Old 01-26-2013, 06:25 PM   #1
Steinbuck OP
Oddometer: 28
Thumb LS2 Dual-sport Helmet
Initial impressions of the LS2 MX453 helmet.
I first tried this helmet after getting it from someone who works for LS2 and so far I'm pretty pleased. The biggest advantage was that it fit my long-oval head--Jean-Luc Picard and I have the same head shape. Most of the other DS helmets (Arai in particular) were too round and I'd end up with that nasty red spot on my forehead after a ride.
The helmet's shell is fiberglass, the liner's completely removable and washable, strap uses 2 D-rings. Speaking of the neck strap, when the strap is closed (tightened against my neck) the two ends cling to each other with some subtle hook-and-loop sections. I'd never had a helmet before that did so; it does keep the strap ends from moving around or flapping in the wind but took me a while to get used to the "additional" step when removing the helmet.
There are vents on the chinpiece and forehead. I haven't had the chance to really test them out but the forehead openings are so small that I don't expect too much air to flow there. The visor has a fairly good stock position, probably a little higher than an MX helmet and is not adjustable. Graphics are good-looking and are under the clearcoat. The shield is a friction-fit and will stay in almost any position; it was easy for me to leave it open a crack if I wanted extra ventilation. There's some very slight shield distortion around the nosepiece that I noticed only when glancing down to my bike gauges. The interior fabric is very comfortable. Cheek pads are quite thick so I wanted to keep my eyes closed when the helmet came on and off.
It's very quiet on the road for a helmet of this style. I'm sure that was helped by my being able to use a smaller shell since the fit was correct for my head shape--in most other helmets I use a Medium; with this one I use a Small.
Overall, I'm impressed with the quality and fit. It's a keeper. Retail price is $160-170, I think, which is pretty good considering that it's rated both DOT and ECE.
One other bit of trivia: LS2 helmets were used by many of the top riders in the Dakar race, including the winner!
Not everyone who wanders is lost. (J.R.R. Tolkein)
Steinbuck is offline   Reply With Quote
Old 01-27-2013, 10:27 AM   #2
Steinbuck OP
Oddometer: 28
Forgot to mention that the official Web site is here:
http://ls2helmets.us/_live/slideshow...f_Road_Helmets
Old 06-25-2013, 09:04 AM   #3
zeeede
Oddometer: 1,004
It's been a few months... still like it? Can the shield accomodate goggle straps?
zeeede is online now   Reply With Quote
Times are GMT -7.   It's 12:32 PM.
