Old 01-26-2013, 06:29 AM   #16
a2ronm
a2ronm's Avatar
Oddometer: 428
Originally Posted by seniorasi View Post
That does appear to be a nice one. Anyone used this brand and can reflect on longevity?
4+ years, over 50,000 miles on my Kawasaki Versys without a single problem. Put one on my sons VStrom and will probably put one on my latest bike too.
2005 Ural Gear Up
2008 Kawasaki Versys
2008 Ducati MTS 1100S (RIP 12/2014)
a2ronm screwed with this post 02-12-2013 at 07:43 PM
a2ronm is offline   Reply With Quote
Old 01-26-2013, 08:26 AM   #17
Yaatri
Oddometer: 20
Originally Posted by duck View Post
About $5:
The electrons don't care how much I paid for it.
Neither do I. Where did you get that>. Suddenly, prices of fuse blocks seems to have gone up as much as $20 to$40. The cheapest one I have seen is one by Hella on Amazon.
P.S.Found one at Pepboys.
Yaatri screwed with this post 01-26-2013 at 09:19 AM
Yaatri is offline   Reply With Quote
Old 01-26-2013, 12:12 PM   #18
guitarin
Oddometer: 176
Bussmann products. Cheap and readily available.
guitarin is offline   Reply With Quote
Old 01-26-2013, 02:22 PM   #19
Dan-M
Dan-M's Avatar
Oddometer: 979
About $5:
This is handy, small and cheap but if you want some of your accessories switched on and off with the ignition, especially on a canbus system, a box equipped with a relay is the way to go.
Dan-M is offline   Reply With Quote
Old 01-26-2013, 08:17 PM   #20
racer1735
Oddometer: 358
I have this fuse block from Blue Sea. I'm not an electrician by any means, and this thing is simple to add circuits to. Fairly inexpensive too. I have the 12-circuit model. I fixed the block to an old CD case, which fits in the tail of my bike. Makes it easy to grab if I need to remove it, and give is a stable base. Blue Sea are 'marine' fuse blocks so they can theoretically hold up to the elements, if necessary.
racer1735 is offline   Reply With Quote
Old 01-28-2013, 02:13 AM   #21
duck
duck's Avatar
Oddometer: 10,403
Search on "raised atc four fuse"
duck is offline   Reply With Quote
Old 01-28-2013, 06:50 AM   #22
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 4,717
I've used these with success and velcroed it down. I used the 6 circuit, cost about 30 bucks.
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 02-01-2013, 03:50 AM   #23
sierraoffroad
sierraoffroad's Avatar
Oddometer: 1,329
there was a guy on here who was doing a group buy on those a few years back. it was either here or stromtrooper. it's a do it yourself kit. you will need a goo set of crimpers.
It's a Jungle out there.
2007 Blue Weestrom
2004 Yamaha Wr250f
sierraoffroad is offline   Reply With Quote
Old 02-02-2013, 09:06 AM   #24
GHO100
Crazy George
GHO100's Avatar
Oddometer: 1,055
I'm trying out something a little different:
Link here: http://goo.gl/Nj5gG $25
Has 2 inputs, 1 ground hub. 14 miniblade fuse outputs (7 each side) and 7 ground inputs.
Roughly 4x3x1 inches.
2012 BMW R1200GS
www.TeslaLEDS.com
www.NYMSTF.org - Support NY Riders!
GHO100 is offline   Reply With Quote
Old 02-03-2013, 09:12 AM   #25
brasters
Just Bob
brasters's Avatar
Oddometer: 126
Originally Posted by atgatt View Post
I have had a fuzeblock for 2 years with no issues. It's a good product but if I had to do it again, I would get the eastern beaver fuse block. Just seems more durable and less prone to weather/water etc...
http://www.easternbeaver.com/Main/Wi...PC-8/pc-8.html
+1 on the Eastern Beaver, very well made and designed for hard envirements, as opposed to the "Fuzeblock". I have gone through two of them, they both broke at the same place, the little terminal block for power input, they are just soldered onto the circuit board as opposed to a through circuit board bolt on the Eastern Beaver fuseblock.
Just Bob
2014 Super Tenere ES, 07 R1200GSA, 03 K1200LTC, 99 K1200LTC, 89 Venture Royal, 83 Suzuki 1100 ES, 82 Honda CB 900F, 81 Suzuki 750 E
brasters is offline   Reply With Quote
Old 02-03-2013, 06:49 PM   #26
mikemaycga
mikemaycga's Avatar
Oddometer: 56
The problem with fuse blocks is water. All of these have exposed copper and electricity and metal don't mix well. I will be replacing the fuze box on my bike with a Rowe electronics PDM60. This device is fully enclosed in epoxy and if/when a circuit pops, you can restart it by powering the bike on and off. No fuses to replace or run out of in the middle of no where. No worries of water getting into the electrics. A few bucks more but worth it.
http://www.rocketmoto.com/index.php/...er-panel.html#
Sent from my iPad using Tapatalk HD
mikemaycga is offline   Reply With Quote
Old 02-03-2013, 08:22 PM   #27
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,243
In my experience, none of the fuze blocks I have used have ever had an issue with water. The little bit that get's anywhere near the fuze block is minimal.
Jim
PS Then again, if you place it on the front of your windscreen, and ride in the rain, you might have issues.
Old 02-12-2013, 05:19 PM   #28
seniorasi OP
Oddometer: 816
Originally Posted by GB View Post
Still haven't pulled the trigger on the Fuzeblock yet... I did check the PDM 60 out. It's cool that the unit is sealed. The not so good is it's a sealed unit. Extra wires are a pain. The programmable thing is cool but not into paying a dealer to do something I should be able to do with my laptop. Thanks for the input.
seniorasi is offline   Reply With Quote
Old 02-14-2013, 01:27 PM   #29
VFR
VFR's Avatar
Oddometer: 740
I had one of the Fuzeblocks back when Curt was making them. Nice piece but the downside may be that the total capacity of the block is 30 amps. The desirable feature is the choice of switched on non-switched outputs. I bought it to look at it but ended up giving it away.
Personally, I prefer the Centech AP-1 or AP-2. These can handle 60 amps total. The difference is the AP-1 can be either switched or non-switched depending on how you set it up. The AP-2 is divided with 3 fuses for switched and 2 fuses for non-switched, or reverse, depending on how you set it up.
I have also used the Blue Sea blocks. Usually the smaller six circuit without the ground connections in the panel. These beauties can take a TON of current. Again, they are either switched or non-switched--can't have both on the same panel.
I also have one of Eastern Beaver's panels. Bought that one just to check it out but haven't used it yet.
Besides bikes, I wire cars--hot rods, customs, restorations--and sometimes use one of these panels as an auxilliary panel. The Blue Sea panel was used on a Bonneville racer.
Larry
If it ain't fun, I don't do it!!!
Stuff - I need more Stuff....
VFR is online now   Reply With Quote
Old 03-02-2013, 06:10 PM   #30
seniorasi OP
Oddometer: 816
I went with the FUZEBLOCKS brand. Order placed so I'll post some pics of the install.
Times are GMT -7.   It's 07:38 PM.
