Old 01-21-2013, 08:16 PM   #1
BuffaloRunner OP
Gone to Baja
Oddometer: 16
Slime- whats your experience?
To deal with the ongoing saga of running tubed tires in my F8GS I poured 16oz of slime in each tire. Thats what the bottle recommends. I have yet to have a flat with them so I can't speak to their effectiveness.
Has anyone else used Slime in their tires? How much? How effective?
I've also heard you don't need to balance a tire with the proper level of slime in it? Anyone know the truth to this urban legend?
"Nothing is great which is not also calm. A gladiator is protected by skill but left defenseless by anger."
-Seneca
BuffaloRunner is offline   Reply With Quote
Old 01-21-2013, 09:55 PM   #2
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,447
Slime in a tube just makes a huge mess when you manage to get a flat. Plus, you can't patch the tube due to it being covered in goo.
I did it once, never again.
As for balancing a tire, it will run to the place that is the furthest out from the axis of rotation, not necessarily the light spot in the tire, which can make an out of balance condition worse. Just do it right the first time and use a few weights.
tbarstow is offline   Reply With Quote
Old 01-21-2013, 10:15 PM   #3
Fuzzy Wrench
Pick Your Tool
Fuzzy Wrench's Avatar
Oddometer: 5
Slime won't work with a tube since it flows out the puncture into the tire and...makes a mess inside for when you have to install a patch..Would work better with tubeless..
Fuzzy Wrench is offline   Reply With Quote
Old 01-21-2013, 11:45 PM   #4
PeterW
Oddometer: 2,692
My experience is old. It worked well, maybe too well.
I remember changing one rear and the tube turned out to be riddled with holes, and it'd glued itself to the carcase and couldn't be removed separately. Probably leaked a bit, but not to the point of being unridable.
So, yes, it works with tubes, that's where it's normally used in fact (bicycle tubes). If you want to give yourself a decent chance of not having to field change a tube, it's probably the only option that'll handle road speeds.
Pete
PeterW is online now   Reply With Quote
Old 01-22-2013, 05:04 AM   #5
Zoolion
Zoolion's Avatar
Oddometer: 58
My edxperience is about the same
Dont do it. It just makes a huge mess.
"I'd hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." - Hunter S. Thompson
Zoolion is offline   Reply With Quote
Old 01-22-2013, 05:07 AM   #6
steveWFL
steveWFL's Avatar
Oddometer: 1,344
Slime is an opposing force to my tire pressure sensors
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 01-22-2013, 09:28 AM   #7
jasiebol
jasiebol's Avatar
Oddometer: 36
I tried it once, it was fine going slow but when you got up to 45-50 mph it all went to one side of the tire and was way out of balence. Maybe i put to much in
jasiebol is offline   Reply With Quote
Old 01-22-2013, 01:18 PM   #8
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,833
+1 for messy. I bought a used XR650R and was unaware that the PO had Slimed the front tube. I am guessing it was an old tube, and the tire on the front was OE. One day when I was getting ready to ride, I topped up the front tire and noticed something green, much like antifreeze between the tread blocks on the front tire. It turned out to be Slime that had oozed out from around the metal valve stem, where it was bonded to the tube, and, in turn, oozed out through cracks in the old tire near the knobs.
I did not ride that day, given the obviously bad tube and tire combination. It made for a hell of a mess to get off the wheel when I replaced the tire and tube.
FWIW, there are two different grades of Slime, one for tubeless tires and one for tube-type.
-Joe
The Marines...When it absolutely, positively has to be destroyed overnight.
Trust and Respect take years to earn, but can be lost in a moment.
Life's too short to hold a grudge. -Joe
Purcell69 is offline   Reply With Quote
Old 01-22-2013, 01:21 PM   #9
dattaway
yeehaw!
dattaway's Avatar
Oddometer: 26
I didn't mind the green slime. But for a non-flammable substance, I was impressed that it peeled all the paint away. The paint flakes were fun to clean off my garage floor.
dattaway is offline   Reply With Quote
Old 01-22-2013, 05:18 PM   #10
thomas.tc.young
Oddometer: 862
Had it in a front tube for a few weeks until I decided to change it. Worked fine but the again I never take my klr above 55 anyway. Had a very slow leak even with slime but only did that when sitting and it hooped to the bottom of the tire instead of staying near the hole
1969 CL350 permanent project
2013 Ninja 650
1987 XR600R
2001 TTR-125L
the klr/versys project: http://advrider.com/forums/showthread.php?t=810279
thomas.tc.young is offline   Reply With Quote
Old 01-22-2013, 06:42 PM   #11
kubiak
Oddometer: 4,829
it works great in my bicycles but havent used in the motorcycles.
Old 01-22-2013, 06:55 PM   #12
wayne_l
Oddometer: 182
it wont fix tears put it will stop pin holes from thorns . im running it on my front 21 inch k60 . its enough to slow a good leak down and buy me time to get a fix .
It also saved my riding partner frome a tear down on the freeway in the middle of the freezing night . Just remember there is 2 types of slime for tubed and non tubed tires ...
But it aint a miracle worker .. if its torn ..tube has to be replaced ...
wayne_l is offline   Reply With Quote
Old 01-22-2013, 08:00 PM   #13
BuffaloRunner OP
Gone to Baja
Oddometer: 16
Thanks for the feedback. Seems like its about 50/50 on using it, understanding that its only for smaller punctures.
I'll update when I have a flat. Hopefully that will take a while.
-Seneca
Old 01-23-2013, 02:04 AM   #14
PeterW
Oddometer: 2,692
Nope, the rear I changed had half inch slashes in the tube - when I wrote 'riddled with holes' I meant it. Thing is, I was using it on a bike that had a top speed of 127kph, down hill , with a tail wind. I'm not sure I'd be so happy using it on anything faster.
Pete
Old 01-23-2013, 02:19 AM   #15
showkey
Oddometer: 1,955
Slime as an emergency on road repair has some merit as a prevent repair strategy not a great idea.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Times are GMT -7.   It's 02:07 AM.
