Old 01-22-2013, 11:00 AM   #1
sect8dr OP
ride them all
Oddometer: 242
01 CR250 cylinder on a 97 CR?
Just wondering if I can put a cylinder from an 01 CR 250 on my 97 CR 250? I am thinking it will be no problem but just wanted to ask those in the know. Thanks
sect8dr is offline   Reply With Quote
Old 01-22-2013, 11:42 AM   #2
RUSTYtankerBEAN
RUSTYtankerBEAN's Avatar
Oddometer: 47
I did a quick bike bandit check and they have different part numbers, but that is not to say that they wont work as I believe they are able to be bolted on.
Here is a great link that talks about the subject specific to the 1997. To paraphrase the link it says...92-01 will bolt on but I would check piston differences. I hope this helps.
Aaron
http://www.thumpertalk.com/topic/767...ars-will-work/
http://www.bikebandit.com/houseofmot...m2192#sch91162
http://www.bikebandit.com/houseofmot...2188#sch89 930
RUSTYtankerBEAN screwed with this post 01-22-2013 at 11:48 AM
RUSTYtankerBEAN is offline   Reply With Quote
Old 01-22-2013, 12:51 PM   #3
sect8dr OP
ride them all
Oddometer: 242
Thanks for the link, I know that the porting is different, i will have to look into the pistons
Old 01-22-2013, 07:46 PM   #4
Farmer John
Oddometer: 11
The 01 cylinder will work fine on a 97.
They use the same gaskets & piston kit even.
Some like the 01 porting better than the massive hit of the 97's
Farmer John is offline   Reply With Quote
Old 01-23-2013, 09:13 AM   #5
sect8dr OP
ride them all
Oddometer: 242
Thats the plan
Just looking to smooth out the power for a better woods bike
Old 01-23-2013, 06:18 PM   #6
RUSTYtankerBEAN
Oddometer: 47
Flywheel weights will help with smoothing the power out also. I used them on my YZ125 and it made the power come on much more smoothly.
Old 01-28-2013, 02:07 PM   #7
zokalr13
zokalr13's Avatar
Oddometer: 414
+1 on the flywheel weight -I have one on my ol CR500,anyways,I like the "all things moto" website for 2 stroke tech stuff- check it out -lots about CR250s...
zokalr13 is offline   Reply With Quote
Times are GMT -7.   It's 11:25 PM.
