Old 02-07-2013, 11:23 PM   #1
Bob Tosi OP
Bob Tosi's Avatar
Oddometer: 1,607
Wanna be electrician can't figure thus out.
I'm trying to get my new dishwasher installed. My problem is I have no power at the outlet. It us a single Romex in the box. I've checked all the surrounding outlets and switches hoping to find the leg off to the dishwasher outlet, but I can find the feed to the dishwasher outlet. I tried to tone out the wire to the breaker panel but nothing. The breaker marked "dishwasher has power leaving so I'm essentially lost now.
Any assistance would be greatly appreciated.
When you're lost in the wild and scared as a child. And death looks you bang in the eye, and your sore as a boil, its according to Hoyle to cock your revolver... and die. But the code of a man says "fight all you can" and self-dissolution is barred. In hunger and woe, its easy to blow... Its the hell-served-for-breakfast thats hard........Robert Service
Bob Tosi is offline   Reply With Quote
Old 02-07-2013, 11:34 PM   #2
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
It shouldn't be wired this way, but possibly a tripped GFCI outlet in the kitchen that feeds the dishwasher? I've seen stranger things than that...
Was it hot before? How long ago?
I've also seen bathroom and outside GFCI receptacles feeding kitchen loads and vice-versa. It's not supposed to be that way, but it's more common than you think. Might be a good place to look, anyway.
kirkster70 screwed with this post 02-08-2013 at 12:28 AM
kirkster70 is offline   Reply With Quote
Old 02-08-2013, 05:08 AM   #3
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Try replacing the circuit breaker for the dishwasher.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 02-08-2013, 07:15 AM   #4
WoodButcher
WoodButcher's Avatar
Oddometer: 2,068
The switch by the disposal switch is on, right?
Rusty
2009 BMW R1200GS Adventure
WoodButcher is offline   Reply With Quote
Old 02-08-2013, 09:06 AM   #5
Bob Tosi OP
Bob Tosi's Avatar
Oddometer: 1,607
Switch by disposal is on. It had power then quit??????
There's no short or ground fault on the line. It's like it's open somewhere.
Old 02-08-2013, 09:14 AM   #6
trailNtent
trailNtent's Avatar
Oddometer: 179
Around here it would be wired so that one of the receptacles on the yoke is hot all the time for the dishwasher, the other is switched for the disposal. Are you sure you're plugged into the right one? Do you have a 3 wire romex in the box?
trailNtent is offline   Reply With Quote
Old 02-08-2013, 09:21 AM   #7
Kafn8td
Oddometer: 170
You've been to my house! Blow dryer in the upstairs bathroom and microwave at the same time and pop.
Kafn8td is offline   Reply With Quote
Old 02-08-2013, 09:35 AM   #8
SPEIRMOOR
Oddometer: 220
Check the outlet with a test plug such as this one.If no power try meter/tester on the breaker and prove thats working correctly. I've seen them fail in the "ON' position.
SPEIRMOOR is offline   Reply With Quote
Old 02-08-2013, 12:17 PM   #9
Rocket Scientist
Oddometer: 24
If its tagged in the breaker panel as "Dishwasher" I personally would remove the hot (black) wire & neutral (white) & follow suit at the dishwasher itself. With an open circuit I would then use a volt meter & double check to make sure theres no voltage across the line itself. After that is verified, I would hook up the meter in the OHM's setting & put the black wire on one side & white on the other while at the other end short the 2 together & check for a solid short across the meter. If you dont get a solid short & only get K-Ohms, more than likely you have an open side of the wire somewhere. You can use the copper (accessory ground) as a shorting side also to determine if its the hot or neutral side thats open. If the line continuity tests out, Id say its probably the breaker itself at the panel. Hope this helps.
Rocket Scientist is offline   Reply With Quote
Old 02-08-2013, 12:24 PM   #10
troidus
Oddometer: 14,278
Does the "dishwasher" breaker control the alarm clock in the master bedroom? Could be a joke by the PO.
troidus is offline   Reply With Quote
Old 02-08-2013, 01:08 PM   #11
baloneyskin daddy
bikaholic
Oddometer: 2,101
If there was a short across the wires the breaker would be tripped,,check for continuity to the breaker box.more likely a break in the wires
baloneyskin daddy is offline   Reply With Quote
Old 02-08-2013, 01:11 PM   #12
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
....also if someone "backstabbed" the switch instead of using the side terminal screws, that may be your problem.
Old 02-08-2013, 02:41 PM   #13
gsweave
Yinz, blinkers are on.
Oddometer: 11,469
Just run a new line/with breaker
Should be updated to a individual circuit .
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 02-08-2013, 04:09 PM   #14
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,931
+1
That one got me. DAMHIK.
Who's F'n idea was that anyway? Is it code? Has to be.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 02-08-2013, 07:06 PM   #15
Wistrick
Wistrick's Avatar
Oddometer: 276
If you have power leaving the breaker then sound like you may have lost a neutral..(white wire) check the small slot side of the outlet to ground...If you get 120v then u have neutral problem.....IIf you still stuck PM me...
Dan
IBEW 441
Wistrick is offline   Reply With Quote
Times are GMT -7.   It's 09:49 PM.
