Old 01-27-2013, 08:44 PM   #1
Kevin K OP
Oddometer: 64
wire connectors
I want to make a few sano wire connections for signals and tail lights. On the rear I want to run a versa light in addition to to signals and a tail light,so ill have to split off of the feeding wires. Where do I get water proof connectors ? I don't want to use home depot bullet connectors . I am so impressed by the builds I see on here. I know I'm in the right company to askThanks
Kevin K is offline   Reply With Quote
Old 01-27-2013, 08:50 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,490
Positaps are what I use. www.cyclenutz.com
http://www.cyclenutz.com/search.asp?...x=0&search.y=0
They won't damage the wire, and are totally reversable.
Jim
Old 01-27-2013, 08:55 PM   #3
MaestroPNW
Me!
MaestroPNW's Avatar
Oddometer: 97
I used this to make a disconnectable harness for the taillights in the top box http://www.wiringproducts.com/contents/en-us/p672.html
Ground, Tail, Brake, Left and Right turn signals, with one lead left spare.
I also have aux lights on my side boxes, and they are connecting using 4-flat connectors (ground, tail, brake and 1 corresponding turn signal)
If you are talking about how to tap into the factory wires, I'd see if factory connectors could be obtained to make a plug-in harness to avoid splicing at all. E.g. for V-Strom, http://www.easternbeaver.com/ sells tail lights harness adaptor.
MaestroPNW is offline   Reply With Quote
Old 01-28-2013, 06:34 AM   #4
Kevin K OP
Oddometer: 64
Thank you guys . I knew I came to the right people
Old 01-28-2013, 07:02 AM   #5
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,796
I've been having success with the solder splice connectors that are available at Home Depot. They have a ring of low temperature solder and adhesive within a heat shrink tube. All you need is a heat gun capable of >600f temperatures.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 02-03-2013, 04:46 AM   #6
Sharkguy
chain lube applier
Sharkguy's Avatar
Oddometer: 208
Ditto what Twilight said. I occasionally wire up 12 volt submersible pumps to transport aquarium fish, sharks, and stingrays.These pumps have to be reliable and sometimes run for days, depending on circumstances of transport. Those are the type of connectors I use. I get them from McMaster-Carr. I also use the heat shrink tubing from them that has a sealant liner. Using both would be a bit of overkill on a bike but there are applications for both.
"Took a look down a Westbound road,right away I made my choice. Headed out to my big two wheeler I was tired of my own voice. Took a bead on the Northern plains and just rolled that power on. "
Bob Seger
Sharkguy is offline   Reply With Quote
Old 02-03-2013, 05:00 AM   #7
Laconic
Anodyne
Laconic's Avatar
Oddometer: 18,388
+1 on the Positap connectors JVB mentioned.
Laconic is offline   Reply With Quote
Times are GMT -7.   It's 01:59 AM.
