Old 01-25-2013, 02:33 PM   #1
lstzephyr OP
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
Xr650r that won't start
Alright gents I need a couple extra opinions on my current situation. I can't get my bike to start again after it died a few months back. It was running fine on a new engine rebuild until I turned into the bar and it sputtered and died. I figured it was low on fuel and didn't bother with it. When I went to leave I couldn't get it to start. It hasn't started since.
I have:
  1. New fuel
  2. new petcock
  3. new fuel line
  4. new spark plug
  5. Checked for spark(has spark on spark tester and when holding plug to head)
  6. Top end is fresh(new piston/rings/valves/seals/tensioner/cam chain etc less than 8 engine hours ago)
  7. Checked cam chain, cam timing, valve clearance(all in spec)
  8. Checked wiring
  9. Cleaned the carb thoroughly ( tore it down completely and had it dunked over the weekend by the local machine shop)
  10. Attempted bump starting (the bike only locks the back tire, I need a bigger hill)
  11. pulled cylinder off and checked valves/piston. Everything looks fine.
  12. New coil
  13. Swapped cdi with ebay xr400 cdi that was stated as pulled from running bike
  14. I'm working in a 70 degree shop so temp is not an issue.
After the carb cleaning it would periodically fire 3-4 revolutions then die. Barely more than the spin of the kick. Starting fluid has no effect other than raising the amount of backfires.
I swapped on my recently rebuilt HS40 Carb (mikuni tm40) to see if it was still a plugged pilot circuit. No change except it will fire 3-4 revolutions every other kick now. I think that is because the accelerator pump allows me to toss fuel in. I didn't want to add another variable(new carb) but I wanted to rule out the stock carb as the issue.
So my thinking is that it could be one of a few things:
Unlikely:
  1. Loss of compression(it is still more difficult to kick than before rebuilt so it appears to have compression)
  2. CDI(only failure symptoms I can find say that there is no spark with a dead cdi, I have spark so probably not cdi)
  3. Stator(the wires to the stator appear fine and I could not find any cuts or abrasions)
  4. Plugged pilot circuit in both carbs (I checked both thoroughly, especially the hs40)
  5. coil(new coil)
Probable:
  1. Misadjusted idle in both carbs (I have moved the idle screws around while trying to start it)
  2. automatic decompressor
  3. coil pickup
My current thinking is that I have spark but the bike won't fire more than 3-4 revolutions so the spark may be weak or out of time.
Can the coil pickup or stator be tested? How?
Any other ideas? Any help would be greatly appreciated!
lstzephyr is offline   Reply With Quote
Old 01-25-2013, 03:37 PM   #2
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,248
Responded to in the XRR thread.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is online now   Reply With Quote
Times are GMT -7.   It's 06:18 AM.
