02-22-2013, 08:53 AM
#16 |
Oddometer: 240
I think you will like the 7.5 spring. At 250, that extra spring will give the bike back its proper geometry and feel. At 210 a dont think a good rider would benefit from the change from stock. Also - I think the stock spring on the 2011 raga was a 6.8 (its printed on the spring)
02-25-2013, 09:00 AM
#17 | |
Trails Evangelist
Oddometer: 963
I agree with you, ya might want the stiffer rear spring, I was just making sure because at 220 and below, I could definitely say stiff springs were causing me trouble.... What I felt was, instead of the tires being allowed to compress the forks and rear shocks, they would stop on the rocks (not the big ones, the ones you wouldn't notice as much, unless it was slicker than heck probably). It was a muddy trials and new lower weight totals, that had me headed home to revert back to stock suspension asap, when I was probably at 230ish or 235... because the front tire (without (pat my own back here) really good technique to unweigh both tires as they rode over these bowling ball rocks, in the middle of tight turns, stuff like that) Now softer springs, I "seem" to glide over almost without working at it. Still I know some had to just do with gravity totals, and I'd be able to tell you if I get back to 280 again, if It feels different again, which I wont do... )
03-07-2013, 07:31 AM
#18 |
Oddometer: 399
After a box of new parts and a few [ok lots]of hours of disassembly and assembly the bike is sitting there complete and ready to go.To bad it is 8 degrees and snowing.Grease was very thin and poor quality in steering head,linkage and swing arm.Changed the fork oil and used a little heavier[7 wt] than stock and raised the oil level 5 mm in each leg.There were plenty of aluminum chips in the stock fork oil so it was probably a good idea to flush them.Bike is beautiful to look at but really my only complaint now other than poor set up from the factory is the mish mash of bolts and nuts they use. My KTMs use 8,10 and 13 and you have everything you need.Working on the Raga it seems like you need a large pile of tools to get anything done.Example is the the sidestand.It needs to be removed to replace the rear brake line.Three allen bolts hold it on.One head is 4 mm,another is 5 mm and guess what-the other is 6 mm.That is unreasonable.Luckily the bike is gorgeous and so far has made a great garage ornament.Two weeks till the first trials.
03-10-2013, 06:53 AM
#19 |
Oddometer: 709
What, no pictures?
2010 Gas Gas EC250 - 1997 Honda XR650L - 1992 Gas Gas GT25 "Twenty years from now, you will be more disappointed by the things that you didn't do than by the ones you did do" - Mark Twain |
