Old 01-28-2013, 04:22 PM   #1
KEELAYMONSTER OP
BRRAAAAPPP!!!
KEELAYMONSTER's Avatar
Oddometer: 156
950 A Front end differences...
Anyone know the difference between a 950 Adventure and 950 SE front end? I bought a used set of wheels for a SE and wanted to convert them for an Adventure. Any help would be appreciated.
Thanks,
Kyle Montagne #141K
KEELAYMONSTER is online now   Reply With Quote
Old 01-28-2013, 04:37 PM   #2
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,114
Valving and springs the SE uses .60 the ADV uses a.52 the SE also has slight different steering geometry .
If you have aADV get your self some SE springs world of difference ,
Wheels SE single rotor Adv twin rotor ,
You can convert the ADV to single rotor cheaply but way more expensive to convert SE to twin rotor
Mudguts is offline   Reply With Quote
Old 01-28-2013, 06:04 PM   #3
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 156
I already have it converted to single rotor. Do you know if the front axle/forks are the same? I know it's a different spring rate. What about rear end? Are the rear wheels and swing arm the same?
Kyle Montagne #141K
Old 01-28-2013, 06:06 PM   #4
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,888
The rear is a direct replacement . . . Front axle diameter is the same.
Motorcycles are Life
If I am not riding . . . I feel like I am missing out on living . . .
mcmann is offline   Reply With Quote
Old 01-28-2013, 06:57 PM   #5
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 156
Hmmmm. Well I think the set of wheels I got aren't for an SE then. The front is a smaller axle. Rear has different spacers. Otherwise I think it will work. Looks like ill be calling RAD wheels tomorrow.
Kyle Montagne #141K
Old 01-28-2013, 08:36 PM   #6
KaaJa
KaaJa's Avatar
Oddometer: 45
Just use spacers from advenventure on both ends and it will work.
Sim Salabim Bamba Saladu Saladim
KaaJa is offline   Reply With Quote
Old 01-28-2013, 09:22 PM   #7
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 855
The axles and fork lugs are not the same. Super Enduros share similar axle lugs with the smaller KTMs (150 to 690) with a machined groove for the speedo pickup. Adventures have there own fork lugs to accommodate the larger axle.
Adventures come stock with .48kg for springs, Super Enduros come with .59kg. Valving spec's between the two are drastically different.
Can you post some pictures of the wheels, it's fairly easy to spot the differences.
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 01-28-2013, 09:24 PM   #8
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 156
Ill get some pics on tomorrow. Do you know if the spacing for the rotors is th same?
Kyle Montagne #141K
Old 01-28-2013, 09:40 PM   #9
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,286
Adv - Front 30mm
SE - Front 26mm
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 01-29-2013, 02:18 AM   #10
LukasM
Oddometer: 5,417
As KaaJa, you just need the right wheel spacers for your model, then they will fit. The bearings and hubs are the same except for the second disc flange on the front.
Old 01-29-2013, 04:09 PM   #11
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 156
Alright here are some pics. Front is definitely a smaller axle. Ill try and get some more comparative pics
Kyle Montagne #141K
Old 01-29-2013, 09:19 PM   #12
KM TUNER
Oddometer: 855
Looks like a nice set of RAD Mfg wheels for a Super Enduro. I'm viewing these pictures on an iPhone, but pretty sure they fit the SE.
Nice wheels!
Old 01-29-2013, 09:55 PM   #13
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 156
Right on. Thanks. So is there a way to adapt them for my adventure? Maybe different bearings/center spacer?
Kyle Montagne #141K
Old 01-29-2013, 10:53 PM   #14
KM TUNER
Oddometer: 855
I'd give RAD a call, they will be able to break it down for you. I would think you could swap the spacer's for it to work but never tried. Best of luck to you!
Old 01-30-2013, 10:58 AM   #15
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 156
Thanks! Ill do that. Ill post whatever I find. If they don't work then expect to see a set of wheels for sale.
Kyle Montagne #141K
Times are GMT -7.   It's 04:50 PM.
