Old 05-06-2013, 03:46 PM   #106
MrPulldown
MrPulldown's Avatar
Oddometer: 3,403
They probably do need to be tougher
MrPulldown is offline   Reply With Quote
Old 05-14-2013, 07:31 PM   #107
ADVwanaB
BOLD NEW AVATAR
ADVwanaB's Avatar
Oddometer: 914
how do you plan to lower the rear?
what did you use for spacers on the front to lower it?
I would like to lower my DR about the same as you have and install a 19" front wheel. It has to be balanced though right? or the rake will be too steep.
2014 FZ-09
2005 CRF230F
2003 DR650
ADVwanaB is offline   Reply With Quote
Old 05-15-2013, 08:51 AM   #108
JagLite OP
JagLite's Avatar
Oddometer: 1,385
Cool2 Suspension mods
Rear lowering:
When I had Cogent Dynamics rebuild the stock shock into a double clicker with full adjustment I had him internally limit the travel to about 8" (at the wheel).
Then I had him install an adjustable height bottom clevis so I can play with ride height.
I have it set so the rear end is about 3" lower than stock.
Ride height is different from stock since the removable subframe and TT seat are lower than the stock frame and seat.
That means my seat is lower than a stock bike would have with the factory lowering.
Front lowering:
I used steel tube that I had on hand for the fork spacers.
Thick wall PVC or ABS could easily be used and is cheap and light.
The spacers only limit the travel and are under very little load.
The original top-out spring is still retained on the damper rod with the new spacers so that there is no instant hit against the spacers.
There is a little load on the spacers when the forks are fully extended when jumping or doing a wheelie.
Keep in mind that the stock spring is too long to put longer spacers (than the stock ones) in.
The problem would be that you could not push the spring down enough to install the fork cap.
So, depending on how much you want to lower your bike, the spacer you will use on the damper rod to limit upward travel will determine how much of the stock spring you will want to cut off.
An easy way would be to figure your desired front end drop, install a spacer that length on the damper rod, reassemble the fork leg and drop the spring in.
Then mark the spring at the top of the fork tube, take it out and cut it off at that height.
Cut the tight coil end and this will make your forks stiffer and enable you to still play with preload spacers on top of the spring if you want.
You can cut the springs shorter too if you want.
If you are going to cut more of the spring off than the length of your limit spacers, be sure to figure out coil bind length using this chart:
http://www.calsci.com/motorcycleinfo/Suspension2.html
If you are using aftermarket fork springs which are usually (always?) shorter than stock for the DR you may not need to cut them and I wouldn't recommend cutting them.
At least until after you have ridden it and see how stiff they are for your weight.
Balanced lowering is a good start for handling.
You may find you like the front lowered more than the rear as that will make the steering quicker or a bit more twitchy feeling.
The motard bikes drop from a 21" wheel to a 17" wheel on the front and most don't lower the rear to compensate.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 05-24-2013, 08:25 AM   #109
the schwartz
Buckethead Wendy
the schwartz's Avatar
Oddometer: 578
Cry
Originally Posted by JagLite View Post
Again, the end result:
I have ProCycle SS side covers on my other DR and they are great!
For what they cover. They don't cover the oil filter though, nor the entire clutch area. Much better than nothing!
And easy to buy and glue on.
holy freaking drooling green with envy. and my initials are AJS, too...
this is one of the coolest things i've ever seen
2004 Ninja 250 for sale!
the schwartz is online now   Reply With Quote
Old 05-24-2013, 08:38 AM   #110
anotherflyer
Oddometer: 9
Thumb Coolest build I've seen on a DR!
Very impressive.
anotherflyer is offline   Reply With Quote
Old 06-24-2013, 07:19 AM   #111
rhino_343
Southern Explorer
rhino_343's Avatar
Oddometer: 2,131
Thumb
Love it mate! Very inspirational and a timely read as I am looking to start something similar with my mate... Thanks for taking the time to write all this up and once again well done, you deserve that first place trophy!
Moto Guzzi Griso 1100
Suzuki DR650SE P I G
Husaberg FE350
Tenere XT600 34L 1983 classic
rhino_343 is offline   Reply With Quote
Old 06-27-2013, 06:02 AM   #112
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 648
The bike is stunning! Awesome work!
With regard to lowering, folks should keep in mind that smaller front wheel reduces trail, as will lowering the front without doing the same to the rear. Trust that you will want all the trail you can get when using a 17" wheel
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is offline   Reply With Quote
Old 06-27-2013, 11:31 PM   #113
JagLite OP
JagLite's Avatar
Oddometer: 1,385
Cool2 Outside pictures
Thanks for the kind comments, I do appreciate it!
