Old 01-24-2013, 09:35 AM   #1
Brixelus OP
Do you feel lucky?
Brixelus's Avatar
Oddometer: 3
Convert PDF file to GPX to put into Garmin
Can anyone tell me if it's possible to take the picture below, which I have as a pdf file and somehow convert that so I can put it into my Garmin gps?
Brixelus is offline   Reply With Quote
Old 01-24-2013, 09:45 AM   #2
250senuf
250senuf's Avatar
Oddometer: 1,723
There is this page to look at:
http://www.garmin.com/us/products/onthetrail/custommaps
Not all who wonder are confused
" I say VW's are like VD.....once you get a good one, it's hard to get rid of." oldmonkeybut
250senuf is online now   Reply With Quote
Old 01-24-2013, 01:55 PM   #3
Brixelus OP
Do you feel lucky?
Brixelus's Avatar
Oddometer: 3
Thanks! That was helpful...
Old 01-24-2013, 02:47 PM   #4
OceanMtnSea
Pretty Dogged
OceanMtnSea's Avatar
Oddometer: 442
Find the image location in Google Earth or Google Maps and create the same route using the map tools, then save as *.kml file and import into Basecamp.
2007 BMW Dakar & 2009 Ducati Multistrada entering the middle of the in-land sea called Saskatchewan Canada
http://s737.photobucket.com/home/OceanMtnSea
OceanMtnSea is offline   Reply With Quote
Old 01-25-2013, 03:11 AM   #5
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 11,661
What GPS are you working with? Not all of them easily accept custom maps, and some older ones don't easily accept gpx route and track info.
And you specifically asked for a a gpx file, which just has track and route information. GPX files don't have maps or images.
dunno.....
Old 01-25-2013, 09:02 AM   #6
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,228
YES, it's possible, and it doesn't involve maps or Routes, it only involves GPS Tracks. I do it all the time, but it's not a simple process.
1) Convert each PDF into a JPEG or PNG, as you did to post that image above.
2) In Google Earth, use the Image Overlay tool (in the Add menu) to import the image as an overlay.
3) Adjust the image transparency so you can see both the overlay image and the underlying Google Earth imagery.
4) Move and scale the image so it perfectly lines up with the same geographic area in Google Earth.
5) Use the Google Earth "Add Path" tool to draw a line on top of the red line from your image.
6) In Google Earth, save that path you just drew (or set of paths) as a KML file (unless you can import KML directly).
7) Use GPS Babel to convert the KML file to a GPX file.
8) Open the GPX file in MapSource or BaseCamp to adjust track colors, then load into your GPS.
p.s. The track in your image above is where the 2012 NORRA Mexican 1000 Rally was going to go, but I moved the race course to a new set of roads further North-East to avoid racing through the streets of Todos Santos.
Going where no Harley has gone before
HogWild screwed with this post 01-25-2013 at 09:17 AM
HogWild is online now   Reply With Quote
Times are GMT -7.   It's 08:58 AM.
