Old 01-31-2013, 10:38 PM   #16
JerryH
Oddometer: 5,069
My understanding is that the GY6 is only found in Chinese scooters, and only 150cc. The Buddy is built by PGO in Taiwan, and is likely to be completely different. If the damage was cause by running it without final drive oil, it may not be so complicated after all. Probably does not involve the engine or even the variator. Most everyone on the Zuma forum recommend UNDERFILLING the final drive on Zumas and Vinos. I slightly overfill mine. It is vented so it won't blow a seal. And I have never had any oil blown out the vent.
JerryH is offline   Reply With Quote
Old 02-01-2013, 09:43 AM   #17
hexnut
just cruising
hexnut's Avatar
Oddometer: 1,630
Honda made the 1st GY6. The Chinese just copied it. The Buddy is a GY6 as are the Kymco 125s and 150s. The Big wheel Kymcos have the GY6B engine with the longer trans case.
2014 Harley Sportster 883 Superlow
hexnuts...a curse put on your balls by a mean gypsy
3/5 Cav, C Troop, BlackKnights, Vietnam 1969
hexnut screwed with this post 02-01-2013 at 10:01 AM
hexnut is offline   Reply With Quote
Old 02-05-2013, 10:06 AM   #18
Motovista
Parts is Parts
Motovista's Avatar
Oddometer: 507
Often repeated, especially on the internet, but nobody has ever come up with anything from Honda referring to a GY6, or parts fiches or service manuals about this motor. AFAIK, Honda produces service manuals and parts fiches for pretty much everything they make.
The first examples of the 50cc version I have seen came on the Kymco Filly. That is the only non-Chinese one I have seen that uses a 669 belt, and it has a design flaw, corrected in later Kymco versions but still in the Chinese versions, that is the primary reason you don't see many high mileage Chinese scooters that have not had the top end replaced. When China banned two strokes on their own roads, the 150cc GY6 was rushed into production, and there is an additional design flaw in the version the Chinese chose to copy which causes abnormally high crankcase pressure to build up.
Discount OEM, replacement and performance parts for vespa, honda, bmw, yamaha, suzuki, genuine, kymco, piaggio, aprilia, SYM, tgb, tomos and other scooters at http://www.scooterpartsco.com
GT200, GT200, ET2, Italjet Velocifero, Italjet Torpedo, Eton Beamer 3, Genuine Buddy Pamplona 150, Kymco Vitality 50, Honda Elite 50
Motovista is offline   Reply With Quote
Old 02-05-2013, 11:05 AM   #19
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,173
The final drive and engine are completely separated, sealed oil containing entities on most twist n go's so the top end defect would have little effect on trashing the rear drive.
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 02-05-2013, 05:49 PM   #20
JerryH
Oddometer: 5,069
So is the GY6 a Kymco design, made into a 150cc by the Chinese? Aside from the crankcase venting problem (which the earlier Honda GET engines used in the Metropolitan and Ruckus also had) what is the other flaw in the GY6? Do current Chinese GY6 scooters still have these problems?
Old 02-08-2013, 11:19 AM   #21
Motovista
Parts is Parts
Motovista's Avatar
Oddometer: 507
The 150 was also being made by the Taiwanese, but it was not quite perfected when the Chinese decided to "borrow" it. The other problem is the design of the camtower on the 50cc head. It is still being used on the Chinese product today.
Times are GMT -7.   It's 10:38 AM.
