Old 01-28-2013, 08:11 AM   #1
Haggisbasher OP
Oddometer: 9
Question KTM lowering kit for 07 S model
hi all,
been registered & reading for a couple of years now & normally can find every answer but..
i have a 07 990S UK model which i could do with dropping the suspension a couple of inches.. there appears to be a lot seat heights on various years - getting lower as the bikes get newer but i cant find any definitive answer on how to lower it properly apart from remove everything & send it to a shop..
i have a shock from an 07 standard model which i was going to fit then either drop the triple clamp down the forks or change the hydrostops & inner tubes.. (i think the standard shock spring length is 10mm shorter than the "s" spring?)
BUT
now KTM are offering lowering kits with a rear spring coil / front springs / hydrostops / inner tubes for 250. however there are two part numbers:
60112955133 - Adventure S MY 03-04 -15mm Adventure R MY 05-06/11-12 -20mm
60112955033 - Adventure MY 05-12 -20mm
any ideas what would be correct for an 07 S model & how much would the drop be? If i fitted the bottom listed kit would that drop the bike by 70mm (+/-3") as a standard bike is about 45mm shorter than an "S" before fitting this kit..??
Haggisbasher is offline   Reply With Quote
Old 01-28-2013, 10:00 AM   #2
freco
freco's Avatar
Oddometer: 46
I had the same problem and managed through the local KTM club forum to trade with a tall guy with a "normal" adv. We swap even the central and side stand.
Now I can manage the beast an feel better. Love it even more.
freco is offline   Reply With Quote
Old 01-29-2013, 02:33 PM   #3
75monza
75monza's Avatar
Oddometer: 347
Ask around.
Somebody closer might be willing to swap parts with you. Your tall suspension for thier short suspension. I wish I was closer to you, or I would make the offer.
2006 KTM 950 Adventure - Go Everywhere Bike
1993 Suzuki GSX1100G - Street Touring Shafty
2000 Suzuki DR200 - A Little Smaller
75monza is offline   Reply With Quote
Old 01-30-2013, 06:39 AM   #4
Haggisbasher OP
Oddometer: 9
thanks guys,
i did some googling & found plenty info under WP not KTM. i have a spare standard rear shock so i will fit it first & drop the forks in the clamps to match before i change anything.
Old 01-30-2013, 06:49 AM   #5
James Siddall
suspension guy
James Siddall's Avatar
Oddometer: 176
Ride Height
If you already have a short shock you are half way there.
You can have a shop change the parts that will make your forks the same stroke length as your shock, or if you are mechanically inclined you can do it yourself without too much difficulty.
The difference between 07S and Standard is 55mm, which is pretty significant. I think you'd be happier with the performance if you did shorten the forks.
Cheers
James
www.superplushsuspension.com
Never argue with stupid people, they will drag you down to their level and beat you with experience.
James Siddall is offline   Reply With Quote
Times are GMT -7.   It's 09:16 AM.
