Old 01-25-2013, 11:06 AM   #1
seniorasi OP
Oddometer: 816
Fuse block
Not having much luck with searches these days so humble apologies in advance. I've ordered a toolbox for the R12GSA that will attach inside the right pannier bracket and will require removal of the rear mudguard. I'll be eliminating the factory tool kit, using the term loosely, and adding a fuse block in it's place. Any suggestions for brand, model?
seniorasi is offline   Reply With Quote
Old 01-25-2013, 11:15 AM   #2
crowos
crowos's Avatar
Oddometer: 20
Fuzeblock is a good one
I have this http://www.fuzeblocks.com/ installed under my seat and like it.
crowos is offline   Reply With Quote
Old 01-25-2013, 11:36 AM   #3
seniorasi OP
Oddometer: 816
That does appear to be a nice one. Anyone used this brand and can reflect on longevity?
Old 01-25-2013, 11:51 AM   #4
crowos
crowos's Avatar
Oddometer: 20
I've had it installed for about the last 2 years with no issues. Its a good peice of kit. I run my usb power outlet, heated jacket liner, heated seat, and my charger for my phone from it.
Old 01-25-2013, 12:07 PM   #5
seniorasi OP
Oddometer: 816
Exactly what I had in mind! Done deal, I'll order one and thank you for the input.
Old 01-25-2013, 12:19 PM   #6
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 3,048
I AM such a cheap fkr, i just use inline fuses. $2-$3 or less each
1 for my lights
1 for my 2 acc plugs for heated cloths
1 for my other 2 acc plugs for my GPS and Phone.
$80 for a fuse block with parts that can fail... no thanks
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything.
-- Charles Kuralt
I never plan a ride, just the destination and that's always subject to change.
STUFF2C is offline   Reply With Quote
Old 01-25-2013, 12:28 PM   #7
Saluki9397
Saluki9397's Avatar
Oddometer: 30
I use the same fuse block. I have had it installed for about 6 months. It is easy to install and I have no problems with it. good luck
Saluki9397 is offline   Reply With Quote
Old 01-25-2013, 01:27 PM   #8
Dan-M
Dan-M's Avatar
Oddometer: 1,045
Same here. Compact and well made.
Dan-M is offline   Reply With Quote
Old 01-25-2013, 01:41 PM   #9
GB
Mod Squad
GB's Avatar
Oddometer: 56,850
this one's even better:
http://advrider.com/forums/showthrea...638076&page=11
Old 01-25-2013, 01:55 PM   #10
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,752
1 for my lights
If it works for you, and you're content with a nest of inline fuse holders, more power to you. The better fuse blocks incorporate a circuit that lets you choose switched or always on power for your accessories.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 01-25-2013, 03:28 PM   #11
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,803
Originally Posted by GB View Post
Nice unit, but not as flexable as the fuzeblock, and almost twice as expensive.
I like that the Fuzeblock has the ability to switch between fuzed and not fused, and you can set your fuses at whatever you need. Further, if the relay fails, you can switch back to a simple fused connection.
Quick install on my friend's bike, and I have one for mine as well.
Jim
Old 01-25-2013, 05:31 PM   #12
atgatt
atgatt's Avatar
Oddometer: 105
I have had a fuzeblock for 2 years with no issues. It's a good product but if I had to do it again, I would get the eastern beaver fuse block. Just seems more durable and less prone to weather/water etc...
http://www.easternbeaver.com/Main/Wi...PC-8/pc-8.html
atgatt is offline   Reply With Quote
Old 01-25-2013, 06:04 PM   #13
steve_k
steve_k's Avatar
Oddometer: 1,063
I have one on both rides and so far so good. Easy install.
steve_k is offline   Reply With Quote
Old 01-25-2013, 08:56 PM   #14
guitarin
Oddometer: 176
I used a 6 circuit fuse block from Autozone ($7.00) and a Ford fuel pump relay ($4.00). Fits and works perfect, 20k miles.
guitarin is offline   Reply With Quote
Old 01-25-2013, 11:24 PM   #15
duck
duck's Avatar
Oddometer: 10,403
About $5:
The electrons don't care how much I paid for it.
duck is offline   Reply With Quote
Times are GMT -7.   It's 06:54 PM.
