Old 01-17-2013, 04:44 PM   #1
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,433
Q about speedo pickup
I wore my speedo pickup wires threw last summer. Rode without a speedo for some time. I recently resoldered the wires and added a bit more preventative heat shrink and tied them back so hopefully this does not happen again. well I took a rip and speedo just reads 0 I trust my splice so started poking around and I cant find a magnet in the brake rotor. I took a look at a parts schematic and no magnet there either.
Anyone know what signals the sensor that the wheel has made a rotation?
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 01-17-2013, 04:53 PM   #2
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,964
the rotor bolt heads
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 01-17-2013, 04:58 PM   #3
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,024
The speedO sensor picks up the brake rotor bolts.
Same as the 990S and other non ABS LC8's
Check clearance between the sensor and rotor bolts.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 01-17-2013, 05:57 PM   #4
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,748
When I got rid of the ABS I had to replace my pickup with the one used on the 950.
I don't know but maybe it is possible your splice might have added too much resistance to the wire for the pickup to work.
Also check the clearance of the pickup to bolt heads like other said. I think there is some wiggle room when installing it that will change that gap.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 01-18-2013, 10:05 AM   #5
Off Road Ryder OP
Oddometer: 2,433
Thanks guys.That helps a lot. I need that speedo, you know how thirsty these things are.
1-800-624-0278
Old 01-18-2013, 05:07 PM   #6
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,695
When mine failed like this (a common problem) I soldered it back together like you did only to find that the overall wire was old and fragile and broke again right away. Ended up having to replace it.
Edit- new cable costs $66.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 01-19-2013, 10:35 AM   #7
Off Road Ryder OP
Oddometer: 2,433
Thats where Im leaning. Those wires take a lot of abuse
1-800-624-0278
Times are GMT -7.   It's 03:33 AM.
