Old 01-24-2013, 11:25 AM   #1
35xj OP
Oddometer: 912
ratcheting sound in front cyl head
some of you have seen this thread,
http://advrider.com/forums/showthread.php?t=856781
now im into it, and going throuh it all. im using the 14 mm to run it through to tdc to check valve, rear is fine. front cylinder is making a really strange ratcheting sound, and the cams kinda "ratchet" forward its not on every rotation. but seems to be every couple?
35xj is offline   Reply With Quote
Old 01-24-2013, 12:21 PM   #2
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Any chance you can upload a video, same to vimeo? Picture is a 1000 words as they say, video is 100,000
crazybrit is offline   Reply With Quote
Old 01-24-2013, 03:20 PM   #3
BoulderGuy
out ridin'....
BoulderGuy's Avatar
Oddometer: 433
If its a big "clack" type noise coming from the front cylinder as you turn the motor by hand it is normal. No idea what it actually is. Kind of freaked me out the first time.....
BoulderGuy is offline   Reply With Quote
Old 01-25-2013, 04:19 AM   #4
zedtours
zedtours's Avatar
Oddometer: 367
Is it accompanied by flickering oil light? = low oil pressure to tensioner
If not check cam chain and tensioner.
zedtours is offline   Reply With Quote
Old 01-25-2013, 05:09 AM   #5
35xj OP
Oddometer: 912
it is happening while the covers are off and im rolling the motor over by hand. been assured by locals that its normal.....
Old 01-25-2013, 06:14 AM   #6
GrenDesb
Oddometer: 328
Yeah, it's when the cam just turn by the top of the lobe and the valve spring push the cam up until the chain slack is taken.
Don't know if what I wrote is understandable though.
GrenDesb is offline   Reply With Quote
Times are GMT -7.   It's 10:57 PM.
