Old 03-16-2013, 05:02 PM   #106
hapbob
hapbob's Avatar
Oddometer: 633
Just got
Waiting for spring in Michigan
Anyone changed Road King handle bars?
2014 triglide twin cooled
2007 CN250
sold2009 FLHR Road King
Hap
Retired USAF
hapbob screwed with this post 03-16-2013 at 05:24 PM
hapbob is offline   Reply With Quote
Old 03-16-2013, 05:23 PM   #107
hapbob
hapbob's Avatar
Oddometer: 633
2007 CN250
Hap
Retired USAF
Old 03-16-2013, 05:55 PM   #108
gymply
gymply's Avatar
Oddometer: 239
Nice looking King! Congrats.
Changing bars was one of the first mods I did to my new 2012 FLHR. The stockers were too short with not enough pullback for me. The options are endless, and I'm sure you will find something that fits. I ended up going with a set of 10-inch mini apes (WO515 from http://www.wild1inc.com/). They are a couple of inches taller and three inches more pullback than stock bars. I was able to use the stock brake line and clutch cable but had to add about 11 inches to the handlebar switch wiring. The wires on the throttle by wire unit were long enough to not need any extensions. All the handlebar/throttle wiring has connectors in the headlight nacelle which is convenient. You should not need to pull the gas tank, but I did because I was also installing a GPS mount and ran the power wiring direct to the battery. The worst part about the job was pulling the right side switch wires and throttle wires simultaneously. The throttle wiring comes into the bars from the end and merges with the switch wiring coming in from the hole drilled at the switch housing location. It makes for a pretty big bundle. Using a silicone type lube made the bundle fairly easy to pull. Good luck!
~gymply
'05 FXST
'12 FLHR
'14 FZ-09
gymply is online now   Reply With Quote
Old 03-30-2013, 12:24 AM   #109
Jagdpanther
Oddometer: 3
2005 rkc
...with WO 513 baby apes (8")
Jagdpanther is offline   Reply With Quote
Old 04-24-2013, 06:46 AM   #110
Mountain Cruiser OP
Oddometer: 1,204
I placed the order for a 2014 Candy Orange / Beer Bottle Road King with ABS/Security Package, 28 spoke cast wheels and cruise control with Military Sales. I will pick it up in September when I get back stateside. It's going to be sweet.....
Mountain Cruiser is offline   Reply With Quote
Old 04-24-2013, 08:36 PM   #111
RKC
RKC's Avatar
Oddometer: 4
So you want to know about Road Kings well they are by far the best harley ever made. I have owned many bikes or the years KLR650,wrx250,MP3,goldwing,Ultra Limited, and several more. The RK is the best of the best incredible on long trips and take the windshield and lowers off on warm days. What else could one want, add on the worlds largest following and you will never be far from an event.
You will not regret buying one, in fact you will wonder why you waited so long
RKC is offline   Reply With Quote
Old 05-22-2013, 10:21 PM   #112
Mountain Cruiser OP
Oddometer: 1,204
I was just informed by Military Sales that the Candy Orange / Beer Bottle is not going to be available in the 2014 Road King. I have to choose from the following colors:
024-Vivid Black
073-Brilliant Silver Pearl With Striping
521-TwoTone Big Blue Pearl & Vivid Black With Striping
648-Mysterious Red Sunglo With Striping
661-TwoTone Amber Whiskey & Brilliant Silver Pearl With Striping
I think I will go with 521. So I think it will look something similiar to this, but will be a Road King vice a Road King Classic.
Mountain Cruiser screwed with this post 05-22-2013 at 11:58 PM
Old 05-27-2013, 09:23 PM   #113
Ironfish653
Combat Commuter
Oddometer: 61
What was the year for the frame update on the FL's?
At the point now where I'm starting to look for a new long-haul commuter, and the Road Glide is on the list. (I like a frame-mounted faring!)
Looking for one with a couple of years on it, so I don't feel bad about riding it 365, rain-or-shine.
Cleverly Disguised as a Responsible Adult
Ironfish653 is offline   Reply With Quote
Old 05-27-2013, 09:27 PM   #114
studad
studad's Avatar
Oddometer: 933
2009
studad is offline   Reply With Quote
Old 05-28-2013, 07:40 AM   #115
Hair
Outside the boxer
Oddometer: 13,891
School me on the twin cam 88 motor.
I've been looking at the used RK market. The 88s are priced right. Many have low miles.
Did these motors have issues?
Where those issues addressed?
As we age we tend to become more direct in our thoughts and actions.
For me laundry day is no longer Wishy Washy day.
Hair is offline   Reply With Quote
Old 05-28-2013, 09:50 AM   #116
131unlimited
Oddometer: 452
88" Twin cam on the RK started in 99. Great Crank and timkin bearing setup through 2002. Weak spots were the cam bearings and the tesnioners for the cam chains. most have been addressed by there owners with upgraded bearings , replacment tensioners, or upgraded hydraulic tensioners , or elimination of that setup and replaced with gear driven cams. Must check crank run out to be within specs to run gear driven cams.
2003 to 06, not as strong crank and left side bearing setup. Same deal with the cams as mentioned above.
05's had a batch of bad valve seals, but is was well known and easily addressed by the owners back then.
88's came with a carb or with FI. the FI system is an older design , but there is aftermarket support for it to get different maps to run different builds.
All in all - they are very good motors , just need to make sure the cam bearings and cam chain tensioners have been addressed when purchasing.
131unlimited is offline   Reply With Quote
Old 05-28-2013, 10:34 AM   #117
Hair
Outside the boxer
Oddometer: 13,891
Old 05-28-2013, 12:49 PM   #118
foxtrapper
Oddometer: 776
The older fuel injection (Marnetti Marelli) started being dropped around 01 and replaced with the Delph. Can't simply say the 88 TC came with the older fuel injection, it came with both. When it was replaced depended on the model bike.
foxtrapper is offline   Reply With Quote
Old 05-28-2013, 01:01 PM   #119
131unlimited
Oddometer: 452
Thanks for the added clarity. I went from a carbed EVO 5 speed E Glide to a 2011 SG with the 103 and 6 speed, skipped all those years and didn't have the details on the changes in the FI.
Old 05-28-2013, 03:57 PM   #120
Deans BMW
Granpa Hoon
Oddometer: 3,316
I added a '13 Road King to the collection, Reminds me of a 50's era Buick or Olds but made with modern materials, great brakes, great tranny, excellent fueling and good running motor. will cruise at 90 all day long great gas mileage.
Completely enjoyable.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is online now   Reply With Quote
Times are GMT -7.   It's 08:56 AM.
