Old 02-09-2013, 08:35 AM   #31
klx250sfguy
klx250sfguy's Avatar
Oddometer: 968
I find winter is such a bummer. It kills me to have two bikes in my garage just sitting there.
Looking forward to the changes I'll be making to my C70. One gripe about my bike is the strap on the seat, the metal part digs into me. It is easily removed but doesn't look as good. Looks vs comfort, that the dilemma.
Can't wait for spring. Newfoundland is about to get blasted today by yet another winter storm.
klx250sfguy is offline   Reply With Quote
Old 02-12-2013, 12:02 AM   #32
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,386
My '68 Cub 125cc conversion uses a manual clutched long stroke engine, the clutch release pull is negligible, enough so that a short, sturdy BMX Bicycle brake lever works fine. removed the old grip and used an NOS Oakley BMX grip cut slightly shorter. Very smooth engagement even with the shorter lever.
I find it's also a lot easier to pull the clutch in to coast for hyper-mileaging on down hills and approaching stop signs. As much as I have liked the semi auto's I've owned in the past, having a manual clutch is a bit more intuitive in traffic and it just seems to shift faster.
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 02-28-2013, 01:02 PM   #33
txsizzler OP
Oddometer: 9
update
Just wanted to give everyone an update on my project. If you recall, I was going
to clean the gas tank (lots, and LOTS of rust in there, come to find out!!!),
and do some other things. Well, here is a laundry list of whats been done thus
far:
- Removed the fuel tank, and did a Evapo-Rust treatment, and lined it with Red
Kote. Here is the procedure I followed:
Evapo-Rust part
- plug petcock holes
- fill with Evapo-Rust (close to a gallon)
- Shake vigorously every few minutes for 30 min.
- Let product settle for overnight, dump out in the morning
- Remove plug from petcock holes, empty and shake out as much as possible.Blow
out inside tank with shopvac hose
Simple Green part
- Mix some Simple Green with water, fill the tank
- Shake vigorously every couple min for about 10-15 min.
- Remove petcock plugs
- Run cold water w/water hose until no suds are seen and line is clear
- Empty the tank, use ShopVac hose to suck out all the water
- Plug lines, pour a pint of Acetone into tank, shake vigorously
- Drain out Acetone, repeat Acetone procedure, remove as much Acetone
as possible.
- Unplug petcock holes, leave tank outside to dry
Red Kote part
- Plug petcock holes, and AROUND the fuel lid
- Using a funnel, pour the entire quart into the tank
- Tape fuel lid hole closed. DO NOT USE THE FUEL CAP
- Following the instructions on the Red Kote can:
- Rock slowly back and forth, up and down for about 30 min to get entire inside
coated
- Product should start moving slower inside
- Once it starts congealing, remove tape from fuel lid and petcock holes, and
let product drain out through petcock holes back into Red Kote can
- Make sure all excess product is out. Might have to rock back and forth, and
let it sit on the can
- After about an hour or so of this, and all excess product is out, put on
cardboard and leave out in the sun to cure
- Curing is 8-24 hours. Wait then a couple days to put fuel in. Should have a
nice, red surface across all areas of the inside tank
Summary
Worked GREAT! After letting it sit for about 24 hours, I checked it, and it has
a nice, red lining inside. Should really protect against the elements! Bought
both the Evapo-Rust and Red Kote at O'Reilly's. Spent about $35.
Here is more things I have done:
- Replaced fuel lines with 6mm (1/4" fitting) clear Motion Pro lines (bought
from Bike Bandit)
- Replaced spark plug, although the old NGK one still looks good, so saving it
as a spare.
- Replaced petcock with aftermarket one from eBay
- Checked the points, still look like NEW (the cap hadn't ever been taken off,
from what I am guessing.. almost lost the gasket, as it was stuck pretty good to
its mounting point)
- Checked air filter, still looks pretty darned clean
- Bought a new battery, filled with acid last night, had it sitting on a 6V
(2amp) charge cycle for about 10 hours (I found out later that this was too strong of an amp to
be charging with.. it shows 6.4v when the bike is off, and it not being connected to the posts.
With posts connected, its at 6.2v, and after riding around for a bit, it showed 14.3v????; its a WPS battery)
- Drained the float bowl. Will carb clean if needed. Will be running some
SeaFoam through it with the fuel.
Here in the next couple of months, I will be stripping the paint off the bike,
and repainting it. Haven't decided on a color yet.
I was able to ride around some after having to kick start it for awhile. No fuel in the carb, and had to get it in
there! Then it ran like a champ, although the idle speed is too high.
Anyhow, sorry if this was too long of a read! I hope others can get some good
info out of it, though! I will update more as I get more things done to it.
Ian
txsizzler screwed with this post 02-28-2013 at 06:12 PM
txsizzler is offline   Reply With Quote
Old 07-17-2013, 01:49 PM   #34
motogirl25
motogirl25's Avatar
Oddometer: 109
We are fixing up our 81 Passport right now and I saw this thread. We are looking for a throttle cable for ours... I read on a site that it was discontinued?? Where can I get one or is there another Honda cable that will work? Just wondering if you ran into this issue.
My Rides:
09 Suzuki DRZ400S, 06 Honda CRF250X, 74 Honda MT250 (vmx bike), 76 Honda TL125
2 Guys and a Girl Tackle the TAT: Part 1
motogirl25 is offline   Reply With Quote
Times are GMT -7.   It's 11:09 AM.
