01-30-2013, 02:14 AM
#46 |
Oddometer: 244
I have to agree with Johnf3 it wasn't about the power increase as much for the ease of maintenance.Anyone who has a 950 SE and are riding them in the conditions they were designed for I imagine like me were sick of pulling the bloody tank off and cleaning the useless pre cleaner after every dusty ride.
As long as you take your time fitting it, mine had to have a slight die grind on the under side of the base plate (no big deal) to get it sitting flat and snug.Do yourself a favour and get a head to wind jetting kit and SAS blanking plates RC8 velocity stacks as well as a couple of packs of filter skins(6) is good I have two on all the time. The best part is when you get home from a dirty ride just pull the seat off reach in peel the top skin off put a freshly oiled skin on and your good to go I reckon I could do it in about 30 seconds seat off seat on and if you need to get main foam filter out you can do that too without pulling the tank off.But when putting the filter dome back in making sure the hinged side is clipped under properly and it sort of clicks over the dusses clips to seat and seal properly if you install this filter yourself you will understand better how it goes together and then will be able to do it all with the tank on. Power increase it dramatic as well mine hasn't been on the dyno since and there is no need the fuelling is spot on no flat spots no more popping and the thing wheelies off the throttle in 3rd gear! Finally I believe if this filter is installed correctly you won't have any sealing problems and will turn your 950 or 990 into a great dirt bike money well spent I say Cheers Emu
Its NOT a race I just want to get there first emuooz screwed with this post 01-30-2013 at 02:42 AM |
01-30-2013, 02:39 AM
#47 |
Rookie
Oddometer: 265
Hi!
As I am using the CPF filter on my 990 for some time, I have some comments: First the claimed hp's can be verified by me. Only the filter is giving something between 8-9 hp's and with some extra tuning with Tuneboy I am now in 11,3 hp's more compared to stock. So the filter works and my bike rips more than ever. About the fitting issue, I have the same issues. This is the most problematic airfilter I've ever owned to be fitted as it is a PITA to get aligned. If I get one tab to match up with the fastener, the other is not aligned and vice versa. But I think the whole problem lays on the left side on the baseplate where the filter is locked down to the base trapped under this 'lip' on the filter. It's really hard to get the filter far enough to the right side under this locking lip, ie get the filter enough to the right side. If you can do that, the tabs aligns much better. So in the process the vendor mention with alignment done with some machines, I am pretty sure the filter frame and the base match up perfectely, but when trying to install it, it will be positioned slightly to the left side making the tabs to be mistaligned slightly. I have been thinking about using some heat to raise this 'lip' a bit to get the filter more to the right side, but then I am a bit worried if I will loose downwards clamping force and filter not so tight against the base. Hmmm..... So to CPRFAB: This is a fact and I have used plenty of time in my garage trying to find the best and quickest method to fit it. It's not easy and some swearing is involved every time. Your product is doing the job in excellent level, so I am a happy customer. I just wish it could be a bit simpler to install it as bringing a spare filter for longer trips (if headed to very dusty conditions) is not an option like it is now. I can get over and live with it and therefor I have not contacted you about this 'issue'. I have the new updated baseplate and using the prefilter if needed. Breather hos vents outside the box. Just wanted to give some verification to the OP and some others that there are others also with the same issue. olec screwed with this post 01-30-2013 at 02:45 AM |
01-30-2013, 04:55 AM
#48 |
Gnarly Infantry
Oddometer: 880
To clarify my ITG filter is not easy to get aligned like Olec says about the CPR. Because my project use the RC8R engine i don´t have the room for the airbox anyvvay and i vvould like to salvage as many ponys as possible. CPR/ITG same same, imho. I still think its a great product and it fits perfect.
01-30-2013, 06:53 AM
#49 |
Life is a trip
Oddometer: 3,102
ITG and CPR have slight difference in dimensions.
There is a slight difference of 1,5cm IIRC
ITG width=149mm , length=298mm, height internal/external : JC30/65 = 65/90 this fits in and JC30/100 = 100/125
There is always a reason!! |
01-30-2013, 07:49 AM
#50 | |
Oddometer: 38
We are very close to getting into KTM hard parts as some factory AMA teams are currently testing our product and if that happens the only change will be an orange frame instead of red. CPRFAB screwed with this post 01-30-2013 at 08:26 AM |
01-30-2013, 08:44 AM
#51 | |
Oddometer: 38
01-30-2013, 09:04 AM
#52 |
Oddometer: 38
Easy Hint
We will give an easy tip here on the alignment and this will help tremendously as you will see the ease of snapping it together in the video below. Make sure the left side clip (Bottim tab in the video) is centered by sliding it back and forth to find the middle. It will clip right in. You can easily do this from the top of the bike. If one ear doesn't quite fit in, slide the entire filter the other way (Front to back of vice versa) slightly to align it and it will pinch right in with 2 fingers.
01-31-2013, 06:41 AM
#53 | |
Wheelieless
Oddometer: 2,903
You wanted nothing more than to tell all of us how awesome you are. Well I don't know you and your contributions to this discussion are useless. I am interested in what the manufacturer of the product I purchased has to say. You, on the other hand, haven't brought any product to the market, so none of us can judge its' worthiness here. You sound like you have sour grapes because you can't get anyone to make your aluminum plate design because it's a heat sink. |
01-31-2013, 07:17 AM
#54 |
They call me......Ronski
Oddometer: 556
Oh, Snap!
Ronski Enduro Racer & Google Earth Adventurer |
01-31-2013, 08:44 AM
#55 |
SE990R
Oddometer: 1,928
I don't think Chris (CPR Fab) needs to defend himself...
~ Ken |
01-31-2013, 12:41 PM
#56 | |
Oddometer: 858
For not having any commercial interest here, you seem pretty sure of yourself when burning down this man's product.
Ducati S4 916 is history. KTM 950 SM, my main squeeze now. 1970 CT-70 And now, an XR75, |
02-01-2013, 03:25 AM
#57 |
Oddometer: 316
My CPR filter even seals upside down here in Oz. Brilliant product, does as advertised and the noise between my legs is enough to get off on.
Rick |
02-01-2013, 09:32 AM
#58 |
I'll Go Second...
Oddometer: 3,667
Everything else aside....
I have never seen CJ Racer sell and use a product he doesn't believe in or rely on... He sells them....he uses them.....I'm in.....
MTS 1200 Pikes Peak....Touring Beast 950SE......Desert Beast 'Berg 570..Trail Beast |
02-01-2013, 09:47 AM
#59 |
KOTW 2010 Finisher
Oddometer: 2,978
TMI. Clearly you can't use a suede seat cover...
Brents347 Truckee, CA. 07 Yamaha R6 07 KTM 950 Super Enduro 04 KTM 250exc- plated two-stroke |
02-01-2013, 07:50 PM
#60 |
Oddometer: 858
I'm not from North Carolina.
