Old 01-25-2013, 01:46 PM   #46
Fixnfly
Fixnfly's Avatar
Oddometer: 366
I did the heater core on a 99 S-10 a few years ago. It ranks pretty high on the pain in the ass list. Lots of vacuum hoses to disconnect and keep track of, lots of screws in places no screws should ever be. During the 8 hours I did this, I made up a few new curse words and threw a few tools across the garage. It's one of the many reasons I would never even consider buying another GM product.
01 DRZ400S 93 GSXR750 13 Z1000
Fixnfly is offline   Reply With Quote
Old 01-25-2013, 07:38 PM   #47
KeithinSC
KeithinSC's Avatar
Oddometer: 1,451
I'd be doing the job myself, but I have a heated shop. You will want heat, as all that plastic on the dash and hire harness connectors is brittle when cold.
Good luck.
KeithinSC is online now   Reply With Quote
Old 01-27-2013, 12:37 PM   #48
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Good luck.
Some of that junk plastic is brittle here in Phoenix in the summer. But when a company is pinching pennies to pay those huge salaries/perks to upper management, why spend a few for decent plastic? Every beancounter needs his high dollar lunch!
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 01-27-2013, 12:43 PM   #49
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Originally Posted by _cy_ View Post
this is why I'll always install Bars Leak long before any problems becomes due. even if my cooling system is not leaking. Bars Leak also conditions coolant and lubricates your waterpump.
ethylene glycol the main ingredient in anti-freeze really doesn't wear out. but anti corrosion additives do get depleted. installing Bars Leak helps maintain coolant.
only use the original pelletized version of Bars Leak. adding something wrong to your cooling system could really screw it up major.
not a proponent of changing out anti-freeze just to renew anti-corrosion additives. have ran the same anti-freeze for 20+ years on multiple vehicles with zero problems. but they all had Bars Leak installed right from the beginning. then anytime radiator hoses were renewed. Bars Leak reinstalled.
So you believe that Bars Leak renews the corrosion protection? Any idea what chemicals it uses to do so?
Old 01-27-2013, 12:55 PM   #50
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,807
Turmeric and Ginger with a smidge of polyethylene glycol to make it even more enjoyable.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 01-27-2013, 12:56 PM   #51
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,632
Interesting the Bars's leak corrosion protection.I never knew that. Looks like I may dump some in the bush car, don't think the antifreeze has been changed in 10 years. Just so happens that I have some here, no need to spend money on that car, it is a Toyota after all.
Rhyzex???
http://www.barsleaks.net/how2works.html
My 78 GMC van was shooting antifreeze through a spark plug hole. Bar's leak fixed it and for many years. Enough time to drive it all the way back east and come back fully loaded, then go to Mexico and was still fine when I sold it many years later.
Not so on my 88 Chevy van, same problem and the engine blew up shortly after, shooting antifreeze from the tailpipe.
Eh...they make Rislone also, the only "miracle in a can" my grandpa believed in. He probably saw lots of miracles....or not in his long career as a mechanic going back to 1928.
Have tools, will travel!
Old 01-27-2013, 04:51 PM   #52
LakeAbilene
Oddometer: 6
Rhyzex???
Every GM I owned shot antifreeze from the tailpipe. I thought they were designed to do that!
LakeAbilene is offline   Reply With Quote
Old 01-27-2013, 05:38 PM   #53
troidus
Oddometer: 14,403
I've seen it only twice, neither time on one of mine. One was a late-60s Pontiac 400 on which the block cracked in the lifter valley just below the deck on both sides, and the other was on a '75 Chevy 350 that got a split between the intake and exhaust valves on #5. That one ended up with a badly bent rod.
troidus is offline   Reply With Quote
Old 01-27-2013, 06:43 PM   #54
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,632
No and my dad was a GM dealer, sure wasn't a common problem back then. Maybe that they rusted into oblivion before that happened... Better out the tailpipe anyway than the compression pressurizing the cooling system. Not good loosing the heat when it overflows in cold climates.
But them black V-8s from the 80's, sure did not measure up to the earlier ones.I think they were made in Mexico. But I mostly drove and abused 4 Bolt mains, red ones and blue ones!
Old 01-28-2013, 04:07 PM   #55
D.T. OP
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,971
Cool2
Update: I went shopping for a vehicle on Saturday and a dude on Craigslist seemed really cool. Until I called on Saturday. He hmmed and haaaad and said call later. I stopped at some used car dealers and you can't get much for under $3 grand.
So I said F it and decided to try and tackle it in my driveway on Sunday morning. Temps were up around 32 degrees so that helped. Dropped the steering column with 4 nuts and all the F'n screws around the dash and it tilted back nicely. There is ENOUGH room to remove the core cover and core itself with out removing the big F'n mess of a dash. So I got it shoehorned in. Took me about 5 hours before the rain sleet hit.
$38 bucks for a heater core and it's done. I had to cut back the heater hose 2" because it was leaking at the motor. Went and spent another $21 on a new hose today. Going to put that in tomorrow.
Anybody have any ideers on how to flush the cooling system at home?
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 01-28-2013, 04:32 PM   #56
Benesesso
Benesesso's Avatar
Oddometer: 9,898
What did the old antifreeze look like? Any rust? Color? The answers can make a difference to how you proceed.
Old 01-28-2013, 04:49 PM   #57
D.T. OP
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,971
There is a little bit of sludge (dexcrap orange) in the system. I usually remove the reservoir and dump it down the toilet. Then rinse all the sludge out and flush it (going to get some crap about this). I put some prestone cleaner in the reservoir last year.
If I had to I can get a 5 or 15 gallon plastic container and put the spent coolant in there, but where would I bring it to?
Oh and BTW, to the dude at first gear garage that told me I needed to evacuate the air conditioning system...
D.T. screwed with this post 01-28-2013 at 06:44 PM
Old 01-28-2013, 04:57 PM   #58
villageidiot
Oddometer: 1,726
i would (while changing heater hose) unhook the old hose from the engine, and hook one end of the new hose to the engine, hook a garden hose (if not frozen solid) to an open end of the hose, and turn it on flush it thru until clean water comes out the open end of hose.
then unhook lower radiator hose and drain system completely, and fill with fresh cooolant/anti corrosion/water mix
villageidiot is offline   Reply With Quote
Old 01-28-2013, 04:58 PM   #59
Benesesso
Benesesso's Avatar
Oddometer: 9,898
I won't run the orange stuff. If you want to continue with it your flush will be easier. Me, I'd flush it all out using several changes with tap water, then refill with 50/50 green AF. You might even try adding some Bars Leak.
Old 01-28-2013, 07:30 PM   #60
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,632
The engine probably has a dedicated coolant drain plug, or two. You should open them up. Hard to get the crud from the bottom of the water jackets out if not doing so. I have opened a few of them where nothing came out until I pushed at the crud with a punch or pick.
We even had an adapter at the shop way back then to flush from the drain plugs. Hoses have to be removed so you don't send the crap to the radiator.
Times are GMT -7.   It's 05:09 AM.
