Old 01-27-2013, 06:18 PM   #16
chavo_dakar_bolivia
chavo_dakar_bolivia's Avatar
Oddometer: 64
Dakar issues and findings
Hello advriders!
Thanks for your comments and insight.
I want to share with all of you what has been done and used in this Dakar.
In Sardegna rally, I dnfed on the last stage, and was using a stock stator with Super B Battery and STOCK headlights.
First i had thought it were the LED lights that were causing the problem, so this theory got discarded.
The second theory of the problems were oil coolers and/or heat. This also got discarded because in Sardegna I had no oil cooler and the stator failed 100m from the start. (cold engine still).
Third theory was the Super B battery. I was using a stock battery in Dakar, and still the stator failed. So this theory is also discarded.
In Dakar, I was using a Trailtech stator with a stock battery.....and it also failed.
So I have in mind experimenting with bolting on rally accesories (tanks,navigation tower, etc etc) on a 2008 CRF450R.
Some say the gearing is too close, but I believe only 1,2,3 gear are closer. 4th and specially 5th, are better on the R model.
The weakness of the X gearing is its 5th gear...it is too tall and the engine doesnt quite pull it.
So with these clarifications, what do you think?
Thanks for the advice.
DAKAR 2015 Chavo Salvatierra Racing-Bolivia
chavo_dakar_bolivia is offline   Reply With Quote
Old 01-27-2013, 07:11 PM   #17
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,199
So when the stator fails, what happens? Does the bike completely stop running? Do the lights or instruments stop working immediately? Does the battery stop charging?
Luke is online now   Reply With Quote
Old 01-27-2013, 07:18 PM   #18
chavo_dakar_bolivia
Oddometer: 64
It is the exact same thing as if it were running out of fuel......
I was going full on and suddenly it stalls and feels like it ran out of fuel......
Old 01-27-2013, 07:30 PM   #19
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,120
Do you know how many watts your stator produces ?
Do you know how many watts you are using ?
Is you reg/rec working , properly no spikes etc etc
Have you checked for bad / loose ground contact points ,broken wires , this can produce a feed back signal and fry stators
Same with positive bad contact will cause things to over heat .
With two different stator frayed , I,d be looking at reg/rec , and ground contacts
Mudguts is offline   Reply With Quote
Old 01-27-2013, 08:26 PM   #20
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,199
Ok, so that should have nothing to do with the charging system or battery. The ignition wiring is independent of these.
It could be either the high voltage coil on the stator which powers the ignition, or it could be the timing pickup which tells the ignition when to fire. The timing pickup is usually replaced with the stator so it could be either.
In this picture the pickup is the plastic bit on the lower right with the blue and green wires going to it.
A resistance test should tell you which one is bad. I don't have a manual so can't tell you what the exact values should be. Sometimes when either part fails it will start failing when hot and work again when it cools off, then fail more often until it never works.
Old 01-27-2013, 08:43 PM   #21
Mudguts
Mudguts's Avatar
Oddometer: 2,120
Could even be the spark plug cap if its a resistor type , but it's breaking down under load , so work from the spark plug back ,
Replace plug , plug cap , there cheap and if there ok you'll have spares
Check resistance of hi-tension lead check for damage ( rub marks etc etc)
Check resistance of coil
All the data you need should be easily Googled
Old 01-27-2013, 08:50 PM   #22
Mudguts
Mudguts's Avatar
Oddometer: 2,120
Test data for crf 450 2005
Tested Plug on other motor which is oke.
Tested: peak voltage on the ignition coil should be 100 volts minimum.
My measerement after kick starting = 0 Volts.
Resistance measurement Ohm at 20 degrees celsius should be 0,1 - 0,3 Ohm
Tested: exiter coil peak voltage should be 50 volts minimum (blue terminal + white
Resistance measurement Ohm at 20 degrees celsius should be 9 - 25 Ohm
Tested: peak voltage on the ignition pulse generator should be 0,7 volts minimum.
Resistance measurement Ohm at 20 degrees celsius should be 180 - 280 Ohm
Tested: coil resistance with cap removed should be 4 - 8 K Ohm at 20c
Regards,
Old 01-27-2013, 09:35 PM   #23
rmhrc628
rmhrc628's Avatar
Oddometer: 2,594
Need to also know did you change the flywheel weight to a trail tech ?
If you have swap back to oem. TT are the first to admit that occasionally their fww really fark up.
rmhrc628 is offline   Reply With Quote
Old 01-27-2013, 10:29 PM   #24
Mike The Swede
Mike, The Swede
Mike The Swede's Avatar
Oddometer: 53
Trailtech Stator fails.
I have been there, done that. Talked to Glen Hoffman at GHR Australia, they had the same experience. They recommended to modified the original stator. I had the same recommendation from my local stator guru, chuck the Trailtech in the bin and modify the original.
I have had 450R for MX and 450X for rally, both -08, at the same time. My mods was the usual, open air box, R-exhaust (fits with minor mods), Stage 2 hotcam, Vortex CDI. Never used the R-head but was temped, R has larger valves on intake. Clocks 158 kmph
Mike The Swede is offline   Reply With Quote
Old 01-27-2013, 10:45 PM   #25
doyle OP
RallyRaidReview-ing
doyle's Avatar
Oddometer: 23,591
http://crfsonly.com/howto/gearing/mo...calculator.php
RallyRaidReview - @RallyRaidReview
doyle is offline   Reply With Quote
Old 01-28-2013, 03:57 AM   #26
Blur
3MTA3
Blur's Avatar
Oddometer: 4,494
Originally Posted by doyle View Post
Nice!
Why use big words when any diminutive utterance will suffice?
Blur is offline   Reply With Quote
Old 01-28-2013, 03:05 PM   #27
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,839
Chavo what gearing are you running now?
also here is a link to their wide ratio gears for the 450R
http://www.crfsonly.com/catalog/adva...s=transmission
wrk2surf is offline   Reply With Quote
Old 01-28-2013, 04:12 PM   #28
chavo_dakar_bolivia
Oddometer: 64
I ran 15/50 for most of the race, and 15/49 for the faster stages.......
Old 01-28-2013, 04:16 PM   #29
chavo_dakar_bolivia
Oddometer: 64
Wicked 2008 crf450r
Tomorrow I will have a 2008 CRF450R in my hands , and see if the rally accesories fit....
- In case the rear tank assembly (replaces the subframe) fits, what would be the next step to have all the electrical installations in a R model?
- I will also order the wide ratio gears from CRFs only...
And hopefully, VOILA! a 55 HP Rally bike!
Old 01-28-2013, 07:48 PM   #30
rmhrc628
rmhrc628's Avatar
Oddometer: 2,594
The rear subframe is swappable between x and r for 07-08 years
You might want to check thumper talk for the info on the wr gears. If they are the ones that bd made and marketed I'm not sure they'll stand up to Dakar abuse...
You might want to custom make a legs case cover so you can install a bigger stator. Lack of space is issue.
Times are GMT -7.   It's 03:34 PM.
