Old 01-21-2013, 08:44 AM   #1
Thunder Strike OP
Oddometer: 69
handlebar suggestions?
Howdy!
I have a 99 KLR650, and as you know that means I am a cheap-scape. (spell check that one)
Anyway, I want to replace my: handlebars, hand guards, throttle assembly, grips to heated, and girl friend.
I already chunk-ed the used girl friend and I am thinking of buying a shinny new one with MORE mileage. lol
Thunder Strike screwed with this post 01-21-2013 at 08:48 AM Reason: add pic
Thunder Strike is offline   Reply With Quote
Old 01-21-2013, 08:50 AM   #2
Thunder Strike OP
Oddometer: 69
anyway
Thunder Strike screwed with this post 01-21-2013 at 08:51 AM Reason: free image hosting kindda slow
Old 01-21-2013, 09:10 AM   #3
ruppster
ruppster's Avatar
Oddometer: 848
Rocky Mountain ATV Tusk brand stuff. Works well for frugal individuals like myself.
15 KTM 690E, 05 KTM 450EXC
ruppster is offline   Reply With Quote
Old 01-21-2013, 09:48 AM   #4
greer
Oddometer: 3,727
Handy chart, too:
http://www.rockymountainatvmc.com/Ha...r-Measurements
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 01-21-2013, 11:27 AM   #5
Thunder Strike OP
Oddometer: 69
Originally Posted by greer View Post
Thanks for both the replies. After looking at the chart and making a call I have decided to go into the shop and try some different ones out for free. :)
I went by there at lunch, and won a hat!
Old 01-21-2013, 06:02 PM   #6
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,212
Originally Posted by Thunder Strike View Post
Howdy!
cheapskate
The word "good" has many meanings. For example, if a man were to shoot his grandmother at a range of five hundred yards, I should call him a good shot, but not necessarily a good man. ~G.K. Chesterton
joenuclear is offline   Reply With Quote
Old 01-21-2013, 08:52 PM   #7
jprovence
Oddometer: 67
I have used the ProTaper ATV-Mid on the KLR before. A great replacement for stick, and much better quality and aluminum as well.
jprovence is offline   Reply With Quote
Old 01-21-2013, 09:20 PM   #8
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,170
MSR ATV High bars are pretty close to stock and cheap. They're no stronger than stock -- they WILL bend in any self-respecting biff. Aluminum bars are strong and expensive.
The Tusk handguards from Rocky Mountain ATV/MC are cheap and strong as hell. I've tested mine several times off-road.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 01-22-2013, 07:36 AM   #9
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Nothing wrong with bars that do bend.... At least those long riser bolts and triple clamp does not break! Think about it. You can ride home with bent bars but not so much with that other stuff broken off. Steel bars are cheap. Triple clamps, not so cheap! The stronger the alum bars get, the more they transmit force back down the line.
buls4evr is offline   Reply With Quote
Times are GMT -7.   It's 11:59 PM.
