Old 01-28-2013, 07:54 AM   #1
skidrow OP
skidrow's Avatar
Oddometer: 24
how to fix a puncture in tank
i am sure i am not the first so i punctured my acerbis plastic tank. it is a really small hole about the size of a pen tip. how do i fix it. thanks for the input and saving me some money
skidrow is offline   Reply With Quote
Old 01-28-2013, 08:50 AM   #2
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,329
Big wood screw with a rubber washer
Seriously though,,you can get it plastic welded,,,not sure if that will cause cracking later though at that spot..
B
techforlife is offline   Reply With Quote
Old 01-28-2013, 02:08 PM   #3
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,179
Here's 4 ideas:
- Call Clarke and ask them for a suggestion.
- Epoxy the hole with fuel proof epoxy, try to hit it from both sides if possible.
- Take some plastic shavings from another area of the tank and carefully melt (drip) it onto the hole or use a soldering iron to swirl it into the hole.
- JB weld (similar to the epoxy solution)
*** make shure it's totally clean ether way
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 01-28-2013, 03:38 PM   #4
Speedo66
Transient
Oddometer: 6,815
Rough it up and put some 2 part Marine-Tex on it.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 01-28-2013, 03:48 PM   #5
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
Fuel proof epoxy would be great, JB Weld perhaps. Either way, make sure the tank is empty and clean. Highly highly recommend several rinse cycles with the garden hose.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Times are GMT -7.   It's 06:33 PM.
