01-28-2013, 11:06 AM
#1 |
Oddometer: 118
Starting Problems...
So for the past few weeks I've been having some trouble starting my 2000 SV650, I knew it needed a good carb clean so I did that and I thought my starting problems were over, the bike started quick and ran great, then last week my area got hit with very cold temperatures and an ice storm, consequently I didn't start the bike for about a week (it was also outside in the cold) So yesterday I went to take it for a sunday ride and it wouldn't start (it wasn't the battery either as it turned over fine, I then charged the battery inside and tried again, still wouldn't start) it's acting like it's not getting fuel, but I know it has clean carbs, any ideas?
Seeking adventure and working for RoadRUNNER Motorcycle Touring & Travel www.roadrunner.travel |
01-28-2013, 11:30 AM
#2 |
Beastly Gnarly
Oddometer: 372
The bike was running; you did something to it; now it does not run. It is too cold out for gremlins this time of year.
Examine what you last did to the bike. Since you mention the word carburetor, try getting a can of starting fluid, spray some in the carbs and see if the bike will start. If it doesn't, you likely did something to the ignition. Good luck! |
01-28-2013, 11:40 AM
#3 | |
Oddometer: 118
01-28-2013, 02:35 PM
#4 | |
Red Clay Halo
Oddometer: 11,352
Does this bike have a Vacuum activated petcock? I tried to start my Vstrom the other day after temps had dipped into the mid teens the night before. Took a few tries even for a Fuel Injected bike to come to life.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
01-28-2013, 02:41 PM
#5 |
t00 0ld 2b n00b
Oddometer: 1,340
It wouldn't hurt to put your battery on charge, either. Cold weather does no favors to batteries, and you probably cranked it for a while.
I agree that it will probably start after a spray. I have a quad and lawn tractor that need a shot to get going. I blame it on a loss of volatility of ethanol gas in the carb float bowls. |
01-30-2013, 07:56 PM
#6 |
What could go wrong?
Oddometer: 4,985
Maybe the carbs frozen from moisture in the fuel, warm the carb and run gas line antifreeze.
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
01-31-2013, 06:30 AM
#7 |
Oddometer: 118
So I sprayed some starter into the carbs and she started right up. What I think happens is that this crappy E-10 gas loses its volatility super fast, so if you let it set (especially in the cold) it doesn't want to ignite in the cylinders next time you start it. That spray stuff is magic!
01-31-2013, 06:55 PM
#8 |
t00 0ld 2b n00b
Oddometer: 1,340
Glad to hear you got 'er goin'. I not familiar with the SV, but if the petcock has an off position, run the carbs out of gas before you shut it down if it's going to sit awhile. That way, fresher gas is in the bowls when you turn the gas on when you go to fire it up. If you don't have an off position, there's StaBil, Startron and starting fluid.
