Old 01-19-2013, 12:33 PM   #1
35xj OP
Oddometer: 911
Stranded on the road, need help
Almost in Huntsville, al
04 950. 34 k on it. Faccet do. Recent valve check.
Bike is behaving like its running out of fuel sporadically
Doesn't sputter or die, but stutters and looses power
Idles fine, runs well at low speed, won't run well above 50
Continuously.
Bypassed fp made no difference.
N
Red some help on what is wrong
Help please!
35xj is offline   Reply With Quote
Old 01-19-2013, 01:01 PM   #2
Dru
Hardly an Adventurer
Dru's Avatar
Oddometer: 568
Check the fuel filter for clogging? Vapour lock?
Dru is offline   Reply With Quote
Old 01-19-2013, 01:21 PM   #3
Dusty
Dusty's Avatar
Oddometer: 1,296
Vent lines for the carbs?
If the canisterectomy was done the 2 bowl vents need to be through the bottom of the air box between the cylinders. Out of turbulent air.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 01-19-2013, 02:07 PM   #4
scruffy
Oddometer: 222
+1 I did the valves on mine and left the vent hose out to open air and same symptoms, rerouted the vent hose back between the cylinders fixed it.
scruffy is offline   Reply With Quote
Old 01-19-2013, 02:50 PM   #5
jclark83
jclark83's Avatar
Oddometer: 373
Could be a split carb diaphragm.
1992 Bmw R100GS
2002 Bmw R1150GS
2008 Bmw K1200LT
jclark83 is offline   Reply With Quote
Old 01-19-2013, 03:16 PM   #6
booger1
booger1's Avatar
Oddometer: 876
Hows the air filter? Happened to me once on my zx9r, I put too much oil on the K&N filter. Ran fine on the bottem end but was terrible on the top end. The shop that I took it to had a real good laugh.
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is offline   Reply With Quote
Old 01-19-2013, 05:42 PM   #7
35xj OP
Oddometer: 911
air filter is good, vent hoses are kinda in the area of air flow. ill move them tomorow.
tell me more about the split carb diaphram?
Old 01-19-2013, 05:55 PM   #8
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,836
It has to be some kind of vacuum lock. The fp can't pump enough fuel to the carbs against a suction. When you put it back together you may have pinched a vent hose.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 01-19-2013, 06:16 PM   #9
35xj OP
Oddometer: 911
plan to tear into it tonmorow morning. the problem is strangely sporadic, the bike will run well for a while, although generally feels down on power, kinda feels like a miss possibly?
plan tomorow is to take it back apart, pull the carbs and look it iver. check carb boots, plugs,coils, etc
bike is also running a higher than normal idle (2K) or so, lots of popping backfiring. Temps are fine, no obvious leaks etc
Old 01-19-2013, 06:29 PM   #10
jclark83
jclark83's Avatar
Oddometer: 373
Carb diaphragm
The throttle cables open the butterflies on the carbs. The black slides that carry the needles are operated by vacuum via the diaphragms. They are located under the black covers on the ends of the carbs. With age they develop cracks that cause a vacuum leak, causing the black slide to not fully open. If your problem didn't start immediately after service work this is where I would look. I had a similar issue and found one of mine split. If you have a split diaphragm I would replace both of them. Good luck and keep us posted on what you find out.
1992 Bmw R100GS
2002 Bmw R1150GS
2008 Bmw K1200LT
Old 01-19-2013, 06:48 PM   #11
35xj OP
Oddometer: 911
the problem did start within 100 miles of service, leads me to hope/believe its something stupid i did.
Its wierd, because the problem has become much more prevalent as the day has gone on. the bike is now running high idle and popping like crazy.
Old 01-19-2013, 07:04 PM   #12
jclark83
jclark83's Avatar
Oddometer: 373
Maybe you didn't get your carbs fully seated in the boots and one of them has come out of the boot? High idle and popping points to a vacuum leak or fuel supply problem.
1992 Bmw R100GS
2002 Bmw R1150GS
2008 Bmw K1200LT
Old 01-19-2013, 07:21 PM   #13
Katoom119
Katoom119's Avatar
Oddometer: 1,836
Originally Posted by jclark83 View Post
maybe you didn't get your carbs fully seated in the boots and one of them has come out of the boot? High idle and popping points to a vacuum leak or fuel supply problem.
+1
Old 01-19-2013, 07:48 PM   #14
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,458
Check carb boots, vent/vacuum lines. Sounds like something simple missed during service.
“Men marry women with the hope they will never change. Women marry men with the hope they will change. Invariably they are both disappointed.”
― Albert Einstein
dlrides is offline   Reply With Quote
Old 01-20-2013, 11:13 AM   #15
Dustodust
Dustodust's Avatar
Oddometer: 886
+2
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Times are GMT -7.   It's 05:56 PM.
