01-20-2013, 11:33 PM
#1 |
Oddometer: 5,968
Aluminium fuel tanks and E85 fuel
I'm looking at a Bartel fuel tank for my Norton, as a bit of a project to dress it up the odd time as a Norvil proddy racer. I was recently told that alloy is also very sensitive to E10 and E85 fuels. This is a new one on me! I know fiberglass tanks have a very short life with E15, and of course the widely known and documented issues with E15 and vinyl/nylon tanks.
But alloy??? WTF,,,,,
Garage Residents: '72 Norton 750 Combat, '74 Honda CT70, '74 Norton 850 Interstate, '81 Laverda Jota '89 Honda RC30, '91 BMW R100GS '08 BMW R1200GS |
01-21-2013, 04:07 AM
#2 |
Spudly Adventurer
Oddometer: 3,271
Sounds like misinformation to me, I have never heard of such.
I would think you are fine, but why E85 in a bike ? Mike
Cogswell Rides To Big Bend See my airhead project here Time Warp Vintage Motorcycle Club The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED. |
01-21-2013, 06:50 AM
#3 |
More tacos than you
Oddometer: 5,197
Yeah, running E85 I'd be more concerned about the engine than the tank.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
01-21-2013, 09:40 AM
#4 |
Rectum Non Bustibus
Oddometer: 3,641
The ethanol in E85 isn't a big problem. I think that it's being confused with methanol, which will corrode things if left in a fuel system.
To get the full benefit from a fuel like E85, the engines' compression ratio needs to be increased and more ignition advance is also required.
10 Ducati 1098 Streetfighter S - "Sleipnir" 09 Kaw Versys "The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher |
01-21-2013, 06:16 PM
#5 |
Oddometer: 5,968
Geez, I'm sorry guys. When I was talking about E85, I meant E15. Yes, you are right, that total avoidance of E85 is of the highest priority.
I'm getting the picture that the info I got about E15 and alumimium tanks [from the Norton Commando forum] is not correct. I've been forced a couple times to use E15 in my RC30, which has an alloy tank. To this day, the inside of this tank is pristine.
01-21-2013, 06:40 PM
#6 |
Easily Distracted
Oddometer: 251
Yeah, you should be fine with that in there. Now, methanol left in an alloy tank
...over time forms kind of this slimy shit thats about the consistency of calf snot and will plug up a fuel filter in a heartbeat. EVEN IF you drain the tank that crap will form. You have to wipe it out with a rag on a stick then swish a lil WD-40 around to keep it at bay. (I've got buddies with alcohol drag cars )
"East were the Dead kings and the remembered sepulchres; West was the grass." Archibald MacLeish |
01-21-2013, 08:32 PM
#7 |
Oddometer: 409
An interesting take on this subject was aired last week on TV. It detailed the many problems Oregon boat owners are having with gasoline/alcohol mixes. I think it would be very prudent to coat any alu tank with Casewell's excellent product. I plan to do just that myself after viewing this: http://www.opb.org/programs/ofg/
Sadly, government seems to be mandating fuel use without weighing the costs to users. In the case mentioned in the above cite, it could have fatal consequences.
.................................................. ................ For all we know, this may all be just a dream; we come, we go like the ripples in a stream. |
01-22-2013, 08:06 AM
#8 |
Cheesehead Klompen
Oddometer: 154
E10, E15 and E85 are all ethanol based blended fuels. In my opinion ALL of them should be avoided in motorcycle engines whenever possible. If you are going to simply run the fuel through the engine such that the bike won't be sitting around with ethanol blended fuel in the engine, then the only loss is fuel mileage. Fuel mileage is proved to be down from 5% to over 15% on ethanol blended fuels.
If the bike will be sitting around unused for any length of time I avoid ANY ethanol blended fuels. The ethanol blended gas degrades quickly, and ethanol attracts water. It forms acids in the oil if left in the engine. Nothing good about it as regards motorcycle engines.
When life throws you a curve,.....lean into it! |
01-22-2013, 08:58 AM
#9 | |
Rectum Non Bustibus
Oddometer: 3,641
01-22-2013, 10:43 AM
#10 |
Oddometer: 372
I have had aluminium tanks on all my motorcycles for the last 10 years using E10 or whatever it is now with no problems.
