Old 01-19-2013, 07:53 PM   #1
PBOB OP
MOTO NUT
PBOB's Avatar
Oddometer: 294
Changing fork oil in old Honda air folks
I want to change oil in the front forks on my 1982 Honda cb900c....
I have a factory repair manual- no mention or picto-process of changing fork oil...
The forks on these bikes is the kind with compressed air.
It shows everything in the book except how to drain and refill fork oil.
I only think they did that bc it must be super easy?... By I could b wrong.
Anyway, have any of you all done this on a dohc 80's cb? If so, point me in the right direction, and I will shoot pic's of how I did it for all to benefit.
Thx
1982 Honda CB900c
2002 Kawasaki KL250G "Super Sherpa"
1999 Honda CN250 Helix
1995 Honda XR650L (in Shasta white and Uranus violet of course)
The list is long, I'll stop there....
PBOB is offline   Reply With Quote
Old 01-19-2013, 08:11 PM   #2
r77toy
Oddometer: 466
Is there a phillips screw on the back of the fork legs near the bottom?
r77toy is offline   Reply With Quote
Old 01-20-2013, 07:47 AM   #3
PBOB OP
MOTO NUT
PBOB's Avatar
Oddometer: 294
I believe it's a hex bolt that drains it...
Changing typical folk oil in a cb750 per-air folk, is a matter of draining using screw at bottom and just refilling at caps.
But on these, I'm unsure how if it would be same process with air hose fittings...
1982 Honda CB900c
Old 01-20-2013, 12:54 PM   #4
What?
curmudgeon
Oddometer: 360
Maybe I don't need to tell you, but be sure you bleed off the air pressure before you remove the drain screw or hilarity we ensue.
What? is offline   Reply With Quote
Old 01-20-2013, 01:02 PM   #5
Cutsit
Cutsit's Avatar
Oddometer: 356
Here is a link on fork seal replacement from Naked Goldwings.
I believe that the 900 has the same forks.
http://www.ngwclub.com/forum/viewtopic.php?t=11831
Google is my friend! (so is Round-up)
Always mindfull of obstructions, do your duty never fail. Keep your hands upon the throttle and your eyes upon the rail.
Never be arrogant.
Don't waste ammunition.
Whiskey makes you think you're smarter than you are.
Always, always make sure you know who has the power.
Don't mess with old men, they didn't get old by being stupid.
Cutsit is offline   Reply With Quote
Old 01-20-2013, 02:10 PM   #6
Gham
Gham's Avatar
Oddometer: 1,319
It's kind of a pain in the ass.
Draining the oil is a simple process of removing the phillips head screws.
The chore is refilling the oil,removing the air-assist unit to refill on the CBF requires you remove the handle bars(take off the four bolt below the fuses),then take off the caps.
Make DAMN sure you have the bike secured with a jack when you loosen those caps!!!! That heavy ass I4 will come off a center stand so fast it will make your head spin!!!!!!
Member 6204
Society Historicus Revisioniscus
Gham is offline   Reply With Quote
Old 01-20-2013, 02:37 PM   #7
Gham
Gham's Avatar
Oddometer: 1,319
One last thing...if you choose to ditch the air system(which is junk anyway) and put some progressive springs(recommended,as yours are over 30 yrs old)I can walk you through that pretty easy
Member 6204
Old 01-23-2013, 05:13 PM   #8
PBOB OP
MOTO NUT
PBOB's Avatar
Oddometer: 294
Dang, I was hoping I could knock it out in no time....
It appears the air fittings will slow me way down.
What oil did you put in your's? Or did you use ATF?
I would prefer shocks to be a little stiffer than the are now...
Maybe use 10w-40 or 30?... Or would that have adverse reactions?
Also will I actually notice much of a benefit when complete?
Thx
1982 Honda CB900c
Old 01-23-2013, 06:44 PM   #9
PBOB OP
MOTO NUT
PBOB's Avatar
Oddometer: 294
thanks for the advice!
id hate to see my old bird bite the dust
1982 Honda CB900c
Times are GMT -7.   It's 06:06 PM.
