Old 12-23-2006, 09:09 AM   #1
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,530
Question Found another...What are these plugs for? R100GS
1991 R100GS
Found these plugs buried in my wire loom.
Any clue what they are for?
these have flat spade connectors inside...
Rapid Dog screwed with this post 12-03-2010 at 10:39 AM
Rapid Dog is offline   Reply With Quote
Old 12-23-2006, 09:10 AM   #2
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,530
Question and this?
Old 12-23-2006, 09:27 AM   #3
wintonio
last of the Dum Dum Daze
wintonio's Avatar
Oddometer: 1,654
Originally Posted by Rapid Dog
1991 R100GS
I found out last week that the one on the left, with the two wires, is for the heated grips. I patched into the hot lead(green), but sent the ground to the battery, though you could patch into the brown ground. I will look at my haynes manual for what the others are
wintonio is offline   Reply With Quote
Old 12-23-2006, 09:41 AM   #4
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,530
more
I'll mention that according to my VIN check this bike is registered as an R100GS...the PO appeared to have PD kitted it with the PD fairing and tank, etc.
That said, there are no heated grips on the bike, and he hacked the hazard switch into an auxilery light switch, which may explain one of the 3 plugs...
I don't have a manual, anyone got a 1991> R100GS wire diagram?
Rapid Dog screwed with this post 12-23-2006 at 09:53 AM
Old 12-23-2006, 09:53 AM   #5
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,980
The hazard wasn't a stock item...
My 1993 is actually a PD that was converted into a non-pd.. so if you ever want to trade your PD kit for a super nice set of non-pd bodywork....
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 12-23-2006, 09:55 AM   #6
wintonio
wintonio's Avatar
Oddometer: 1,654
lucky you
I have a full fairing as well, but no PD tank . But, I do have a 1992 R100GS, and that is what the wire was for, even though I had no factory heated grips
Old 12-23-2006, 10:14 AM   #7
BMWRich
BMWRich's Avatar
Oddometer: 1,590
I was told that the wire looms on the '91 through '95 are universal between all the GS and GSPD models for those years. These extra plugs are on all the looms,so if a particular "option" was ordered on a bike,the loom was already wired for it.
I believe that because on my two (now sold) airhead GS's a '92 and a '95,I added heated grips,emergency flashers,and believe it or not the "factory clock" that fit on the handle bar clamp above the triple tree.
All were "plug n play" additions or in my case "mount-plug-an play"! The wire loom was already with the connectors.
I just don't remember from memory what each connector was for from sight..sorry...
2007 GS Adv
Everybody likes a little ass,..but nobody likes a smartass...
BMWRich is online now   Reply With Quote
Old 12-23-2006, 10:15 AM   #8
BMWRich
BMWRich's Avatar
Oddometer: 1,590
I believe for the "factory handle bar clamp" clock...
2007 GS Adv
Old 12-23-2006, 10:21 AM   #9
wintonio
wintonio's Avatar
Oddometer: 1,654
tengo mas
ok, in the top picture, the connectors are for
left side: heated grip connector, as mentioned earlier
right side: if the back side of the yellow wire is violet, it is the connector for the hazard flasher.
I know you do not have these things on the bike, but BMW did provide the connectors for them
Old 12-23-2006, 10:26 AM   #10
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,475
I've always been pretty poor at figuring out wiring, but the BMW airheads stuff seems pretty easy to figure out in general. With the wires and a good diagram you can usually sort stuff out. Their harnesses do seem to be laid out so all options are plug and play. I had a 78 r80/7 and put a factory S fairing on it with the clock and voltmeter. With the S fairing harness everything just plugged in and it was ready to go. JT
jtwind is offline   Reply With Quote
Old 12-23-2006, 11:11 AM   #11
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,530
danka!
you guys are da bomb!
Old 12-23-2006, 11:56 AM   #12
m0t0-ryder
squirtin dirt
m0t0-ryder's Avatar
Oddometer: 295
Not sure how accurate it is for your year model, but here's a scan of the wiring harness for my '88 R100GS.
(the manual is Haynes 1970 - 1988)
Name:  wiring harness sm.jpg
m0t0-ryder is offline   Reply With Quote
Old 12-23-2006, 01:40 PM   #13
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,530
Question one more
...and what about these 2? one is red wire, other has 2 black wires, both spade type...
Old 12-23-2006, 03:24 PM   #14
tiefflieger
tiefflieger's Avatar
Oddometer: 300
My Haynes Manual shows a fourth, green/black wire for the clock; otherwise it's a match.
tiefflieger is offline   Reply With Quote
Old 12-26-2006, 08:45 AM   #15
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,530
these?
anyone guess these yet? the red one is hot with the key on and the test light grounded to the frame but the test light doesn't work if you have ground to the black wire...
Times are GMT -7.   It's 05:33 AM.
