Old 01-24-2013, 03:11 PM   #1
wiseblood OP
Hall Monitor
wiseblood's Avatar
Oddometer: 12,733
Switched accessory plug -- anyone go to 15A?
So, now that it's superfuckingcold in the Northeast I'm running my heated jacket liner and gloves. UNFORTUNATELY, that puts me just very SLIGHTLY over the 10A budget (prolly 10.5A).
Here's my question: Has anyone tried putting a 15A fuse into the accessory circuit on a 2007 950 SMR (or SE)?
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now."
Big Apple Tag-o-Rama Maps: Click Here!
wiseblood is offline   Reply With Quote
Old 01-26-2013, 06:04 AM   #2
Blackbert
Factory Rambler
Blackbert's Avatar
Oddometer: 1,058
On the 950 adv, they had 5amp fuses, upgraded to 10amp on the 990. I wouldn't want to take the risk of frying the wires before the fuse goes. In the shop manual there are numbers in the wiring diagrams, (i.e. yellow-red 0.5) unfortunately it doesn't say what 0.5 is. My guess: 0.5 mm˛. If so, it's rated for 11amps. I would run a 1mm˛ cable straight from the battery, with it's own fuse (and switch), powerconnector where you want it, can also be used for batterytender, ...
my 2 cents ...
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy)
want to save on Smugmug? use this code (VoUO8M1ukmnMY)
Blackbert is offline   Reply With Quote
Times are GMT -7.   It's 04:01 AM.