I have been extremely busy fixing up an older house we bought and will start moving into this weekend so I have neglected posting on this thread.
So, here are a few pictures of the bike after my first ride on a dirt road.
In this picture you can see the shock sock my wife sewed up for me.
It has a Velcro seam so I can easily remove it for adjustments.
I like the reflection on the tank in these shots
Front views:
Heard the old term to "Drop it in the weeds" referring to lowering a car?
So I did:
You may be waiting for a ride report, if so, wait a bit longer
My short ride is not enough to test it out and give it a real workout, let alone adjust the suspension to my liking.
I can say that it feels tiny!
More like my Yamaha TW200 than anything else.
Since I am 6'-4" it will take some getting used to I can tell.
The 13/46 sprockets really give it instant acceleration and quick shifting.
I plan to get a 14, 15, and maybe a 16 front sprockets to experiment with. But this is not a highway bike so I am not looking for a comfortable 65 mph cruise.
I am not happy with the muffler though. It is OK at low revs and sounds great but once up to even half throttle it is too loud. I don't like obnoxiously loud bikes making non-riders hate riders so I will be modifying the muffler or replacing it with a GSXR can.
I am also going to make a new pipe since I didn't like my first attempt in both welding and in bend layout. The goofy mummy wrap covers the lousy welding but nothing can hide the shape not following the frame bends enough for me.
Other than all the work fixing up the house we bought and the pain of moving everything and then fixing up our old house to get it on the market, I am looking forward to having a real shop.
Yes! A two car garage (24'x24') instead of a one car garage...
I am doubling my shop space!
This winter I have two project bikes lined up in addition to the Rickman Metisse.
A Wee Strom 650 and a Suzuki VX 800.
Tracker or cafe', or????
Attitude ~
James
Old 06-28-2013, 08:29 AM   #114
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
Lizrdbrth is offline   Reply With Quote
Old 07-02-2013, 11:02 AM   #115
JagLite OP
JagLite's Avatar
Oddometer: 1,385
Cool2 Size comparison
Here are some interesting pictures comparing the Yamaha TW 200 with the DR 650 Tracker.
This should give everyone a good idea of how small the Tracker is
Now I need to take pictures of the Tracker next to my other DR for comparison.
Attitude ~
James
Old 07-03-2013, 07:35 AM   #116
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV is offline   Reply With Quote
Old 07-11-2013, 01:47 PM   #117
JagLite OP
JagLite's Avatar
Oddometer: 1,385
Cool2 Size comparison two
Finally took the time to shoot pictures of the Tracker with my DR.
In the process of moving and I had to move the bikes to get at other stuff to load so I parked the bikes together and here is the results.
Switched positions:
And with the TW also:
While I was moving bikes out of the way I decided to take a few pictures of the Street Fleet together.
These are the street legal bikes I currently have, although my Honda VTX1800 project is not in the pictures, yet.
Not in the pictures are the dirt bikes.
I should mention I only buy cheap bikes.
My DR was the most expensive at $3,500.
The TW was second at $2,200.
The Wee Strom and VX800 are both future project bikes.
The Wee was an insurance total sold as parts.
The VX800 was $800 and the second one I have owned.
I think it will make a neat and unique Street Tracker.
Why buy new when I can buy 3, 4, 5 or more great bikes for less than the price of one nice new one. Well, I do want a Honda Grom...
Attitude ~
James
Old 07-11-2013, 02:55 PM   #118
DRjoe
DRjoe's Avatar
Oddometer: 5,244
Mate you've finished that bike of brilliantly.
Its amazing how much slimmer it is compared to the stock dr.
DRjoe is online now   Reply With Quote
Old 07-12-2013, 08:22 PM   #119
JagLite OP
JagLite's Avatar
Oddometer: 1,385
Eh? Pipeburned Exifbike
Originally Posted by PhiSig1071 View Post
That is too cool, you should submit it to pipeburn or bikeexif. It's better then some of the crap they put up. I think the stance looks great, I'd be worried if you lower the back end it'll mess that up.
Thanks for the suggestion!
I sent some low res pics to both to see if one or the other would be interested in featuring it.
Well, it has been two weeks and still not a word from either one.
Which is the answer obviously.
My bike doesn't meet their requirements I guess.
Maybe the seat looks too comfortable?
Ah, well. I like my bike and I certainly enjoyed the build process and look forward to my next project.
Attitude ~
James
Old 07-17-2013, 10:12 PM   #120
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,561
I'll be looking forward to it too. What's the plan with the Strom?
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Times are GMT -7.   It's 04:10 PM.
