Old 01-20-2013, 09:06 PM   #31
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,946
Originally Posted by BELSTAFF View Post
I know this is way to simple but check the position of the ON/OFF KILL switch----- HEY it's happened before---- Don't ask
But it would it turn over then?
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 01-20-2013, 10:42 PM   #32
DuctTape
Oddometer: 351
Naw, as a matter of fact if you hit that switch the lights on the dash won't even come on and you'll think you have a dead battery.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 01-21-2013, 12:10 AM   #33
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 666
Bluhduh
Opps duh: I somehow read stator as starter, sorry
HeatXfer is offline   Reply With Quote
Old 01-21-2013, 12:38 AM   #34
achile
achile's Avatar
Oddometer: 289
Bump!
Ok, rewind... Please state the simptoms and what was rulled out. It's simpler to keep track
achile is offline   Reply With Quote
Old 01-21-2013, 03:58 AM   #35
Cyath OP
Impetulant Ignoramus
Cyath's Avatar
Oddometer: 431
@achile
Turn the key and it everything lights up as it should.
Battery fully charged and being tended.
Fuel pump and ABS whir on key on. Every fuse has been checked and tested. All good.
Hit the starter and it cranks and cranks, but won't catch fire.
It's not fuel. I've run out of gas before and I know what that's like, the bike won't crank if its not getting gas.
Pulled the plug and looked at the electrodes as the bike was cranking. Where you'd expect to see a spark, there isn't.
Whatever died and is not sending current to the spark plugs, it happened as the bike was parked while I was at work.
Yes, I did entertain the idea that some asshat decided to fuck with it, but I've , gone over it carefully and I can't find a cut wire or empty connector anywhere.
Looks like I've got to bite the bullet and take it in.
Appreciate all the ideas guys.
"You think I can remember what you posted a year ago? I can't remember what kind of beer I drank for breakfast." -SScratch
'10 KTM 990 Adventure aka The Spork
Cyath is offline   Reply With Quote
Old 01-21-2013, 04:30 AM   #36
achile
achile's Avatar
Oddometer: 289
Diagram??
Do you have an electric diagram in full color and high resolution? My dad's an electrical engineer. I can ask him to take a look.
Old 01-21-2013, 04:59 AM   #37
-Macca-
Oddometer: 79
The bit in bold isn't something I'd normally expect to read/hear (but maybe you just talk/type different to me ), so I'm going to ask anyway:
Is the spark plug earthed while you're cranking?
I couldn't find anything posted earlier to confirm it..
-Macca- is offline   Reply With Quote
Old 01-21-2013, 05:09 AM   #38
Chewy750
Chewy750's Avatar
Oddometer: 35
+1 on the earthing.
Chewy750 is offline   Reply With Quote
Old 01-21-2013, 05:27 AM   #39
achile
achile's Avatar
Oddometer: 289
grab the plug, hold on to the cylinder head and give'er a turn! That's how you make shure it gets juice.
Old 01-21-2013, 05:44 AM   #40
Wantajustride
Wantajustride's Avatar
Oddometer: 105
Cyath,
It looks like a lot of bases have been covered here. I do wonder about the "Lack Of Spark"?
Meaning,, that the contact end is a good ways up inside the boot, Did you use a screw driver or something like it stuck up inside the plug wire, then try to go to ground to see that spark is present?
I'm not questioning your mechanical skill but sometimes it the simplest things that get overlooked.
WJR
2012 KTM 690 R
2012 KTM 990R Adventure
2014 BMW GSAW
"Walking thru life to an unknown destination and trying to enjoy the adventure getting there"
Wantajustride is offline   Reply With Quote
Old 01-21-2013, 11:16 AM   #41
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,338
@achile
Maybe we're using different definitions of the same word, but fuel should have nothing to do with whether it cranks or not. The electric starter motor is what cranks the engine.
As others have mentioned, make sure you're properly checking the plugs for spark.
After a lot of cranking, pull the plugs and see if they're wet/smell like fuel. I still kinda think fuel is the issue here. I only say this because you just had part of your fuel delivery system worked on.
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is offline   Reply With Quote
Old 01-21-2013, 11:26 AM   #42
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
Yeah, once he determines that it sparks...ground the plug!...the old spray a little carb cleaner/ether/atomized fuel into the airbox trick will tell you its a fuel system problem.
My moneys still on a burnt up sensor or ecu.
Sporting Wood is offline   Reply With Quote
Old 01-21-2013, 12:26 PM   #43
achile
achile's Avatar
Oddometer: 289
In Romania, we use an old sock. We soak it with gas and put it in front of the airbox intake
Old 01-21-2013, 12:44 PM   #44
Tha Rick
Shake and bake!
Tha Rick's Avatar
Oddometer: 5,345
Have you tried reconnecting all the connection's? From the battery terminal to the light socket's? not just visually check, but disconnect and reconnect.
The light socket's are a bit much, but you get the idea- TPS sensor, EGU, MAS, etc...
And a dab of dielectric grease.
Happy Trails Y'all.
It's not about tha bike nor tha ride; it's about tha adventure in life we all seek. Great memories are made of taking tha trail less traveled and explored.
Tha Rick is offline   Reply With Quote
Old 01-21-2013, 01:55 PM   #45
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
Connect it vvith the tuneecu. Maybe it ill shovv something.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Times are GMT -7.   It's 02:44 PM.
