Old 01-30-2013, 10:03 AM   #1
duck OP
duck's Avatar
Oddometer: 10,403
What do you think of my gash?
Was planning on going for a ride today. Checking the tire pressure in my Avon Azaro rear and knew something was amiss when it read 12.5 psi. Upon inspection I found this inch and a half gash with strands of the steel belt poking out.
Does this look like a manufacturing defect or did I just get unlucky and run over a tank spike? :shrug
duck is offline   Reply With Quote
Old 01-30-2013, 10:39 AM   #2
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,656
No cords showing but sure got cracks just like that on near new Avons before.Twice and one tire had 2 of them cracks. And I wasn't the only one back then.They were so similar in appearance that we did not believe it was riding over road hazards. Not radial so no steel showing.
Last one got me home but I was way back east when I found that. Did not like checking it a few times a day to make sure it did not get worse. Never bought Avons again.
Have tools, will travel!
Old 01-30-2013, 10:52 AM   #3
duck OP
duck's Avatar
Oddometer: 10,403
The steel being cut and exposed leads me to believe that it was a road hazard.
I don't have much choice in replacing it as it's the only radial rear that I've found that comes in a 140/80-17. I know of quite a few K1100LT riders who have have good luck with this rear.
Old 01-30-2013, 12:21 PM   #4
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,855
If you can host a 150 the Shinko 712 has been a very good tire on my V-Strom. And the price is right. I use it primarily for commuting and such.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 01-30-2013, 04:33 PM   #5
BigEasy
BigEasy's Avatar
Oddometer: 1,757
Yeah with the name of this thread it ain't gonna go south very fast
All who wander are not lost
"Play hard and FLOOR IT" Stevie Ray Vaughan
just remember: the only difference between genius and stupidity is genius has limits
BigEasy is online now   Reply With Quote
Old 01-30-2013, 05:15 PM   #6
duck OP
duck's Avatar
Oddometer: 10,403
The tire guys at Chaparral said it was definitely caused by something metal and nasty that I ran over.
Was thinking on the way home that I should've just stuffed a sticky string in there.
It's kind of puzzling that whatever it was it gashed my rear right in the middle of the tread but my front tire has no damage at all.
duck screwed with this post 01-30-2013 at 05:45 PM
Old 01-30-2013, 05:42 PM   #7
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,264
That's actually very common -- so are nails/screws/sharp objects stuck in the rear tire but not the front.
Why? Said object will be laying flat or on its side in the road. Front tire runs over it and kicks it airborn, essentially standint it on end just in time for the rear tire to impale itself on it.
I'd be fairly certain you ran over a small flat piece of metal that was lying innocuously on its side -- front tire kicked it up sideways and the rear tire got gashed up on the sharp edges.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 01-30-2013, 05:47 PM   #8
duck OP
duck's Avatar
Oddometer: 10,403
Yep, that makes sense.
Old 01-30-2013, 05:48 PM   #9
duck OP
duck's Avatar
Oddometer: 10,403
Done on purpose. It's the best way to get attention around here.
Old 01-30-2013, 06:12 PM   #10
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 11,164
Forgot this wasn't Jo mamma....
Useful answers here.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 01-31-2013, 02:51 PM   #11
BigEasy
BigEasy's Avatar
Oddometer: 1,757
Nice work
Times are GMT -7.   It's 12:17 AM.
