, and then rode around on it a bit with the pressure still high. It seemed like the bounce with the high pressure was the real catalyst though.
some call me...tim is offline   Reply With Quote
Old 06-03-2013, 04:24 PM   #7
MrPulldown
MrPulldown's Avatar
Oddometer: 3,339
How clean is the rim. Seems there is often rubber build up on the rim that could cuase it to be sticky.
MrPulldown is offline   Reply With Quote
Old 06-03-2013, 05:02 PM   #8
duck
duck's Avatar
Oddometer: 10,403
A ratcheted tie-down around the perimeter may help push the sidewalls out closer to the bead.
duck is offline   Reply With Quote
Old 06-03-2013, 05:07 PM   #9
mwood7800
Oddometer: 611
What's wrong with starting fluid?
mwood7800 is offline   Reply With Quote
Old 06-03-2013, 05:17 PM   #10
joexr
Oddometer: 3,773
I've gone to 100 PSI with tires and ridden them around the block a couple of times to get them to seat. I was skeptical the first time myself years ago doing this at a large reputable dealer.
Old 06-03-2013, 05:23 PM   #11
Oldschoolorange
Oddometer: 52
Clean bead, clean rim, lots of lube, lots of swearing.
Oldschoolorange is offline   Reply With Quote
Old 06-03-2013, 05:45 PM   #12
jdrocks
Gravel Runner
Oddometer: 4,477
mounted plenty of TKCs, and i've always thought that those were some of the easier ones. helps to have a warm tire.
jdrocks is online now   Reply With Quote
Old 06-03-2013, 07:26 PM   #13
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,616
This.
Flashmo is offline   Reply With Quote
Old 06-03-2013, 07:31 PM   #14
Cutsit
Cutsit's Avatar
Oddometer: 356
This works for me.
Also can use a shot of ether if need be. Be careful with that though.
Google is my friend! (so is Round-up)
Always mindfull of obstructions, do your duty never fail. Keep your hands upon the throttle and your eyes upon the rail.
Never be arrogant.
Don't waste ammunition.
Whiskey makes you think you're smarter than you are.
Always, always make sure you know who has the power.
Don't mess with old men, they didn't get old by being stupid.
Cutsit is offline   Reply With Quote
Old 06-03-2013, 08:28 PM   #15
TheCowboy OP
TheCowboy's Avatar
Oddometer: 606
All great ideas... But I already done them (except send tire back). Still will not seat...
Times are GMT -7.   It's 10:46 AM.
