Old 01-19-2013, 08:36 AM   #1
AlanCT OP
The Byronic Man
AlanCT's Avatar
Oddometer: 3,679
Another oil furnace question
Hi,
So apparently when we had our furnace serviced a month ago, the repair man left the fuel petcock for one of our two oil tanks in the off position. As a result, the furnace ran dry after using the oil up in one tank. Normally, it draws from both tanks at once.
Today, I got an oil delivery, bled the air out of the line and now the furnace is up and running.
However, the oil delivery we got filled one tank, but didn't cross over to the other. Normally the two tanks balance when filled, because they have a common fill pipe, and the furnace draws oil from both. What's the deal? How come the oil isn't balancing between the two tanks? How do I get it back to normal?
I dont know if it was necessary, but I shut the petcock off for the empty one so it doesn't suck more air.
"You wouldn't be riding a motorcycle if you weren't an optimist."
- Matthew Crawford
2005 Ural Tourist, 2000 Kawasaki W650
IBA #23064
AlanCT is offline   Reply With Quote
Old 01-19-2013, 09:33 AM   #2
AlanCT OP
The Byronic Man
AlanCT's Avatar
Oddometer: 3,679
Okay, it seems like they are starting to equalize, just very, very slowly.
- Matthew Crawford
IBA #23064
Old 01-19-2013, 10:07 AM   #3
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,429
Observed that same thing at my buddies house, I was checking on it for him while he was away all winter on vaca. Didn't equalize, then finally did. This is a GREAT reason to follow accepted service procedure and BLOW OUT THE LINES periodically. I'm guilty of not doing it enough... S L U D G E
Old 01-20-2013, 09:09 AM   #4
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 9,040
I wonder if a half barrel of bio diesel would clean things up... Just make sure you have a couple of new fuel filters on hand.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 01-20-2013, 01:26 PM   #5
DC2wheels
Castle Anthrax troll
DC2wheels's Avatar
Oddometer: 2,778
I run the furnace at my office on kerosene.
Pricey? Sure. But my tank is outside- so no winter problems. And the furnace, tank and lines stay CLEAN.
More $$ but cheaper long term? Maybe. Plus less worries.
John (sugarhillctd on the world-wide K11OG forum)
'92 K100RS + '12 DRZ400
DC2wheels is offline   Reply With Quote
Old 01-20-2013, 03:26 PM   #6
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,429
It's real easy... turn off emergency switch, disconnect both ends of the fuel line, stick one end in a gallon jug, blast it from the other end with compressed air, reconnect line, connect catch hose and open bleeder, turn on switch run till clear fuel, close bleeder. Repeat every two years.
Old 01-20-2013, 07:41 PM   #7
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,355
How much is K1 in NH? I have a Monitor 30 in my garage, and it's getting hard to find K1 in CT. I paid $5 a gallon at a fuel dealer, which beats the $10 a gallon at Home Despot.
HapHazard is offline   Reply With Quote
Old 01-21-2013, 08:54 AM   #8
DC2wheels
DC2wheels's Avatar
Oddometer: 2,778
We are just over $4/gallon.
Old 01-22-2013, 07:21 AM   #9
Lorretto
City Dweller Crushperado
Lorretto's Avatar
Oddometer: 345
A lifetime ago I delivered #2 heating oil. If the tanks aren't equalizing you usually have a vent problem. With a common fill, there should be two vents. If the second tank isn't venting or venting really slow, the delivery driver is hearing the first vent close and shuts down the pump thinking they [both tanks] are full. As mentioned, sludge can be a problem but since the tanks feed the system to empty it could cause the slow equalization but not the false full.
First your oil delivery company will probably check the vents for free as they want to sell you oil and it is easier for them to drop 500 gallons twice a season than 250 four times.
Generally next to the fill pipe are the vent lines. Pull the covers and see if critters have taken up residence in the vent, if so, clear and you're done.
Lorretto is offline   Reply With Quote
Old 01-22-2013, 07:56 AM   #10
spafxer
spafxer's Avatar
Oddometer: 2,651
Being that I'm from California and have only heated with natural gas...............
AND, being this is ADV and all............................................... ....................
I'm going to take a wild guess............................................. ......................
YOUR FURNACE IS TELLING YOU IT'S TIME TO CHANGE TO SYNTHETIC FURNACE OIL!!!!!
spafxer is offline   Reply With Quote
Old 01-22-2013, 01:42 PM   #11
ttpete
Rectum Non Bustibus
Oddometer: 6,149
Why does the East coast heat with oil? We've had natural gas here for 60 years or better. Are there no pipelines in New England?
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 01-23-2013, 04:25 PM   #12
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,429
The road I live on is 350 years old, nothing but rock and clay down there. We have natural gas in the cities... but rural areas not so much.
Old 01-23-2013, 04:26 PM   #13
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,429
LOL and at $12 a QUART, I'll sleep better knowing the $100 Sundstrand pump will last 300,000 miles!
Old 01-23-2013, 05:12 PM   #14
TeneRay
2>4
TeneRay's Avatar
Oddometer: 2,200
I don't understand how people here still have oil burning furnaces, either. I'm in this shitty rental for another week but have refused to fill up the 300 gallon tank with $4/gal kerosene (yeah, gasoline drops but not kero).
I tried earlier in the season just to see what the rate of consumption was. Yeah, I went through 10 gallons in 3 days keeping the house at 70F. Since then, I just purchased one of those small convection burners and seek shelter in the bedroom. It's 20ish outside and about 45 in the rest of the house.
Seriously, two seasons of filling up that tank will literally pay for a new heat pump system and pay itself off in no time.
TeneRay is offline   Reply With Quote
Old 01-23-2013, 10:36 PM   #15
1greenmachine
Oddometer: 822
I was talking with a HVAC guy and the waste oil subject came up and its mainly the old people that insist on fixing that old ineffient oil burner and forget trying to sell them a newer propane unit. I've got a 1699 sgft ranch that cost me 160 to heat last month and would hate to pay for waste oil
1greenmachine is offline   Reply With Quote
Times are GMT -7.   It's 01:48 AM.
