Old 01-30-2013, 07:08 AM   #16
mdlak
Oddometer: 201
mdlak is online now   Reply With Quote
Old 01-30-2013, 07:25 AM   #17
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,470
Originally Posted by mdlak View Post
Process look familiar Mike?
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 01-30-2013, 07:41 AM   #18
mdlak
Oddometer: 201
Haha! Love this kinda stuff. If I find the right bike, I'll do it again.
Looking good FP!
Old 01-30-2013, 08:01 AM   #19
Kawidad
Kawidad's Avatar
Oddometer: 4,851
I've been waiting for this. I'm in.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 01-30-2013, 08:10 AM   #20
fleshpiston OP
fleshpiston's Avatar
Oddometer: 599
Looking good FP!
Thanks man! It was your fork swap thread that inspired me to go this route, you made it look too damn easy!
Originally Posted by Brandon View Post
I am pretty sure you are right. I had an Applied on a XR a few years ago and from what I remember it looked exactly like the one pictured.
Originally Posted by Unstable Rider View Post
Howdy Flesh,
Appears we are maybe neighbors. Great post, I have a KLR in the garage meself.
~Subscribed.
Howdy neighbor, I'm a little South of the metro ...... here to be exact -
Thanks to all that are following along, gives me some inspiration
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 01-30-2013, 12:34 PM   #21
Beezer
Oddometer: 5,793
nice. but as far as swapping forks goes... mebby not worth it. I put YZ forks on mine & ran it for a year. cushy ride but with the fat USDs you lose some travel lock to lock. you also lose the stock instruments, no loss... I kept the Acewell gage when I switched back to the stock forks with Ricor valves. the Ricors in front & Moab on the back fix the ride pretty well... it'll give you everything you need unless maybe you are jumping it. something to consider. in fact I've ridden side by side with my friends 640A & it 's really close... even he agreed, though most orange guys will contend that is not possible and are outraged by the suggestion.
Beezer is offline   Reply With Quote
Old 01-30-2013, 01:03 PM   #22
bobfab
bobfab's Avatar
Oddometer: 1,428
me too!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 01-31-2013, 07:50 AM   #23
fleshpiston OP
Oddometer: 599
Originally Posted by Beezer View Post
nice. but as far as swapping forks goes... mebby not worth it. .
Now you tell me!
You're probably right, I guess I'll find out this spring.
As far as the steering lock goes.... I've heard people complain about it that have done the swap and I just don't see it as being an issue. I modified the steering stops, which I'll cover in the next couple posts, so I'm only losing a couple degrees of lock. The only time I can see this being an issue is making a u-turn on a really tight trail. If you're doing that often on a KLR you might be on the wrong bike?
SRX600
SRX250
SR500
KLR650
Old 01-31-2013, 08:24 AM   #24
fleshpiston OP
Oddometer: 599
So time to make the gold springy things fit the red shiny thing.
Time to visit my friend Ted. Ted is equal parts genius and artist. It's good to know people like Ted.
The Yam steer tube is too short so just swapping bearings isn't an option, the stems need to be swapped.
so apply a little heat .........
Press out the old ..........
Here you can see the difference in length.....
A spacer could be made to adapt the the pieces but Ted decided to add weld to the tube.......
Then turn it back down to the correct diameter on the lathe .........
A top spacer was made up......
We also machined the bearing land to accept stock KLR dust seals as the aftermarket ones are a joke ........
And after a few hours work we end up with this....... all pretty straight forward if you have the tools or know people that do.
Thanks Ted!
SRX600
SRX250
SR500
KLR650
Old 01-31-2013, 10:56 AM   #25
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Thanks Ted!
You said it right otherwise it can be a real pain... looking forward to the rest of the buildup.
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 01-31-2013, 11:02 AM   #26
Rot Box
Oddometer: 212
Cool. Looking forward to updates
94 ATK 605DSES - 84 Honda CR500R - 81 Honda XL500S
Rot Box is offline   Reply With Quote
Old 01-31-2013, 11:57 AM   #27
fleshpiston OP
Oddometer: 599
Getting back to the steering lock issue....
My solution was to remove the stock stop on the frame and make one that's compatible with the Yamaha triple.
This is all hacksaw and hand file (I'm no Ted)
I had my bro brass braze it to the frame so it wouldn't distort the head tube with excess heat.....
Then I mocked it up with shop vac tubes and checked clearance on the left
and on the right ....
check it, grind some off, check it again, grind some off, check it again, grind, check, grind, check, etc etc etc
As mentioned before I did lose a few degrees of turning radius but I really don't see it as a deal breaker. Only an issue when making a super tight u-turn or maybe when moving it around the garage. Even then, worst case is that it becomes an 8 point turn instead of 6
I actually rode for several weeks with little plastic blocks taped to the stock stops to limit the lock and test it out. Not once did I miss the extra lock.
SRX600
SRX250
SR500
KLR650
Old 01-31-2013, 12:46 PM   #28
KustomizingKid
Oddometer: 678
A local guy building a KLR.... I am starting my build this weekend
KustomizingKid is offline   Reply With Quote
Old 01-31-2013, 08:47 PM   #29
ProZac235
Oddometer: 62
Awesome
ProZac235 is offline   Reply With Quote
Old 02-01-2013, 03:24 AM   #30
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,589
nice job on the fork swap, having the tools and knowledge to use them are key
However, I am not complaining because I know that I am probably better today then I will be tomorrow, so I try and enjoy every day as it comes, and stay determined to live well and be appreciative of what I still can do..."Stromsurfer"
PWRCRZR is offline   Reply With Quote
Times are GMT -7.   It's 07:29 PM.
