Old 02-01-2013, 01:27 PM   #16
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,955
I used a razor blade and a ruler . . . Didn't have an exacto knife. You may be able to use scissors . . . If they are orange.
My bike decal is a Silhouette of an Adventure. I couldn't find a good one to copy so I traced a 950A on my iPad.
Think of it as a 950A shadow decal . . . Cut out by hand from someone that has very little paper doll experience!
How's this?
mcmann screwed with this post 02-04-2013 at 01:28 PM
mcmann is offline   Reply With Quote
Old 02-03-2013, 04:52 PM   #17
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,463
There you go... Looks perfect to me.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 02-04-2013, 01:34 PM   #18
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,955
I decided to CF the side covers & fork tubes . . . Now I am done . . . Unless someone has another idea . . . Still have some left-over pieces!
Yes, motorcycles helps keep the kid in me alive . . . I really like trying different ideas out on my bikes!
Full view:
Old 03-28-2013, 08:11 AM   #19
barbwire44
barbwire44's Avatar
Oddometer: 120
How are you guys removing the original graphics? I thought they were clear coated over. My tank has bubbles in the graphics I would love to take them off and do something like the above
Doing the right thing is not always the easiest thing to do. (J.J. 2012)
13 KTM450,08 KTM200,GASGAS EC200,Guzzi Quota 1100es, DRZ400, 1200HD,
barbwire44 is offline   Reply With Quote
Old 03-28-2013, 09:18 AM   #20
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 2,956
Basically, heat: http://www.advrider.com/forums/showp...1&postcount=27
And then you have to get the glue residue off the tank: http://www.advrider.com/forums/showp...5&postcount=45
Hope that helps.
Orangecicle is offline   Reply With Quote
Old 03-28-2013, 03:51 PM   #21
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,955
I was able to get the old decals off by cutting into the bubbles with a razor blade and heat it with a hair dryer . . . Pulling the label up from the middle to the outside. Or, from the top of the label with my fingernail.
Old 03-29-2013, 09:50 AM   #22
brocku
brocku's Avatar
Oddometer: 67
Awesome idea and result. I have an '06 and there are one gagillion bubbles on each side. looks like the elephant man.
I thought that a clear coat was applied on top of the decals instead of under them, therby trapping the gas vapours below.
Now, when the old bubble decals come off; did you spray a clear to seal the rest of the tank? Then put the decals on top of the new clear?
Thanks.
brocku is offline   Reply With Quote
Old 03-29-2013, 10:08 AM   #23
Orangecicle
On a "Quest"
Oddometer: 2,956
Thanks.
Not to hijack your thread here, McMann. But, to answer the question, you don't have to clear coat the tanks under decals or clear coat over the decals. It is unclear whether or not clear under or over makes any difference. My tanks were covered with two layers of 3M decal material where the normal stock decals are located. No problems now for a year or so of wear. The decals on the actual gas tank below are replacements. The "K" on the little faring part is original.
Old 03-29-2013, 10:38 AM   #24
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,955
I got my 3M carbon fiber decal idea from your original post . . . I am not as creative as you. I noticed the 3M decal material was very thick and sticky . . . It was not necessary to remove any old label sticky residue.
As you mentioned, it is not clear-coated under the label and is not necessary. I cleaned the surface with alcohol before applying the new decal. I did not remove the front black label . . . It was not bubbled . . . I put the new CF label over the black to match my new CB tank decal.
After removing my label:
Old 03-29-2013, 10:46 AM   #25
brocku
brocku's Avatar
Oddometer: 67
Thank you gents. Great info. A project for April when the weather is warmer and the beer wouldn't freeze in my hands!
Thanks !
Old 05-28-2013, 12:35 PM   #26
Venturer
AKA klakeman
Venturer's Avatar
Oddometer: 694
Orangecicle,
I went your route and put on replacement black decals. Unfortunately, after 12 months, the new decals are bubbling badly. Just like the original. I wonder why yours are holding up ok. Any ideas?
Kirk
'05 KTM 950; '11 KTM 350 XCF; '08 KTM 250 XCF-W; '05 Montesa 250 4RT Trials
Venturer is offline   Reply With Quote
Old 05-29-2013, 11:16 AM   #27
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,955
I am getting some bumps under my carbon fiber decals . . . The texture of the CF does help from noticing etc. Bottom line, it would be best to have decal material that can breath . . . Small perforations in the decal.
Plastic material on plastic gas tanks probably won't last long unless they can breath.
Old 05-30-2013, 09:49 AM   #28
Venturer
AKA klakeman
Venturer's Avatar
Oddometer: 694
Yep. Does anyone know of perforated tank decals for the 950? Simply putting new stick-on graphics won't work. They ALL bubble eventually. My new ones are now worse than original...
Kirk
Old 05-30-2013, 10:39 AM   #29
Qwik
Adrenaline Addict
Oddometer: 6,849
I am going to use perf'd Dinoc on my safari tanks. Hopefully the perforations will help with the bubbling.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 05-31-2013, 07:19 AM   #30
Venturer
AKA klakeman
Venturer's Avatar
Oddometer: 694
Makes sense. Where did you find the perforated product ?
Kirk
Times are GMT -7.   It's 10:17 PM.
