Old 01-22-2013, 09:52 AM   #1
motoretro OP
Oddometer: 453
Generator Propane conversion &??'s
My 5 year old Honda EB5000X has lost it's fuel prime therefore won't start and stay running. I can drizzle a bit of gas into spark plug hole and get it to start(pull) and running for 3-4 seconds at best. any ideas?
This whole fuel issue leads me to think Propane might be a better choice. This is the second piece of equipment I've had go down due to Ethanol fuel issues. How difficult is the conversion? +'s & -'s?
Motoretro
motoretro is online now   Reply With Quote
Old 01-22-2013, 12:04 PM   #2
ragtoplvr
Oddometer: 4,600
This is also how they act when low on oil
be sure to check and top off
Rod
ragtoplvr is offline   Reply With Quote
Old 01-22-2013, 12:06 PM   #3
RVDan
RVDan's Avatar
Oddometer: 1,634
Don't know if a kit is available for you Honda. I used to convert onan Rv generators all the time, took about an hour to instal the kit plus the time to run the propane line. Not too difficult
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 01-22-2013, 12:36 PM   #4
ttpete
Rectum Non Bustibus
Oddometer: 3,641
If it's been sitting for awhile, you probably have clogged carburetor jets, especially the idle jet.
09 Kaw Versys
"The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher
Old 01-22-2013, 01:07 PM   #5
motoretro OP
Oddometer: 453
It's run every 6 months, new plugs and oil every year and always use fuel stabilizer. Local implement dealer mentioned even w/ stabilizer, They're replacing carburetors by the wheel barrel load.
Motoretro
Old 01-22-2013, 01:15 PM   #6
gsweave
Yinz, blinkers are on.
gsweave's Avatar
Oddometer: 9,988
http://www.propane-generators.com/
How we run em.
If your looking for me. I will be at Rella's eating Blackberry pie.
http://www.youtube.com/watch?v=qri3VhRQA7Q
http://www.youtube.com/watch?v=_ampAFmwP_E
gsweave screwed with this post 01-22-2013 at 01:31 PM
gsweave is offline   Reply With Quote
Old 01-22-2013, 01:16 PM   #7
ttpete
Rectum Non Bustibus
Oddometer: 3,641
Motoretro
I'd be draining the carburetor after each run. Only takes a minute.
My generator's set up with an electric fuel pump so I can drop a sucker hose into any gas can and change them on the fly. I dump the cans into the truck every so often and get fresh gas.
09 Kaw Versys
Old 01-22-2013, 01:30 PM   #8
motoretro OP
Oddometer: 453
Neat set-up, how does it start in cold weather? Any reduction in power to drive the generator?
Chonda.....Ironically my Honda is made in China .
Thanks, Motoretro
Originally Posted by gsweave View Post
How we run em.
Old 01-22-2013, 01:37 PM   #9
gsweave
gsweave's Avatar
Oddometer: 9,988
No noticable change in power.
No longer need any choke to start. they start everytime.
We use em on emergency cooling pumps for melt furnaces. they must run within 5 minutes of a power failure.... otherwise ugly expensive shit happens
This is ice indroduced to bath.... same thing happens if coolent is lost, which really would suck if you happen to be beside it.
gsweave screwed with this post 01-22-2013 at 01:46 PM
Old 01-22-2013, 01:54 PM   #10
motoretro OP
Oddometer: 453
Oil is right up to the top.
Motoretro
Rod
Old 01-23-2013, 11:48 AM   #11
motoretro OP
Oddometer: 453
Thanks for the info, looks like a interesting occupation.
Motoretro
Old 01-23-2013, 12:54 PM   #12
motoretro OP
Oddometer: 453
This where it seems to be headed. Hopefully I can get the garage warm(It was 0 last night) enough to tear things down tonight. Trying to figure what solution I can use to soak the parts in to dislodge any varnish, crud.etc. Any ideas? Tried local car parts and Powersports places and they just shook their heads.
Motoretro
Old 01-23-2013, 04:21 PM   #13
ttpete
Rectum Non Bustibus
Oddometer: 3,641
Motoretro
Lacquer thinner works well. You'll have to pass a fine wire through the idle jet, the solvent alone won't do it.
09 Kaw Versys
Old 01-23-2013, 04:59 PM   #14
motoretro OP
Oddometer: 453
I've a pint of Laquer thinner in the cabinet along with a set of torch tip cleaners, Thanks for the tip.
Motoretro
alone won't do it.
Old 01-23-2013, 05:08 PM   #15
ttpete
Rectum Non Bustibus
Oddometer: 3,641
Motoretro
If the tip cleaners aren't fine enough, a bristle from a fine wire brush works well.
09 Kaw Versys
Times are GMT -7.   It's 08:34 PM.
