Old 02-26-2013, 08:38 AM   #1
Benesesso OP
Benesesso's Avatar
Oddometer: 9,898
Which Loctite To Use?
Yo, Dirty_Sanchez,
Just discovered why the headlight popup motor on my old Toyota MR2 quit working. The internal spline on the steel crank arm stripped, "right to the bone". Was a surprise, as the external spline on the output shaft was like new. I think both parts are soft steel.
With bolting, the slightly larger internal threads of a nut are stronger than the bolt threads, for the same steel strength.
Anyway, getting another motor soon. Plan to remove the crank arm and use a very high shear strength adhesive on the 3/8"spline. Being a former KLR owner, I have saved a few red bottles of various Loctites, including the old red "Stud Lock" and some green "High Strength Retaining Compound" #635. The gap will be very small.
Which one of these will be stronger in shear? Um, BTW, they're both ~30 years old. Dixie.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 02-26-2013, 10:21 AM   #2
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,199
Use the LocTite web site to send a request for technical info. You'll get a response from one of dirty's cohorts. Chances are it'll be the same info you'd get from dirty. If you're not in a rush, he may eventually see this thread.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 02-27-2013, 05:58 AM   #3
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 3,028
Bene- For basic spline repair on what I suspect cheapo pot metal, I'd go the route of something called 660 Quick Metal. It comes in a grey toothpaste-type of tube. Using a threadlocker in this sort of fix isn't going to work very well at all based on your description.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is online now   Reply With Quote
Old 02-27-2013, 09:14 AM   #4
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,934
Oooh! I got a question too. What is the shelf life of the Lock tite 242 in the big bottles? We have some old stuff and I wonder if the stuff will still work if it's 5 years old...
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 02-27-2013, 12:30 PM   #5
Benesesso OP
Benesesso's Avatar
Oddometer: 9,898
Dirty
Thanks. The parts are soft steel, not "pot metal" (usually zinc alloys). I think I'll just epoxy the new spline.
Old 02-28-2013, 05:43 AM   #6
dirty_sanchez
Dirty_Sanchez
Oddometer: 3,028
Officially-it's past it's use by date of two years old.
Anecdotally-I've successfully used 20 year old Gasket Eliminator.
Here's our very own Loctite thread where we try to keep all related questions:
http://advrider.com/forums/showthread.php?t=265016
Dirty
Old 02-28-2013, 10:58 AM   #7
foxtrapper
Oddometer: 909
Might I ask for comments/observations on the chapstick stuff, or the tape?
I've used the chapsticks, and found it darn convenient. Very easy to work with, not messy at all. Be it the thread lockers or the antiseizes.
Was just given some tape thread locker to try out, but haven't yet.
foxtrapper is offline   Reply With Quote
Old 02-28-2013, 05:50 PM   #8
dirty_sanchez
Dirty_Sanchez
Oddometer: 3,028
The liquids, sticks, and tape are all different tools and all serve a slightly different purpose.
Dirty
Old 03-01-2013, 03:42 AM   #9
foxtrapper
Oddometer: 909
Dirty
OK, (confused).
All three are Loctite blue or red thread lockers. Darned if I see how they are supposed to be serving different purposes.
I've had bottles of the liquid harden up on me. And it's a bit messy to work with.
The chapstick stuff doesn't seem to ever go bad, but it doesn't seem to set up as strongly as the liquid. Darn easy and neat to work with.
No experience with the tape yet. Not sure that I'll find it convenient at all, considering how much fun I don't have with teflon tape when doing plumbing.
Old 03-01-2013, 04:41 AM   #10
Benesesso OP
Benesesso's Avatar
Oddometer: 9,898
Never happened to me. Still have some that's over 30 years old. They may or may not develop full strength, but they are still liquid and still harden in threads. Once in a while (every few years) I'd remove the cap and give the bottles a few squeezes to get more air/O2 inside.
I keep them in my garage refrigerator. Almost out of the blue one, guess I'll have to break down and buy another bottle--and some more primer T.
Old 03-01-2013, 04:46 AM   #11
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Like painting preparation and primer are keys to success.
you don't see luggage racks on a hearse..........act accordingly
Old 03-01-2013, 11:20 PM   #12
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,641
Dirty
The single greatest collection of all things loctite. Its mind blowing
Jayrod1318 is offline   Reply With Quote
Old 03-02-2013, 04:14 AM   #13
Eat the Peach
Eat the Peach's Avatar
Oddometer: 157
Absolutely! I wonder if it's possible for the mods to append/integrate this thread into the original and sticky the original.
Jesse
Eat the Peach is offline   Reply With Quote
Times are GMT -7.   It's 09:05 PM.
