01-27-2013, 06:48 AM
#76 |
Oddometer: 91
Subarus first got my attention with the early 80's Loyale and its' high/low 4wd transmission. Too bad they've all melted away from the salt and rust.
Then the early 90's 2.2 engine truly was bullet proof. You didn't even have to worry about the timing belt because it was a non-interference engine. The Legacys were a nice ride and I had a two wheel drive one that could get 35mpg with a little careful driving. But in my opinion it has been down hill since then. I've had 12 different subies, seven on the road at one time, but reliability has been inversely proportional to the age of the car. We have a 2002 impreza with all the fore-mentioned problems. And they've gotten amercinized and grown huge. I think you could open the back door of a Tribeca and drive a Justy right in. My love affair with Subaru has pretty much faded. hey John |
01-27-2013, 07:58 AM
#77 |
Found:Gideon's Bible
Oddometer: 53,642
Their styling hasn't improved, either, IMO.
The last decent looking Impreza was 2007. With the possible exception of the Forester, I don't like the look of anything in their lineup anymore.
It's only a scratch. It is a far, far better thing to have a firm anchor in nonsense than to put out on the troubled seas of thought. -- John Kenneth Galbraith |
01-27-2013, 10:13 PM
#78 | |
Location: Sometimes the Twin Cities, Sometimes NW Wisconsin
Oddometer: 934
01-28-2013, 03:23 AM
#79 |
Oddometer: 4,738
Then how do you explain Subaru's continued growth in US market share?
2009 DL650A, 2008 Tiger 1050 ABS, 1994 XR100R |
01-28-2013, 04:20 AM
#80 | |
Wee-stromer
01-28-2013, 05:28 AM
#81 |
Oddometer: 91
NPR had a segment on Subaru and its' growing market share this morning.
They lay part of the blame on Portlandia. Hey John |
01-28-2013, 06:58 AM
#82 | |
Oddometer: 6,251
01-28-2013, 07:54 AM
#83 | |
Oddometer: 4,738
Haters gona hate, but.
The low-end [4 speed] automatics are an 80/20 or 90/10 split (ie, drive the front wheels until slip is detected) without any locking. Cars with the six cylinder or turbo have a five speed automatic Subarus VTD drive system. This is a significantly more sophisticated system that puts more than half the power to the rear wheels until slip is detected. Almost all of the VTD cars also have VDC - essentially four wheel electronic traction control that uses the ABS system to limit slip and help keep the thing pointed in the right direction. I don't have a 2010 manual OBW wagon handy, but on all previous Subarus equipped with VDC, there was a button to disable it, and it was "off." On my 09 WRX it's a button on the lower left part of the dash, unlabeled other than the graphic. I usually only shut it off for autocross. The STI has yet another drive system, with mechanical front and rear limited slip differentials and a "DCCD" - Driver Controlled Center Differential, which can vary the amount of power directed to the front and rear wheels from 90/10 to 10/90. This hardware is the primary reason the STI weighs more than the WRX. AWD systems are all "automatic" but the Subaru systems are not like the She-RV or RAV4 systems, other than being relatively light duty AWD systems without things like locking or limited slip differentials. For one thing, the 2012+ CR-V has a more capable system than previously. RAV4 has had three different systems, some with a viscous coupling center differential, some with a clutch type center differential (like the low-end Subaru manual system) and some of each model with mechanical rear LSD. The higher-end Acura SH-AWD system does have a mechanical center differential. http://www.awdwiki.com/en/subaru/ etc.
2009 DL650A, 2008 Tiger 1050 ABS, 1994 XR100R garandman screwed with this post 01-28-2013 at 08:02 AM |
01-28-2013, 10:35 AM
#84 | |
Living on a prayer
Oddometer: 6,119
Although my Parents had a 1992 Auto Trans one that blew up. Subaru replaced the transmission without charge. It was the car I learned to drive in.
01-28-2013, 11:09 AM
#85 | |
Oddometer: 6,251
01-28-2013, 01:42 PM
#86 | |
Oddometer: 810
You bring up a point I've wanted to know. I have seen the videos posted about Subaru's climbing up a ramp with rollers where other vehicles could not. The video looks impressive. Is it true Honda, Toyota, Ford, etc. AWD systems could not move up a slope with only 1 wheel having traction???? |
01-28-2013, 01:52 PM
#87 | |
Oddometer: 6,251
I suppose others could chime in and say that no vehicle in the world, except a subaru, can do that. |
01-28-2013, 11:26 PM
#88 |
Oddometer: 5
My '84 Subaru Brumby (Brat) now has 124,000 km on the clock. What should I be looking for regarding the head gasket problem?
01-29-2013, 05:16 AM
#89 |
stay weird
Oddometer: 1,171
01-29-2013, 06:38 AM
#90 | |
Oddometer: 4,738
In other words, you are 100% correct in having the least expensive and least capable Subaru system of the several they offer. And have moved on. Good luck.
| Thread Tools | |
