Old 02-11-2013, 11:18 PM   #1
heirhead OP
Oddometer: 560
Help Me Rhonda
Hello,
Snapped plastic float as screwdriver slipped. Anybody crazy glued one back together?
Just a little 1/8' piece of plastic, doesn't move much. Please advise to the stupidity of this question or
is it genius for saving $50.00.
Thanks in advance for your advice.
Heirhead
Worlds worst mechanic
heirhead is online now   Reply With Quote
Old 02-12-2013, 11:01 AM   #2
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,615
Been testing some industrial strenght CA on some plastics the last couple days. Only one where it seems to have worked is ABS+PC as marked by BMW.But Eh it is only a $50.00 part.
So I have my doubts, will see when I re-install.
But the glue was free....!
Have tools, will travel!
Old 02-12-2013, 11:12 AM   #3
heirhead OP
Oddometer: 560
Thanks for your reply,
Am going to glue it now.
Heirhead
Old 02-12-2013, 12:17 PM   #4
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,222
Most every glue is not going to hold up to fuel over the long run -- gasoline is quite the solvent. I'll be surprised if it lasts longer than a week in the environment inside a float bowl....
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 02-12-2013, 05:03 PM   #5
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,258
^+1 on the glue not lasting.
If I were going to try something futile, I'd attempt to melt the two pieces together, although alignment would be a bit difficult. If it works you could be a KLR legend!
HapHazard is offline   Reply With Quote
Old 02-12-2013, 07:38 PM   #6
P B G
Oddometer: 10,001
seal all?
Old 02-12-2013, 10:36 PM   #7
heirhead OP
Oddometer: 560
Hello,
Didn't work
Heirhead
heirhead screwed with this post 03-31-2013 at 11:49 PM
Old 02-13-2013, 05:47 PM   #8
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,914
I glue parts together for a living as a Loctite Factory Rep. and moonlight as a lobotomist-a fun and entertaining self-taught hobby and I'm still learning.
The bondline you're dealing with is key..are you trying to bond the equiv of the edges of two pieces of paper together or do they overlap? You don't have to think hard as to which is the better bondline.
We recently tested a few cyanoacrylates (aka: CA's, Super Glues) for one of my customers in a long term diesel AND bio-diesel immersion test.
At the 5000 hour mark in complete immersion of his parts the tensile strength actually went up. We all were surprised. Bio Diesel immersion actually increased in strength more then the regular diesel did.
Ideally we'd need to know what kind of plastic the float cage is made of before recommending any one of our 120 different kinds of CA.
If you wanted to move forward without knowing the type of plastic you're dealing with the Loctite CA was 431.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 02-13-2013, 11:03 PM   #9
heirhead OP
Oddometer: 560
glue float?
Hello,
VERY interesting.
Heirhead
heirhead screwed with this post 03-31-2013 at 11:50 PM
Old 02-15-2013, 09:20 AM   #10
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,789
How about plastic welding it together, using the same material as the cage is made out of would results in an equivalent structural bond wouldn't it?
But then again your mechanical reputation precedes you so....
(also check ebay you might find a used cheap replacement so you will have a spare if all else fails, good luck regardless)
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 02-27-2013, 09:55 PM   #11
heirhead OP
Oddometer: 560
glued float
Thanks again folks,
Heirhead
You know
heirhead screwed with this post 03-31-2013 at 11:48 PM
Times are GMT -7.   It's 11:54 PM.
