Old 01-24-2013, 08:39 AM   #1
Katoom119 OP
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Highway Dirt Bikes and Heated Grips
I'm putting Symtec heated grips on my bike and don't like the little toggle switch.
I want to get the Highway Dirt Bikes top clamp so I can turn them on or off. My question is can I get the one with the little turn dial to act as the rheostat to control the current?
I'm thinking turn on the grips with the push button and control the current with the dial. OR turn on the grips and control the current with the dial.
I'd also like to have the little LED light up so I know that they're on.
For those familiar with these, can I use the one from the HDB or do I need to get a stand alone controller ala Geek's Gerbring setup, post #206 in "Back in Black"?
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 01-24-2013, 01:36 PM   #2
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,650
Send in your question to Paul at HDB.
I used a top clamp that Paul made me for other gear, fans & such-
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 01-24-2013, 05:33 PM   #3
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
I did but haven't heard back. I'm guessing he must be out of the office or something.
Nice setup.
Old 01-24-2013, 06:44 PM   #4
Hondo
Hondo's Avatar
Oddometer: 9,650
You could mount the heat troller to an Ipod mount or switch mount-
http://www.highwaydirtbikes.com/HDB_...i6565r364074o4
Old 01-24-2013, 07:16 PM   #5
kirb
should be out riding
kirb's Avatar
Oddometer: 1,803
I mounted my remote adjust heat troller behind the dash with the knob in the top left corner. The troller I use is the on/off and adjustment. The troller duty cycles the grip...adjustments will increase the on time and reduce the off time. Duty cycles control the net heat output.
Warmnsafe.com
A Ducati, some Guzzi, a KTM, and a Excelsior...Indian in resto.
kirb is offline   Reply With Quote
Old 01-26-2013, 05:41 PM   #6
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,125
I don't know much, but I do know that you can't use just a rheostat to control your heated grips. You can use an on-off switch and LED where you say, and then get a LED dimmer to mount somewhere else for the heat control. The LED dimmer is just a cheap way to get a PWM control. I've got one on my symtec heated grips, works great- ADVRonski did a little write up here in O.C. somewhere. Mount the pot where you can get to it, and remotely mount the rest of the circuitry- run the whole thing into the hi part of the grips, ignore the low circuit completely.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 01-26-2013, 08:54 PM   #7
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
Just heard back from Paul yesterday (I think, what day is it?) and he said get him some dimensions and specs of what I'm doing and we'd make something work.
Man good customer service is refreshing...
Old 01-27-2013, 12:33 PM   #8
Hondo
Hondo's Avatar
Oddometer: 9,650
You won't find any better than Paul.
Times are GMT -7.   It's 09:29 AM.
