Old 01-21-2013, 07:10 AM   #1
Jim Moore OP
Jim Moore's Avatar
Oddometer: 13,441
Genuine Buddy 125 Final Drive Questions
HI folks,
I have an opportunity to buy a GB125 for cheap. It starts, but doesn't run. It also has a trashed final drive. "Trashed" as in grinding noises and metal in the FD oil. I've never dug into a scooter final drive before, but I've watched a few videos. I assume I will have to replace everything that turns or rotates in the final drive. I haven't had any luck finding an online fiche. Any idea how much $$ I'm looking at to replace all the bearings and gears? Any special tools required?
Thanks,
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 01-21-2013, 07:13 AM   #2
gogogordy
gogogordy's Avatar
Oddometer: 1,921
Originally Posted by Jim Moore View Post
HI folks,
Thanks,
You might be better off sourcing an insurance totalled Buddy and just doing an engine/driveline transplant. They're out there!
Isn't it past your bedtime?
gogogordy is offline   Reply With Quote
Old 01-21-2013, 07:36 AM   #3
Jim Moore OP
Jim Moore's Avatar
Oddometer: 13,441
I thought about that. I saw one on eBay for $900. Thta's way too much for this project. I'm hoping to spend $100 or so on parts. I'm not interested if I can't do it for that.
Jim Moore
Jax, FL
Old 01-21-2013, 07:49 AM   #4
gogogordy
gogogordy's Avatar
Oddometer: 1,921
Maybe call Genuine directly in Chicago....?
Old 01-21-2013, 07:59 AM   #5
Jim Moore OP
Jim Moore's Avatar
Oddometer: 13,441
OK, I found an online fiche. Looks like about $200 worth of parts. Interesting. Looks like I'll get to use my bearing puller. Anyone know if the gears need to be pressed?
Jim Moore
Jax, FL
Old 01-21-2013, 10:26 AM   #6
Chillis
Iron toocus
Chillis's Avatar
Oddometer: 3,840
May want to try modernbuddy.com forums.
Also, the parts may be swappable with aftermarket GY6 bits which could save some money as well.
Originally Posted by Skowinski View Post
Speaking of dumps, that coffee is working for sure, gotta scurry and perch on the thundermug...
Chillis is offline   Reply With Quote
Old 01-21-2013, 10:48 AM   #7
Jim Moore OP
Jim Moore's Avatar
Oddometer: 13,441
Thanks. I see the term GY6 alot, mainly referring to engines. What is a GY6 exactly?
Jim Moore
Jax, FL
Old 01-21-2013, 10:58 AM   #8
Chillis
Iron toocus
Chillis's Avatar
Oddometer: 3,840
The basic aircooled platform of scooter engine from 125cc to 150cc(Buddy 170cc is now even bigger). There are different versions of the GY6 so parts have to be confirmed before purchasing and swapping since there are several derivatives.
Old 01-21-2013, 06:52 PM   #9
bbishoppcm
It ain't a moped.
bbishoppcm's Avatar
Oddometer: 666
Be careful; on real Honda scooters, if the needle bearings are trashed, you need to replace half the engine case (the needle bearings are not replaceable). Call that a "worst-case" scenario!
bbishoppcm is offline   Reply With Quote
Old 01-21-2013, 08:49 PM   #10
Hittman
Oddometer: 157
The gears do not need to be pressed in.
Hittman is offline   Reply With Quote
Old 01-22-2013, 07:48 AM   #11
Jim Moore OP
Jim Moore's Avatar
Oddometer: 13,441
Thanks for the info guys. I'll let you know what happens.
Jim Moore
Jax, FL
Old 01-30-2013, 11:44 AM   #12
Dibber
Oddometer: 15
Try www.scooterwest.com or www.scooterworks.com. Scooter Works is the same company that distributes the Buddy 125. These are the best locations I have found and use them on my Buddy 125. Interesting, never heard a drive train being toast. My has been a real work house for over 14,000 miles.
Dibber is offline   Reply With Quote
Old 01-30-2013, 11:56 AM   #13
Jim Moore OP
Jim Moore's Avatar
Oddometer: 13,441
Thanks again. I kinda got the it was run without rear drive oil, or it was never checked. The whole thing is fishy, but I can live with fishy for super-cheap.
Jim Moore
Jax, FL
Old 01-30-2013, 01:59 PM   #14
Motovista
Parts is Parts
Motovista's Avatar
Oddometer: 507
I've seen a few scooters with final drive failures. A lot of them had crappy bearings put in at the factory, and there are some that have obviously been under water at some point. One thing you want to make sure of before ordering parts is that when the rear end self distructed the bearings and gears didn't take chunks of engine case with them. That's expensive.
Also, sometimes people think the final drive is toast and when you open it up you find out that a clutch shoe broke or the variator froze on the crankshaft.
When you pull the bearings, note the sizes and try to replace them with German or Japanese bearings. We use a brand called Nachi and have had very good luck with them.
Freeze the bearings and they will slide right in where they should.
Discount OEM, replacement and performance parts for vespa, honda, bmw, yamaha, suzuki, genuine, kymco, piaggio, aprilia, SYM, tgb, tomos and other scooters at http://www.scooterpartsco.com
GT200, GT200, ET2, Italjet Velocifero, Italjet Torpedo, Eton Beamer 3, Genuine Buddy Pamplona 150, Kymco Vitality 50, Honda Elite 50
Motovista is offline   Reply With Quote
Old 01-31-2013, 08:09 PM   #15
conchscooter
conchscooter's Avatar
Oddometer: 1,985
If the transmission ate the end of the crankshaft you may need a $900 transplant motor. Go for it and tell us the result!
http://www.keywestdiary.com
IBA#39,523
conchscooter is offline   Reply With Quote
Times are GMT -7.   It's 06:26 PM.
