Old 01-28-2013, 05:35 PM   #1
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 388
Water Filter
Hello..
Have any of you tried one of these cheap water filters on ebay?
http://www.ebay.com/itm/Pure-Mini-So...item256a3a7597
skidxr is offline   Reply With Quote
Old 01-28-2013, 06:11 PM   #2
the_gr8t_waldo
Oddometer: 2,099
sure you want to trust your comfort to a device that only goes down to .3 microns? if youre back packing, or any other overnight trip? sawyer sells a three squeeze bottle set up that goes down to .1 micron- i think it comes in at, about 60$us. for whats it worth, i,ve heard enough stories about the pump handles breaking off to even consider that type of filtration set up for myown back country use. even if it could filter at .1microns!
the_gr8t_waldo screwed with this post 01-29-2013 at 06:28 PM
the_gr8t_waldo is offline   Reply With Quote
Old 01-29-2013, 05:15 PM   #3
JoshBMW
JoshBMW's Avatar
Oddometer: 350
Cheep and Ebay are not things I want listed when looking for water filters.
Josh
"Integrity, justice, courage, and action - without these, a person is of no consequence." Don Nelson my friend gone from us, 06/06/04.
JoshBMW is online now   Reply With Quote
Old 01-29-2013, 05:29 PM   #4
sintax
Oddometer: 495
I personally am not a fan of plastic parts on the pump handle. I would be worrying about it failing, or fatiguing after use. I suppose it also stands to sort out what you expect to use it for? Is this just something you plan to use once or twice, or is it something you intend to have around and you'll maybe someday depend your life on.
I have a Katadyn Pocket, its a little heavier, but should last forever if taken care of.
sintax is offline   Reply With Quote
Old 01-29-2013, 06:54 PM   #5
GRN
GRN's Avatar
Oddometer: 27
Agree that cheap + water filter = dumb. I've played in deep back country since I was a kid, clean water = life. I've packed MSR filters for about 20 years, and will continue to do so with confidence.
GRN is offline   Reply With Quote
Old 01-30-2013, 09:53 AM   #6
GHO100
Crazy George
GHO100's Avatar
Oddometer: 1,055
Lifestraw: http://amzn.com/B006QF3TW4
I used one of these on my trek in Nepal and loved it. No boiling, no pills or chlorine taste.
Could probably rig up a straw to extend it or a siphon bulb with some tubing if you wanted to bottle some when you had the chance
2012 BMW R1200GS
www.TeslaLEDS.com
www.NYMSTF.org - Support NY Riders!
GHO100 is offline   Reply With Quote
Old 01-30-2013, 09:52 PM   #7
JR356
JR356's Avatar
Oddometer: 3,638
http://www.amazon.com/Sawyer-PointOn...e+water+filter
As mentioned in second post.
JR356
JR356 is offline   Reply With Quote
Old 01-31-2013, 08:22 AM   #8
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,247
You can get a Katadyn hiker for about $60. I'd rather spend twice the money to get a filter from a reputable manufacturer than take a gamble on cheap Chinese-made Fleabay crap. The problem with those kinds of filters is with quality control.
What do you expect to gain from going from a 0.3 to a 0.1 micron filter? A 0.3 micron filter is fine for filtering human pathogens, with the exception of viruses. However, a 0.1 micron filter won't filter out viruses either. Although a 0.1 micron filter sounds good... in fact, three times better than a 0.3 micron filter, practically it doesn't really make a difference. It does, however, make pumping slower and increases the rate of filter clogging.
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is online now   Reply With Quote
Old 01-31-2013, 10:02 AM   #9
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,535
^^^ You are quite right.And I'll also listen to my sister. After all she has seen enough pathogens viruses etc etc through a microscope in 30+ years to know a thing or two.
She travels with a 0.3 Micron filter and not a cheapo chinee then kills the viruses by other means. Two steps process, they are out there, got lots on that with a quick google search.
Have tools, will travel!
Old 01-31-2013, 10:27 PM   #10
QSrider
QSrider's Avatar
Oddometer: 48
If you like the principle of the pump system, here is the link of the one I've been using for quite some times now (US and Central/South America).
http://www.campmor.com/first-need-xl...=%7Bkeyword%7D
Before that one, I had tried several different models. Some where as good as filtering the water, but the flow was horrible. It took too long and too much effort to make a gallon...
With it, I have filtered red Southern Utah creek water into clear good tasting water with no problem.
I highly recommend it.
The UV lights are good to kill bacteria, but they won't help you with the mud.
_____________________
2001 BMW F650GS Dakar
2003 BMW R1150RT
QSrider is offline   Reply With Quote
Old 02-01-2013, 08:12 AM   #11
letterofmarque
Oddometer: 15
I'm a backpacker and it seems like most people have the right idea from my experience. I used to always use a pump, and I still have one that is from the company now known as Katadyn. However, recently I've started to shift down to ultralight and I made a small change. I've got a steripen and I use a camelbak pre-filter to get everything into my bottle. Check out the pre-filter at REI. I don't own any other camelbak products, and it works great. Also weighs next to nothing. I would recommend bringing a backup in the form for water purification though as if your primary goes out you can really be screwed. I carry portable aqua tablets just in case. I've only had to use them once, but I can't tell you how glad I was to have them.
letterofmarque is offline   Reply With Quote
Times are GMT -7.   It's 03:48 PM.
